Question about Sport & Outdoor - Others
Fridge door seals
I have a thetford c11 fridge in my caravan. the seal on the freezer compartment has split. is it possible to buy and fit a new seal
2 Suggested Answers
  • 30 Answers
SOURCE: Thetford fridge type C11[fitted to caravan]model N80 PL R
This Caravan is a recreational vehicle? If you have an ammonia absorption refrigerator in the unit, and you smell ammonia, your fridge is leaking. This can be a health hazard. Park the unit and get the fridge serviced, they are repairable by independant service personnel. There are only 2 in Ontario Canada. If you go to an RV shop, the will only want to sell you a new fridge.
Good luck, try a search in your area for ammonia absorption refrigerator repair in your area.
Peter.
Posted on Jan 07, 2009
My fridge/freezer is frosting cos the rubbers shot x local repairman says he will not fix as "it never works"x can I replace them myself? difficult? x leroy
most places have a " seal-a fridge " type business that comes to your place and makes and fits door seals to fridges and freezers
check in the trade pages of the phone directory or go google and type in--- fridge door seals and repairs -- to see if there is a business close to you
the only problem that you may have is , if the door and seal edge area is badly rusted
if you can get a seal from a service agent spares and you have some ability you may be able to fit the new seal your self
Nov 22, 2016 | Refrigerators
How do I fit a new door seal to my fridge-freezer?
you buy the new seal and look it over real good . then proceed to look for how the old one is fastened to the door . usually screws .
Oct 25, 2015 | Refrigerators
Freezer is frosting and refrigerator is warm.
As far as your freezer frosting up, sounds like a door seal problem, run your fingers along the seam of the door seal, there should be no splits/holes in the seal.
As far as the refrigerator either there is a secondary fan motor, or there is a obstruction blocking the air movement, if the freezer has a bad seal, its suspect ice is still building up.
Jul 08, 2013 | KitchenAid KSRV22FV Side by Side...
Can I remove the freezer compartment from my Haier HSE12WNAWW?
not possible to remove the freezer
the most likely [problem is that the seals around the freezer door are not sealing properly
that allows the atmosphere into the freezer and the humidity then freezes and turns to ice , causing the problem
adjust the door and change that door seal
when defrosting the freezer, remove all the frozen food, and place a fan at the open door
atmospheric temp air will defrost a badly iced freezer in around 1 hour with the use of the fan on high speed
Apr 05, 2017 | Haier Refrigerators
My brother has a AEG fridge freezer he thinks the part number is either R600A or 412 or KG2 we need new door seals for both doors can you advise the part numbers needed? it is a fridge at the top and a...
The R600a is the isobutane gas in the system. The 412 is probably the alternate gas to be used. The KG2 is probably the weight. You have the make & model number above. most magnetic door seals will fit you buy it in a roll and cut it to size.
Apr 17, 2010 | AEG Santo 3888 KG8 Bottom Freezer...
Whirlpool Fridge/Freezer Door Seal Replacement. Model: ART 462/3
In short no as long as you get the correct seal type from a spares shop, or Whirlpool. Just make sure that it is straight and there are NO gaps or splits in it when you refit it. Usually these will come pre cut to size for the particular model of FF but you can also buy seal strip on a reel from many spares shops. Also when you have removed the old seal make sure that you use a degreasing cleaner to clean around where the old seal was located and make sure the area is dry before fitting the new one.
Aug 16, 2009 | Whirlpool Refrigerators
How to fit a Zanussi fridge door seal
You mean you have a door gasket. A good, step-by-step article on this pesky concept of "panel-screw" gasket installation is found on this handy page:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Appliance_Zone_Refrigerator_Install_A_Refrigerator_Door_Gasket.htm
This should help!
Brad
May 21, 2009 | Refrigerators
Peter.
Jan 04, 2009 | Thetford Porta Potti
Fridge freezes contents
Check the door seal is not split,it may be letting air into the compartment
Nov 12, 2008 | Candy CPCA240FFK Bottom Freezer...
Sport & Outdoor - Others Logo
14 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
