Load Paper indicator problem - Canon LBP5000
My new Canon LBP5000 keeps having this button flashing. I have now been able to work out it is the Load Paper indicator and it's flashing because it thinks the wrong size paper is loaded.
How do I stop it, clear the problem and start again? Can't see anything in on-line manual. It all started because I was trying to print an envelope. The job isn't in the print list so I can't cancel it. I have switched the computer on and off several times and it just flashes all the time and I can't print anything.
There doesn't seem to be a reset type button.
  • victoria_bra Jun 22, 2009
    Thank you - there is no cancel button on the printer - that's the problem. I will try unplugging the printer. So far, I've only done switch off and back on. It keeps happening and is very annoying.
    I thought it should know about manual feed without telling it. There is even a clever hole on the print that you slot the envelope into and it should just print.
    Thanks.
    Thanks. I unplugged it for about 15mins. Switched it back on just now and the light is still flashing. Still unable to print. :-(
    Hand writing out the envelopes is definitely the way to go
  • 90 Answers
You should have a cancel button on the printer press that and hit cancel job. if that does not fix it unplug the printer for a few min and it will clear. make sure when you send an envelope to one of these you select the right paper type and "manual feed" in your printer options so you do not cause this again.
Posted on Jun 22, 2009
  • Troy Anderson Jun 22, 2009
    leaving it unplugged will for sure wipe the momory of the job. And FYI don't assume the computer knows anything EVER. If in doubt set it manually :)
Hello! My canon lbp5000 load paper indicator constantly blinks but there is paper in the casette. Can you please help? Ken
Hello sir; Make sure after you closed the drawer, does the paper lift up, if not check machnically problem, if not replace the tray lifting motor.
Jan 30, 2010 | Canon LASER SHOT LBP-5000 Printer
Lbp5000 two sides print
LBP5000 doesn't have a duplexer for automatic double sided printing, so it's maual duplex.
You have to print on one side, then put the paper in the paper tray again. Take note of the pictogram that shows a printed page with the corner turned over, this indicates wich way you put the paper in (for the print you are about to make, not what is already on the paper)
Dec 09, 2009 | Canon LASER SHOT LBP-5000 Printer
My new computer can't talk to my Canon LBP5000
Your unit will work only on vista 32 bit system check canon for more details
Sep 11, 2009 | Canon LASER SHOT LBP-5000 Printer
E2 and error 5100
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
tokio-16
Aug 26, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Machine flashing load paper message even though paper is loaded
Hi ...
Most of the time this problem comes when the paper is not loaded correctly. Follow the below instructions to load papers to the cassette and I am sure this will resolve your problem. I will keep monitoring your responce and if required, i'll look for a work arround.
Follow this procedure to load paper / envelope in the cassette:
  1. Pull out the cassette from the machine.
  2. Remove the cover from the cassette.
  3. Fan out the sheets of paper so that they do not stick together.
  4. Align the edges of the paper.
  5. If the cassette is not yet extended, use your thumb to press the tab (indicated by the pink circular outline) and release the latch.
  6. After the latch is released, remove your thumb from the tab. Then extend the cassette until a click is heard.
  7. Load paper on the upper-right corner of the cassette with the print side facing down.
    Note:
    * Since the Credit Card sized paper, Canon Photo Stickers, and Legal sized paper cannot be fed from the cassette, load them in the auto sheet feeder (ASF).
    * When loading A5 or larger sized paper (nonstandard-size paper: 203mm / 8inches or more in length), extend the cassette by pinching the tab.
  8. Grasp the paper guide (A) and align it to the long edge of the envelope stack (2). Align the front edge of the paper stack in the same way (3).
  9. Close the lid and push the cassette all the way into the printer.
  10. Press the <Open> button and pull out the extension completely.
  11. Press the <Feed Switch> button to turn on the Cassette light.
    *MP500 shown.
    Note:
    If the Auto Sheet Feeder lamp lights, press the Feed Switch button to light the Cassette lamp.
    If the Cassette lamp does not light even after pressing the Feed Switch button, Paper Source in the printer driver may be set to the setting other than the Feed Switch button.
Loading on envelopes
Paper Type
Precaution
Envelope (DL / #10 )
Set paper with the flap closed.
  1. Press down firmly on the edges of the envelopes to make the folds crisp. Also, press firmly on the area that corresponds to the edges of the back flap.
  2. Remove any curling by holding the edges diagonally and bending them gently.
  3. If the edges of the envelope are inflated or are curling, place the envelope on a flat surface. With a pen, press down while moving it from the center toward the edges of the envelope.
  4. Ensure that no curl or puff exceeds 1/8 in. (3 mm).
  5. Load envelopes in the cassette with the print side facing down and the flap towards the left.
  6. Close the lid and push the cassette all the way into the printer.
  7. Press the <Open> button and pull out the extension completely.
  8. Press the <Feed Switch> button to turn on the Cassette light.
    Note:
Don't forget to vote if this helps ... Cheers :)
Jul 17, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon Mx300 wont recognize my paper. says:load paper
I cant print...orange light under alarm keeps flashing...please help...patricia
Jun 04, 2009 | Canon MX300 Office All-In-One Printer
Paper jam
just remove all cartridge and u will find the stell plate wich is movable from there u can remove the paper
Mar 25, 2009 | Canon LASER SHOT LBP-5000 Printer
Canon s520
The number of orange flashes between green flashes indicates the type of error, as outlined below. Check the cause and take the appropriate action. Two flashes: Out of paper, paper jam or paper feed error Replace the paper correctly and press the RESUME/CANCEL button. If paper has jammed in the printer, clear the jam and press the RESUME/CANCEL button. Three flashes: Paper jam If paper has jammed in the printer, clear the jam, replace the paper in the printer correctly and press the RESUME/CANCEL button. Four flashes: Empty ink tank One of the ink tanks is empty. Replace it. If all of the above won't help, unplug the printer from the power cable, wait a while, and plug in. If that didn't fix you, I guess it's time to get in touch with canon, or a repair lab you trust. Good luck
May 16, 2006 | Canon S520 InkJet Photo Printer
699 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
