Question about Royal 435dx Electronic Cash Register
Have a paper jam, now E1 comes up and it hums when you press a key it is a royal cash register
Have hard time feeding paper also
4 Suggested Answers
  • 329 Answers
SOURCE: I need free manual for Royal ER 145. Recently
Here Goes Program 2 position - enter 102420 att/total key - program 1 position enter o in the departments as non tas enter yy mm dd (09 04 23) hit charge key
enter time hhmm (1500) military time hit xtime depress amout tend key turn off and on and maybe will work for your child...Good luck......have fun
Posted on Apr 23, 2009
SOURCE: Royal 482cx cash register constantly running the reciept motor.
ERror code says Printer overheat! Even when just plugged in. Wont clear. Any solutions?
Posted on Apr 20, 2012
gopakumarg43
  • 75311 Answers
SOURCE: Where can I get a free owner/operator manual for a Royal 500dx electronic cash register?
https://www.royalsupplies.com/cashreg/110dx_Instruction_Manual_Eng_June_08.pdf Try this link to download it. Gopakumar Gopalan Google
Posted on Jan 16, 2015
How to change paper
This product uses 2 1/4in (57/58mm) wide standard thermal paper. Use the feed keys only when changing the paper. Do not pull the paper manually.
1. If prompted during use, or when setting up the printer for the first time, open the printer compartment by lifting up on the tabs located toward the back of the register. This will expose the printers.
2. Depending on each sides needs, use the release buttons to open the paper wells and release the print rollers.
3. Place the paper rolls into the paper well so it feeds from the bottom of the roll towards the front of the cash register (not the back). Pull the paper up and past the print heads towards the front of the cash register.
4. Once done, close the printer arms and use the feed keys to advance the paper.
5. To attach the journal roll to the back of the winding wheel, remove the wheel from the comparment. Put a small fold in the end of the journal roll and feed it under and around the tabs located on the wheel. Spin the wheel manually to take up paper slack.
6. Once the paper is attached, place the wheel into the holder in the back of the printer compartment. The part of the winding wheel with two discs should be on the right side.
Dec 23, 2015 | Royal 29445B Alpha 9500ML Cash Register
CAN YOU REPLACE THE PRINTHEAD
spacer.gif spacer.gif Anything can be replaced, if you know what you are doing. Try contacting the Tech support for your product to get the part.
contact Us ' Technical Support ' My Account ' View Cart
Call us toll-free at 1-877-877-3192
Royal 435dx Cash Register Parts Cash Registers Online offers parts for all models of Royal Cash Registers and POS terminals. From keyboard covers, paper rolls, ink ribbons, keys, manuals, cash drawer inserts, cash drawers, etc. Please e-mail or call if you do not see your parts listed and we will give you a competitive price quote for your parts.
Please select your Royal Parts from the list below:
Nov 23, 2014 | Royal 435dx Electronic Cash Register
How do I change register tape on 500dx electronic cash register
There should be instructions where the paper feeds in. Usually, you follow the rollers with the paper and feed it in. Did you try google.com for you instruction manual?
Nov 17, 2014 | Royal 500DX CASH REGISTER
Feed button error
Check if you have pressed well the plattern
Jun 20, 2014 | Royal Alpha 1000ML Cash Register
Problem with paper roll feed - does not finishing feeding through on transaction need to manually feed to get the whole receipt
hi top of the left side on the cash register their is a button its shape like a arrow .it is the paper feeding key if you wont to manually get the receipt press it
Jan 05, 2011 | Sharp XE-A402 Electronic Cash Register
Sharp A203 cash register froze up
hmmmm are you try to install new paper roll?
the paper feed arm didnt lock
open printer cover and again install paper roll
and close the printer arm
then press cl key
Jul 22, 2010 | Sharp XE-A402 Electronic Cash Register
PP_0.00 is on the display screen The till stays on and inactive no matter where the key is
This sounds like a Royal. That's my best guess since you haven't told me what you have. PP means there is a printer problem. Look for a paper jam or any other reason why the printer motor can't turn.
If anyone needs Royal cash register manuals, try here: http://the-checkout-tech.com/manuals/cashregisters/royal1.php
Jul 20, 2010 | Casio Parts Cash Register PC Desktop
Tom, we have the same problem, did you get it fixed? Thanks,
Trish
Robinson Sew and Vac
Robinson IL
sewvac75@hotmail.com
Jul 09, 2010 | Royal ALPHA850ML Cash Register
Cash register PE ondisplay and nothing will work
It means printer error. Usually after a paper jam. Clear any paper out and try turning off and on at the wall. ***************************************************************************** *****************************************************************************
All of these manuals can be downloaded at: http://the-checkout-tech.com/
royal 110cx User royal 115cx User royal 130cx User royal 425cx User royal 435dx User royal Alpha-580 User Programming royal Alpha-583cx User Programming royal Alpha-600 User Programming royal Alpha-600sc User Programming royal Alpha-601 User Programming royal Alpha-710ml User Programming royal Alpha-9155sc User Programming royal Alpha-9180sc User Programming royal TS4240 User Programming
Mar 02, 2010 | Office Equipment & Supplies
Royal 435dx Electronic Cash Register Logo
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
