Question about Datamax M-4208 Thermal Label Printer
Datamax Ovation, media sensor broken?
Datamax Ovation, after changing the ribbon, it always gives an error and feeds too many labels as though it cannot find the label edge. i have no idea which bit of the printer is the media sensor (it is not included on the manual diagrams) but from my previous googling i am assuming this is the problem. what can i do?
  • JDTec
    JDTec May 11, 2010
    the paper sensor is usually on the right side behind the print head.
SOURCE: Datamax problem
You probably need to adjust the leveling cam if you have not done so already. This is the green thumbscrew near the print mechanism.
Posted on Feb 12, 2008
JackHeath
  • 1049 Answers
SOURCE: Zebra S600 printer
  1. Try just storing your labels in a cool dry place before using them. Peeling labels are usually a sign the glue is poor or weak.
  2. When tearing you labels off, feed them out before tearing them off, then hit the auto-align. See if that helps it.
  3. Try pushing a normal playing card under the metal cutter that tears the labels and pull it up and through the front to bend the blade slightly outward. This will hopefully allow the labels to pass underneath.
Posted on Jul 30, 2008
SOURCE: Datamax I-CLASS DMX-I-4212
Printer ribbon has a wrinkle and it transfers to the label in the form of a blank line accross the ribbon.
Posted on Aug 19, 2008
informatica
  • 1114 Answers
SOURCE: Datamax Allegro 2
Hi - You can download the manual by clicking the link underlined in blue below:
Datamax Allegro 2
You will need to contact their customer support for the software, the details are here.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Posted on Sep 05, 2008
SOURCE: Z4MPlus Ribbon wrinkles causing lines diagonally across label.
Could be down to tension on the ribbon roller/spool. Check to see if you have pulled out the end part of the spool (black bit) that should ensure there is back tension on the ribbon.
Posted on Apr 11, 2009
Printer will not print
There's a "Media Sensor" in the Datamax that is evidently having trouble seeing the labels. The sensor is inside of a horizontal bar above the labels and just behind the Printhead. That bar is movable. Make sure that the vertical mark, usually white, is positioned over the label - best if it is the center of the label. Also make sure that there is no label or ribbon material stuck in that area. Hold "Feed" button down for a few seconds after checking those two things to "Re-calibrate" the sensor.
Apr 16, 2014 | Datamax Office Equipment & Supplies
Keep getting a check supply error
Slide out the Media Sensor (green plastic bar that sticks out over the labels) about 1 inch from all the way in ("in" = left if looking from front). Then press Feed to clear errors. If still get same error, then look for piece of label or ribbon stuck in that error - ok to blow out with canned air.
Oct 04, 2013 | Datamax DMX-I-4212 Label Printer
POSITON FAULT
Hold in the Feed button for 4-5 seconds, which causes the printer to attempt to "Auto-calibrate." If that doesn't solve it, then slide out the Media Sensor (green plastic bar that sticks out over the labels) about 1 inch from all the way in ("in" = left if looking from front). Then press Feed to clear errors. If still get same error, then look for piece of label or ribbon stuck in that error - ok to blow out with canned air. Then try holding in Feed again for 4-5 seconds to Auto-calibrate again.
Sep 27, 2013 | Datamax I-4208 Thermal Label Printer
Ribbon fault
May 08, 2013 | Datamax I-CLASS DMX-I-4406 Thermal Label...
Supplies
Hold in the Feed button for 4-5 seconds, which causes the printericon1.png to attempt to "Auto-calibrate." If that doesn't solve it, then slide out the Media Sensor (green plastic bar that sticks out over the labels) about 1 inch from all the way in ("in" = left if looking from front). Then press Feed to clear errors. If still get same error, then look for piece of label or ribbon stuck in that error - ok to blow out with canned air. Then try holding in Feed again for 4-5 seconds to Auto-calibrate again.
Dec 18, 2012 | Datamax DMX-I-4212 Label Printer
Position fault
Oct 24, 2011 | Datamax I-4208 Thermal Label Printer
Out of stock
Oct 19, 2011 | Datamax I-4208 Thermal Label Printer
WE HAVE A DATAMAX CLASS PRINTER AND IT'S GIVING ME AN ERROR " TOP F FORM FAULT" WE DO NOT HAVE THE MANUAL. CAN YOU PLEASE HELP? THANK YOU
Most likely problems:
Wrong sensor set in the media type area. Gap, Reflective.
If the incorrect meday sensor is set, the unit will give a TOF error.
If you hae pressed the feed button and kept pressed for at least 4 labels, and it does not automatically calibrate, check the type of sensor.
If you still get error, and the correct sensor is set, do a complete calibration.
You can downlad the user manual at Datamax-ONeil Web site.
Feb 24, 2011 | Datamax I-4208 Thermal Label Printer
Top form fault
Feb 08, 2011 | Datamax I-4208 Thermal Label Printer
Top of form error! help
Jan 19, 2011 | Datamax DMX-I-4212 Label Printer
Datamax M-4208 Thermal Label Printer Logo
88 people viewed this question
Top Datamax Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Starnley Johnwells
Starnley Johnwells
Joseph Mueller
Joseph Mueller
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
