Dell 3333dn has a 900.30 firmware error. How do I fix it?
2 Suggested Answers
SOURCE: Dell 3333dn audio driever awrdacpi
download easydriver and install it will help
Posted on Feb 23, 2014
Printer dose not print
From Dell's site:
Here's what did help:
1) if you disable in the web interface, under Printer Server SEttings the HTTP Server Enabled, and the HTTP Config Enabled - the problem WILL go away. HOWEVER, you will loose the ability to remotely administer these printers.
2) Just yesterday Dell supplied a firmware upgrade that is to fix the 900 RIP errors. The file name is: 551_061.fly
This is a firmware upgrade that is to fix the problem, then you do not need to unenable the web interface.
Mar 10, 2015 | Dell 5210n Laser Printer
Feb 21, 2014 | Samsung Computers & Internet
2155cn printer giving error #006-370 what should I do
Power off the printer and turn it on again with the big button held down (the one with the tick on it).
This seems to clear the error and allow printing but won't fix the fault itself.
Feb 17, 2014 | Dell 2150cn / 2150cdn / 2155cn / 2155cdn...
My son owns a Dell Latitude D610 was wondering what a DST error is a can it be an easy fix?
it may be a hard drive error reporting feature available on SOME (not all) hard drives, via hard drive firmware.
Check your BIOS Setup and see if it is enabled : the HD may have a feature you will be able to correct this by enabling it.
have you tried (bottom right corner of screen) Dell icon support " get in contact with www.dell.com and give them the service tag #.
Oct 17, 2010 | Dell Inspiron 6000 Notebook
Dell 3130cn gone down with repeating 016-370 Error...
This type of error code implies that you need to restart the printer again. However, do check to see if toner cartridges are seated in the proper position. Also ensure that they have been locked in. This is an error commonly associated with the Dell 3100cn laser printer. Please let me know the results.
Jun 28, 2010 | Dell 3100cn Laser Printer
Firmware error
Try going into rescue mode by pressing the Play button while inserting the end of a thin object such as a straightened paper clip into the reset at the same time, then hold the Play button until your Dell Pocket DJ turns on.
Scroll to "clean up" and select. This just defragments your players hard drive, you won't lose any data.
If that doesn't fix it try replacing the firmware. Download the most current firmware from Dell's support website. Scroll to and select "reload firmware" in rescue mode. Connect to pc with usb cable and power on player. Double click the firmware file on your pc and let it do it's thing. This won't affect your saved data either.
If neither of those work you may need to reformat the players hard drive. This will wipe out anything you had on the player. Scroll to and select "format all" while in rescue mode. Select "yes" then just watch the progress bar. Good luck!
Feb 17, 2010 | Dell DJ MP3 Player
My Dell printer 2330dn is showing an error of 900.57 Firmware - what does this mean? It will not print
clogatto,
This error identifies a problem with the printers "internal language". Many times the firmware is just outdated and needs to be updated.
Since this firmware is vital in the communication of components, outdated firmware will cause miscommunication such as error messages or weird symptoms.
I would recomend having a tech update the firmware since you really need to know what you are doing.
Apr 17, 2009 | Dell Office Equipment & Supplies
Firmwareupdate Dell 1720
I have the problem with the paper jam error, though there isn´t any paper jam. I´ve read in an other topic, that the firmware update should solve this.
Nov 12, 2008 | Dell 1720dn Laser Printer
My Dell 962 Photo Printer gives error when trying to photocopy.
The issue you are experiencing with your printer i.e error 2200 is related to "Scan Carrier Stall error" I believe the steps mentioned below will fix the issue,
1. Unplug the power cord from the wall socket.
2. Disconnect the power supply from the back of the printer.
3. Wait 15 seconds.
4. Reconnect the power supply to the back of the printer.
5. Plug the power cord back into the wall socket.
  1. Go to www.support.dell.com.
  2. Click on Drivers & Downloads.
  3. Under Option 2: Select a Product as printers .
  4. Locate the printer(s) 962 printer and click Go.
  5. Select an Operating System that is installed in your computer then choose downloads and look for Firmware.
  6. Download and install the firmware, then restart the computer and the printer, however please make sure that you do not restart your computer and the printer when the download and the installation is in progress.
I would appreciate if you could let me know if you have refilled the black cartridge, cause Dell printer often give error messages if the cartridges are refilled and not replaced with an original Dell one. If you have done so please replace the cartridge with a genuine Dell cartridge.
Regards
Malik Khan
Jan 24, 2008 | Dell 962 Photo All-In-One InkJet Printer
64 people viewed this question
k24674
jasbo
jasbo
