Question about Maytag (MFI2568AEW) Bottom Freezer French Door Refrigerator
Lights in my may tag 2 door refrigerator keep flickering, but won't stay on
It's a 2 door MSF22DAXABOO Maytag stainless steel
5 Suggested Answers
peyton32034
  • 410 Answers
SOURCE: not getting ice
sounds as if the icemaker is getting too much water and causing the unit to flood out. aside from replacing the icemaker you may be able to adj the amount of water going into the icemaker. there is a screw that holds the front cover of the icemaker inplace. remove the cover and you should see a screw  with a + and - sign on it. try turning the screw 1/4 turn then wait for the icemaker to cycle and see if it improves. keep making theses adjustments until your problem is solved thx peyton
Posted on Jan 28, 2009
peyton32034
  • 410 Answers
SOURCE: Maytag MFI2568AES Stainless Steel Bottom
heatman101
  • 43501 Answers
SOURCE: Warm Refrigerator
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 18, 2010
Crew Dawg
  • 275 Answers
SOURCE: maytag refrigerator stainless steel french
Im thinking maybe a power surge was felt by the refrigerator.
Try unplugging from wall for a couple minutes and then plugging it in again.
Hope this resets it...
Posted on Jul 23, 2011
Maytag refrigerator stainless steel french door bottom freezer...lights flashing and ice maker opening and closing/making sound
Jul 23, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
How to clean maytag stainless steel finish on appliances
HOW TO CLEAN MAYTAG STAINLESS STEEL REFRIGERATOR:
Do not use abrasive or harsh cleaners such as window sprays, scouring cleansers, flammable fluids, cleaning waxes, concentrated detergents, bleaches or cleansers containing petroleum products on plastic parts, interior and door liners, or gaskets. Do not use paper towels, scouring pads, or other harsh cleaning tools.
How do I clean and care my stainless steel surfaces such as refrigerator or any other stainless steel made appliance?
NOTE: Just because a cleaner is a liquid does not mean that it is nonabrasive. Many liquid cleaners designed to be gentle on tile and smooth surfaces still damage stainless steel.
> Avoid Citric acid
-it can discolors stainless steel. To avoid damage to the finish of your stainless steel appliance, do not allow these substances to remain on the steel finish:MUSTARD,TOMATO JUICE,MARINARA SAUCE,CITRUS-BASED SAUCES,CITRUS-BASED PRODUCTS.
If you want to clean safe and keep the sparkling steel you can purchase STAINLESS STEEL WIPES this wipes is ideal for cleaning food spills,grime and stains leaving surfaces shining like new. This wipes is for stainless parts only make it sure this stainless steel wipes to come into contact with any plastic parts.BUT THE SAFEST WAY TO CLEAN STAINLESS STEEL SURFACES IS TAP WATER WITH CLEAN WHITE CLOTH.
Jan 26, 2011 | Maytag Refrigerators
Lights on panel blinking. ice dispenser keeps opening and closing
there is the HV board on the back under a cover . 2 680uf capacitors @ 35v are likely domed instead of flat on the top and are likely hot. replacing these with an equal value will cure the problem. they are in parallel so 1000 and 470uf will cure it. mine was same model except white. local dealer said no warranty. did not call maytag but he indicated it might help. good luck
Jun 02, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
How do I initiate defrost in a Maytag tri-door
Try this open the freezer door and flick the light switch 6 times, like flick, ----- flick,----- flick. If 6 does not work try 8, cant remember.
Aug 22, 2009 | Maytag MFI2067AES Stainless Steel Bottom...
What is wrong with my Maytag refrigerator
You have a bad high voltage board call the manufacturer, if the unit is under 2 yrs old they may help cover the repair with the problem your having.
Jul 30, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag ice maker flap keeps opening like it was possessed
If the flap your mentioning is the one that opens and closes that is on the freezer door,than it needs to be replaced with the "Fountain Kit ".In this kit you will have the parts that control this problem.Replace ALL the parts that are in this kit with the parts off your old one.If installed correctly ,the problem is fixed.
May 12, 2008 | Frigidaire FSC23F7DSB Stainless Steel Side...
THE ICE DOOR PROBLEM
Budd, if you want to stop the flapping until service shows up to replace the high voltage board do the following: remove the drip tray, remove the 2 screws under the drip tray. From the bottom, where you removed the screws, pull out and up. The whole disp cover lifts off. Unplug the 2 harness going to the board on the dispenser. The refrigerator will still operate normally minus the dispenser. Catriver.
Dec 25, 2007 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag Refrigerator MFC2061HES - temperature control
Maybe. Is the compressor staying on? If it is...then the temp controller may need to be replaced. If it is cycling regularly, then you are iced up and the controller can't do much to help you. Fully defrost. Takes 2 days to melt it all. Then let's see where we are.
Dec 22, 2007 | Maytag MFC2061HES Stainless Steel French...
Maytag (MFI2568AEW) Bottom Freezer French Door Refrigerator Logo
29 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
