Question about LG LSC26905 Side by Side Refrigerator
Freezer Cold but not freezing LG LSC26905
Freezer is cold, but even Ice will not freeze. The freezer is mostly empty
fridgetech
  • 473 Answers
SOURCE: cold box at the top of the fridge
This box is the evaporator which provide cooling for the whole fridge. They will only freeze things solid that are easy to freeze. Don't count on it being like the normal freezer.
Posted on Nov 12, 2007
jeffbvegas1
  • 520 Answers
SOURCE: LG French door fridge freezer not freezing
hopefully you looked out back ...rear lower panel and checked little white condenser fan running...it really needs too to keep temp stable across the condenser coils and no overheat condition to the compressor.hopefully you wont need the $300 circuit board like I just bought
Posted on Jun 26, 2009
heatman101
  • 43501 Answers
SOURCE: LG GR431SCA fridge will not
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 05, 2010
  • 31 Answers
SOURCE: LG Fridge not cooling, Freezer not Freezing .
u should refill the gas, and clean the condenser.
Posted on Nov 07, 2010
woodchuck789
  • 4066 Answers
SOURCE: LSC27926ST REFRIG/freezer. Ice maker
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn't take much to eventually block the fill tube.
Posted on Sep 10, 2011
I just replaced my automatic ice maker in my Samsung french door refrigerator. Now the temperature is not cold enough to freeze the water which leaves the ice bucket with water not ice. Freezer works
Repair for a Freezer That Is Running But Not Freezing ...
homeguides.sfgate.com > ... > Other Types of Mortgages
This is the heat you feel blowing near the freezer when it's in a cooling cycle. ... Also, using a freezer to cool hot items or opening the freezer frequently will ... If you noticewater pooling on the floor when the freezer is running but not freezing, ...
Why Is My Freezer Not Cold Enough? - Articles - Networx
www.networx.com > ... > Electrical > Appliance Repair > Read Article
Sep 1, 2011 - Next, make sure the freezer isn't overloaded and that the evaporator fan ... are choked with frost, restricting the airflow that makes the freezer cold. ... In verycold weather, a freezer in the garage may heat up, since there isn't enough warm ...unit (even on automatic-defrost units, in case there's a lot of water).
refrigerator - Freezer is cold but not freezing at all - Home ...
Dec 20, 2015 | Refrigerators
The contents of the refrigerator freeze even on low settings
One of the most common problems with freezers is their tendency to build up a thick level of frost and ice that can disrupt performance. The ice can form on the hoses and cause the fan to freeze up. While you want the freezer to be cold, too much ice is not good for the freezer or the food inside it. There are multiple reasons a freezer could start to develop frost buildup.
Freezer Overstocked
Frost can build up in the freezer if there are too many items inside of it. Air cannot properly circulate around the freezer, so the areas with the sitting cold air can freeze the moisture. Frost continues to build up and accumulate, which then allows it to spread. If food is stocked up near the fan, cold air can't get past it, and the fan itself could develop frost to the point where it freezes and stops working entirely. This can be prevented by not overstocking the freezer and by evenly distributing food throughout.
Temperature Setting Too Low
The freezer should have a thermostat that regulates how cold it gets. If the temperature is set at too low of a setting, the freezer kicks into high gear, the air freezes outright and frost quickly builds up. Adjusting the thermostat to a higher temperature or level can counteract this problem, but you may need to de-thaw the freezer to eliminate the frost that has already built up inside.
Keeping the Fridge Door Open
Many people keep their fridge door open for extended periods of time while they examine the contents inside to see what they want to eat. This can contribute to frost buildup in the freezer, because the fridge is taking in a lot of warm air during this process and the fan pushes it up into the freezer. The moisture in that air is then quickly frozen, and ice can build up substantially as a result. The longer the fridge door is held open, the more likely this can occur, so the best solution is to only keep the fridge open for short intervals and then to not open the door again for a while.
Hope this tips will help you. : )
Aug 17, 2011 | Refrigerators
Ice maker not freezing the water. teeth still appear to be turning but water only freezing due to cold freezer. water mostly overflowing and forming icicles all over the freezer section. have removed ice...
the freezer is supposed to freeze the water, the icemaker is just the form for the ice and the motor is to free the ice from the form, make sure water supply is cold water and not hot
Oct 10, 2009 | Whirlpool Refrigerators
Not cooling or freezing
bimetal switch not working. change it.
Aug 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Bottom freezer "on" but not freezing and not making ice
Refrigerator running but not that cold, freezer running also but not freezing at all. Also not making Ice
May 17, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
The freezer is not freezing my ice cream solid and the refrigerator section is not cold, even when the temp is set to the coldest temp. The unit is approx. eleven years old. Kenmore refrigerator with a...
possible that it is frozen up behind freezer compartment panels restricting air flow, check this by emptying freezer and removing panels, if so then you have a defrost problem causing this. If you find nothing and it is fine just not cold then with it being that age repair is expensive to have unit this age recharged and most would suggest replacing it.
Apr 26, 2009 | Refrigerators
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
Cold box at the top of the fridge
Nov 12, 2007 | LG GC-151SA Compact Refrigerator
LG LSC26905 Side by Side Refrigerator Logo
41 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
