Question about Samsung RB1955VQ Bottom Freezer Refrigerator
Both refrigerator and freezer not working properly. Refrigerator light on the "interactive display" would be blinking and I would unplug for fifteen to twenty minutes and plug back into the socket. Would run for about twelve hours and then started blinking again. Unplug and plug back in. Last about twelve hours. Am trying to figure out what my problem could be. Any and all help would be greatly appreciated. Thank you in advance.
  • 619 Answers
SOURCE: Sumsung top fridge and bottom freezer
Hi, The infeller struck to build of ice , causes the the beep sound ,defrost manually by two hours put electric fan to fast defrosting ,set rotate knob to defrost , you hear sound cracking of ice and smell burning that was could heating element for defrost if you hear sound like that in manual , later set automatic if timer will not turn you may replace timer .
Posted on Jan 22, 2008
Sea Breeze
  • 4654 Answers
SOURCE: Samsung RS2533SW refrigerator is not cooling.
It sounds like a defrost problem and I will help you if you need. Thanks, Sea Breeze
Posted on Jun 17, 2009
  • 7 Answers
SOURCE: Samsung RSA1DTWP
Check the fan units for freezing up. Its just a matter of clearing and removing the units. Ice may make it a bit of a tight problem. Defrost with a hairdryer and make sure the drains are clear. It worked for me. Paul.
Posted on Jul 11, 2010
  • 266 Answers
If your seals are good on the door and the fridge side is set for a mid range temp ck and make sure the fan is running in the fzr side. The fridge side steals cold from the freezer by directing air from the fzr to the fridge. Also make sure the fzr does not have an ice block in it the back will be frosted up and if you took the back shell off you would see the cooling coils frosted up real bad or even iced if you find this your refrigerator is going to stop working soon. The suspect parts are the defrost timer the heating element in the freezer located with the cooling coils and the defrost limit this is a nickle size disc with one wire running to the end of the heating element it kicks the element on and off to keep it from overheating the fzr. The defrost timer is usually located in the fridge side under the top or backside plastic it will have a slot in it that a flatblade screwdriver will fit it and you can turn it with audible clicks It kicks the heating element in for a few minutes each day if it quits it will not advance. Hope this helps all of the parts can be purchased and installed by the home owner good luck and remember to unplugg before delving into the elect parts.
Posted on Aug 16, 2010
  • 135 Answers
SOURCE: Not cooling freezer or refrigerator.
problem of the defrost element of defrost thermostat
if u live near madison, wi . i fix the problem charge $100 labor. part may be $120
Posted on Jan 13, 2011
The temp says 14 and 8 but should be -21 and 3? Can anyone help
Controlling the Freezer temperature
The freezer temperature can be set between -14°C (8°F) and -25?C (-14°F) to suit your particular needs. Press the freezer button repeatedly until the desired temperature is shown in the temperature display. Keep in mind that foods like ice cream may melt at -16?C (4°F). The temperature display will move sequentially from -14°C (8°F) and -25?C (-14°F). When the display reaches -14?C (8°F), it will begin again at -25?C (-14°F). Five seconds after the new temperature is set the display will again show the actual current
freezer temperature. However, this number will change as the Freezer adjusts to the new temperature. The top and bottom guards in the freezer of this model are the two star sections, so the
temperature in two star sections are slightly higher than other freezer compartment.
Controlling the Fridge temperature
The refrigerator temperature can be set between 7?C (45°F) and 1?C (34°F) to suit your particular needs. Press the fridge button repeatedly until the desired temperature is shown in the
temperature display. The temperature control process for the Fridge works just like the Freezer process. Press the fridge button to set your desired temperature. After a few seconds, the Fridge will
begin tracking towards the newly set temperature. This will be reflected in the digital display. The temperature of the freezer or the refrigerator may rise from opening the doors too frequently, or if a large amount of warm or hot food is placed in either side. This may cause the digital display to blink. Once the freezer and refrigerator return to their normal set temperatures the blinking will stop.
If the blinking continues, you may need to "reset" the refrigerator. Try unplugging the appliance, wait about 10 minutes and then plug back in.
The refrigerator does not work at all or it does not chill sufficiently.
• Check that the power plug is properly connected.
• Is the temperature control on the display panel set to the correct
temperature? Try setting it to a lower temperature.
• Is the refrigerator in direct sunlight or located too near a heat source?
• Is the back of the refrigerator too close to the wall and therefore keeping air from circulating?
Dado
Jul 19, 2015 | Samsung RSA1UTMG American-Style Manhattan...
DF light on continuously
HI,
Please make sure that the cold knob is turned up.Next unplug all the cords of your refrigerator for 30min and allow it to reset.
Let me know the result.
Oct 11, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerator malfunction
samsung units have duel cooling. that means there is a evaporator in the freezer and the fresh food section. it is possible that the temp sensor in the refrigerator section could be bad. and they have been known to have defrost problems there to. the samsung is a complicated unit and its hard to describe how to repair since there is a lot of electronics that control everything. the best thing I could say is to unplug the refrigerator for a few minuets. sometimes this will reset everything and start the unit back to the factory settings. if that does not work I would call for service. hope it helped you some
Aug 04, 2007 | Samsung RS2556 Side by Side Refrigerator
How to reset a samsung refrigerator model number rs261mdpn aftthea power outage
http://www.searspartsdirect.com/partsdirect/part-number/Samsung-Parts/Refrigerator-Parts/DA41-00669A/0046/401/Model-RS261MDPNXAA/1482/0165000
this is the control board you will need for your model if unplugging the unit for 5 minutes doesn't fix the problem. If they are LED lights, then I point my finger at this. This is a plug and play board with molex connectors. Very easy to install with unit unplugged. You can manually reset the display and check for error codes by holding the top left and top right button on your user interface for 5 seconds in unison FOR 5 or more seconds after all the lights flash.
Feb 01, 2015 | Samsung 26.0 cu. ft. French-Door Bottom...
Refrigerator and freezer not working
What is the model number for you fridge?
Mar 12, 2013 | Refrigerators
Samsung fridge RS2555SW is not working. all temp lights are blinking. can you help
May be it needs reset. Unplug the unit for 12 hours and then reconnect to see if that makes any difference.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | Samsung Refrigerators
The digital display resets to 0 F for BOTH the Freezer and Refrigerator after I change the temps (for eg to -4F for the freezer and 34F for the refrigerator) Also the the refrigerator and freezer are...
The OF OF display is the OFF setting, used for display purposes, so the light and controls light, but the refrigerator does not run while it is on display at a dealer. Try pushing in and holding the top two buttons on the left side of the display for about 5 seconds at the same time to get it out of the display mode. You should be able to set temps then.
Jun 20, 2010 | Samsung RFG297AARS (285 cu ft) Bottom...
Freezer, Ice Maker and Water dispenser not working
it has to get down to the proper temperature after the reset the set point is -4 for the freezer and 38 for the refrigerator. the numbers shown o\n the digital display panel stands for the actual temperatures. When the compartmnet tempertures go down, so do the numbers on thge display panel, and finally they reach the set temperatures. Once the system is stabilized , the display tempoeratures are the set temperature.
Jan 26, 2009 | Samsung RS2578BB Side by Side Refrigerator
Control Display keeps changing numbers
we unplugged the refrigerator for a bit over 1 minute and replugged and problem went away.
Jan 11, 2009 | LG LRFD21855 Stainless Steel French Door...
Samsung RB1955VQ Bottom Freezer Refrigerator Logo
42 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
