Question about Google Nexus 7
Problem logging into paltalk on tablet nexus 7
I push on log-in and cannot log in, does not respond
Peter from Paltalk here! First off i suggest you try the 'basic' things:
- Kill the app in memory and start it again
- If above does not fix the issue uninstall then reinstall the app.
If you are still stuck shoot an Email to ptmobile@corp.paltalk.com and one of the smart guys on our Mobile team will fix you up im sure!
-Pete
Posted on Jul 09, 2014
How can I download flash player ?
  • Google is your friend in such cases :>)
  • How to Install Flash on the Nexus 7 and Other Jelly Bean ... www.howtogeek.com/120277/how-to-install-flash-on-the-nexus-7-and... 2012-07-29 · ... you can install Flash on your Nexus 7, ... it works flawless on Nexus 7. Thanks. ... Took the Flash Player 11.1 from my Galaxy Nexus and it works a ...
  • How to install Adobe Flash Player on Nexus 7 and Nexus 10 ... best-tablet-converter.com/.../install-adobe-flash-player-on-nexus-7-10 This tutorial will show you how to Download and Install Adobe Flash Player 11.1 on Google Nexus 7 and Nexus ... you can install Flash Player on your Nexus 7/10, ...
  • How to Install Flash Player on Your Nexus 7 Tablet to ... nexus7.wonderhowto.com/how-to/install-flash-player-your-nexus-7... Video embedded · There's no Flash Player or Flash plugin in the Google Play Store anymore, ... How to Install Adobe Flash Player on Your Nexus 7 Running Android ...
  • Nov 26, 2015 | ASUS Google Nexus 7
    Android 4.2.2 keeps freezing and a few apps stop working. Any Suggestions? Thank you
    hi u don't mention make or model of youre tablet try this if u have the full app of facebook delete it and just log in on youre browser I have 2 nexus 7 tablets & they both used to freeze until I deleted the full app of facebook .........hope this helps .
    Aug 27, 2015 | Tablets & eReaders
    How do I fix frozen Asus Tablet.
    hi u don't mention a model .....if its a asus nexus 7 hold power button down until it resets ........good luck also with this model if u have the full app off facebook delete it and log in in youre browser or google search the full app of facebook causes them to lock up ........
    Aug 16, 2015 | ASUS Tablets & eReaders
    Nexus 7 tablet won't talk to XP computer
    Hi, make sure that you have your Nexus screen on and passed any PIN or authentication screens, in other words, log in to it.
    Then you should see the main directory on the shared drive.
    Keep in mind that WinXP support has ended last year and vendors do not keep their drivers up to date for this anymore. So there might be problems.
    Apr 15, 2014 | Google Nexus 7
    My nexus 7 tablet fails to turn on.
    Plug it in to give it a full charge. Push the on/off button and hold it in until it turns on. It may take about a minute. I had the same problem with my Nexus 7 because I let the battery get too low and it would not turn on.
    Jan 17, 2014 | Nexus Tablets & eReaders
    How to put in sim card
    Assuming you mean the 2013 version but I'll try both,
    so for the 2013 version
    1. Turn your tablet off and place it on a flat surface with the screen facing up.
    2. Tilt the right side slightly up to find the SIM card tray near the bottom right and the small hole in the tray door.
    3. Insert a paperclip into the hole in the tray door, and push firmly but gently, the tray should pop out.
    4. snp_8a30b60eaed5a3a37f46a8c715167552992e_3271601_en_v0Remove the tray and place the micro SIM card inside it, the angle corner fits with the angled indent
    5. Push the tray it gently back into the tablet.
    6. snp_8a30b60eaed5a3a37f46a8c715167552992e_3271604_en_v0
    Activate SIM card
    1. Open the Settings app snp_2918920_en_v1 and turn off Wi-Fi after completing the set-up instructions. Once Wi-Fi is off, you'll see a notification at the top of your screen.
    2. Swipe down the notification shade and touch the notification.
    3. Follow the activation instructions provided by your carrier.
    For the Nexus 7 (2012) 3G use the same process noting that the tray slot and pinhole is on the left side of the device when its facing up.
    *Note* : Only the Nexus 7 (2013) LTE & Nexus 7 (2012) 3G can accept a SIM card. Wi-Fi versions of the tablet can't.
    Dec 10, 2013 | ASUS Google Nexus 7 8GB Tablet Unlocked...
    Switched on my nexus 7 and it wont go past the multicoloured x
    Only thing to really do is wait for the battery to die all the way, then try the hard reset after it charges up a little bit.
    Nov 20, 2013 | ASUS Google Nexus 7 8GB Tablet Unlocked...
    Nexus 7 16 g tablet wont respond to any touch..powers on ok but no response
    Throw it against the wall as hard as you can. It worked for me.
    Feb 17, 2013 | ASUS Google Nexus 7 Tablet
    Charging problem google nexus 7
    i have a problem with my nexus7 and it want charge or turn on please help me with this problem
    Jan 16, 2013 | ASUS 32GB Google Nexus 7" Tablet with...
    Nexus 7 will not completely turn on
    The battery connector in the Nexus 7 (2012 model) is notoriously problematic. Sometimes dropping the device can cause issues that prevent the Nexus 7 from charging altogether. A hard reset may not work. Fortunately, it is quite easy to fix.
    However this will void your warranty.
    Pop the back of the Nexus 7 case open by pushing a credit card or guitar pick or small screwdriver under the edge of the black plastic case. Start from the top and gently pry the case open, working your way around. The back of the case will come off quite easily. The battery occupies the bulk of the left-hand side of the unit, and a group of six wires come out of the top of the battery to a connector on the circuit board. Gently push the plug out of the socket connector, wait 15 seconds, and push it back in. Snap the case back on and plug in your charger. You should now see the battery charge image appear.17d253bb-4ba9-4ee2-99ca-91507603cc78.png
    Dec 05, 2012 | ASUS Google Nexus 7 Tablet
    Google Nexus 7 Logo
    77 people viewed this question
    Top Google Tablets & eReaders Experts
    noel
    noel
    David Payne
    David Payne
    Are you a Google Tablet and eReader Expert? Answer questions, earn points and help others
