Question about Necchi Sewing Machines
Rihour palace What is the history of rihour palace
I have a Morse Sewing machine Model 9400 I can"t find any information on this machine or that it was even made.can any one help with this
The manual is here in the main link. There is history below. The machine is imported from Japan.
Morse - NBWiki - Needlebar.org
www.needlebar.org/nbwiki/index.php/Morse
  1. Cached
  2. Similar
Jump to Morse Sewing Machine & Supply Corp - Morse was set up in 1948 as a US distributing ... Machines were imported from Japan via Mercury Machine Importing Company, ... of the public preferred machines of domestic origin. โ€ŽMorse Sewing Machine & Supply Corp ยท โ€ŽMorse Foto-Matic Zig Zag (MOD ...
What is the history of the Morse sewing machine company? - Quora
https://www.quora.com/What-is-the-history-of-the-Morse-sewing-machine-company Here's a website that gives a little history and information on some of the Morse sewing machine models: Morse - NBWiki.
Sewing Machines >> Morse Sewing Machine - PatternReview.com
sewing.patternreview.com > Forum > Sewing Machines
  1. Cached
  2. Similar
Jul 30, 2009 - 10 posts - โ€Ž6 authors I tried to get hold of Morse International Sewing Machine since they sell ... the Super Fotomatic from my little collection of machine history.
History of the Morse Sewing Machine ' eHow
www.ehow.com > Crafts
  1. Cached
  2. Similar
History of the Morse Sewing Machine. Morse sewing machines were introduced by Philip S. Morse in 1948. They are recognized for their versatility and ...
What company manufactures Morse sewing machines? ' Reference.com
https://www.reference.com > Hobbies & Games > Crafting > Sewing
  1. Cached
Pine is one of the companies known to have manufactured Morse sewing machines. Morse was established in 1948 as a U.S. distributor of these Japanese-manufactured machines. The Pine Sewing Machine Company was purchased by Singer in 1959.
What is a Morse sewing machine? ' Reference.com
  1. Cached
What company manufactures Morse sewing machines? ... The country of origin was either covered by a motor or the label was removed prior to the machines ...
Sew Chic Pattern Company: The Morse Sewing Machine, a question ...
sewchicpatterns.blogspot.com/2012/06/morse-sewing-machine-question-of.html
  1. Cached
  2. Similar
Jun 15, 2012 - I wonder about the history. How did this happen? Did they advertise to the right crowd? Was the machine too expensive? Made in Japan- were ...
Morse Sewing Machine ' eBay
www.ebay.com/bhp/morse-sewing-machine
  1. Cached
  2. Similar
Find great deals on eBay for Morse Sewing Machine in Sewing Machines. Shop with confidence.
Morse Sewing Machine Pictures
www.sewusa.com/Sewing_Machine_Pictures/morse_sewing_machine_pictures.htm
  1. Cached
  2. Similar
Pictures of Morse Industrial and Domestic sewing machines.
DOWNLOAD PDF 9400 sewing machine manual smm411pdf Machines name begins...
Oct 30, 2016 | Sewing Machines
History of the machine
History of WHAT machine? You want the history of the invention of sewing machines? Have you tried doing a search for "invention of sewing machine"? Have you tried Wikipedia?
Dec 16, 2014 | Sewing Machines
The needle bar of my brothers cs6000i is bent. The repair shop is asking $120 labour and $20 for the part. Is there any way I can fix it myself
Hai, You can try to take one screw driver [ or asking cycle repair shop, elctrician ] put the bent side adjust the needle bar.
Mar 24, 2014 | Brother CS6000i Computerized Sewing...
What year is a Singer G6132572
The G6132572 has built in 1918 and made in Elizabeth, NJ. Most of the history of the Singer machines is available from the Singer UK site: http://www.singermachines.co.uk/faq/singer-sewing-machine-company-history/ .
I hope this helps.
Nov 19, 2011 | Singer Sewing Machines
How old is my model 9018 singer sewing machine serial #N511601027
The Singer UK site has a history of the company. A machine with the serial number starting with N was built in 1900 and was built in Elizabeth NJ. See http://www.singermachines.co.uk/faq/singer-sewing-machine-company-history/ (look at the bottom of the page for the links).
I hope this helps.
Oct 20, 2011 | Sewing Machines
For the HV #1+ embroidery unit, using the plus hoop and embroider
Hi!
You can find the solution by following these steps-
Slide in embroidery card 21 and companion cassette. Touch Embroidery ON.
Touch FUNC to Program mode, The “E” inside the hoop will appear on the left end of the Program display window. If Plus Hoop programming is desired, touch the rotational arrow E one time and you will see the hoop in the Programdisplay window change into a Plus Hoop with a small arrow pointing to the top portion of the hoop, indicating position 1.
Toward the right side of the Program display window are
F1 S1 M1. F1 = Font style (1, 2 or 3), S1 = Size (1 or 2) and M1 = Menu (1, 2 or 3).
FONT: Select 1. Palace Script 2. Clarendon (block) 3. Kalligraphia
(Note: Programmed letters are always displayed in block)
SIZE: Select 1. Large 30mm 2. Small 12mm
MENU: Select 1. Upper case, 2. Lower case, or 3. Numbers and Symbols—check Program display for upper or lower case indication.
Note: You must select the Font, Size and Menu before selecting the letter desired.
Do rate the solution accordingly.
Thanks
Rylee
Mar 16, 2009 | Husqvarna Viking 1
Probel with Embroidery disc
I am pretty sure you can download Disk 100 free from the Husqvarna Viking website. This has all the embroideries that came free with the machine, plus the alphabets (I think!). You can download this direct to your PC or to a set of floppies, depending on what your Designer needs and what support software you have (or have not) got. If you have no Husqvarna software at all, your PC will not be able to read the floppy. It is in .shv format which PCs are unable to read, being an embroidery machine language only.
If you are trying to open the faulty disk in your Disk Manager software, I always found it worked better if I didn't put the disk in the floppy drive of the computer until after I had already opened Disk Manager.
Hope some of the above is useful to you.
Jun 17, 2008 | Husqvarna Designer I
Embroidery programing, using the Palace Script disc
on your alphabet card there should be an UNDERSCORE. Use this to add spaces between words.
Apr 23, 2008 | Husqvarna Designer I
We have a projeck to do for school and we don`t know anyting about vikings history
If you mean the Nordic peoples known as Vikings then this is not the place you need, and your spelling should be project, not projeck. If you want history of the machines with the name Viking made by Husqvarna then you might check husqvarnaviking.com to see if they have a history page on the site. Husqvarna is a diverse company that makes lots of things from firearms to sewing machines to motorcycles and snowmobiles,
Apr 09, 2008 | Husqvarna Viking 1
Sewing Machines Logo
11 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
