Question about Troy Garden
My troy built brand edger's motor dies when about to operate
The motor is running after it has been started but,it dies when about to operate.WHY?
  • 25 Answers
Is the choke still on ? How about the condition of the spark plug ? Air filter and fuel filters clean ? Make sure the lower unit is lubed up and nothing is binding.
Posted on Jun 23, 2009
Starter rope is loose on lawn edger
remove the recoil housing and wrap the chord round the spool more to take up the slack
Feb 11, 2016 | Troy-Bilt Troy-built Tb516ec 4-cycle Gas...
When I compress the trigger to get higher speed, it dies on me.
Fuel jet may be plugged Not uncomon on small carbs. I had same problem replaced carb $19 from troy Built Problem solved
Jul 02, 2014 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Troy bilt tb490bc trimmer cranks with start fluid but wont run
if it runs on starting fluid but dies after that runs out then you have a carburetor issue not supplying fuel to keep it running
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Sep 25, 2013 | Troy-Bilt Garden
Troy built Trimmer....tb575
Attached to this response are the front and back photos of the clutch assembly from a TB575SS trimmer motor.dave8459.jpgdave8459_0.jpg
May 20, 2010 | Troy Bilt Tb70ss Gas Trimmer
My Troy-Bilt TB70SS starts fine,but it will only rotate the spool if it`s in half choke.If i put it on run it stops rotating.
Hey... I have the same problem. It will start if I put in on #1, then it will continue to run if I put it on #2... but will eventually stop. It likes to idle between #1 and #2... but it will not run full power on any speed. Relativey brand new. Piece of junk and I will never buy a Troy Built anything even again!
Sorry I could not help with your problem. I can usually fix anything, but this thing is a piece of ****!
May 07, 2010 | Troy Bilt Tb70ss Gas Trimmer
How to change the oil in my troy built pont where is the drain plug
Not sure what a pont is, or what motor you have, but on some of the Troy built small engines from Honda the geniuses designed the motor with no drain plug. You have to tilt or flip the engine over to drain oil out the filler
Feb 24, 2010 | Troy Garden
Want stay running
try ajusting carb did get better.if no rebuild carb and ajust carb again should fix your problem low needle 1 turn out and high needle 1 1/2 turns out this will get it runing and you might ajust again run full throttle to ajust high needle.let me know if this help you.ok
Jul 14, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
I have a troy built 4 cycle weed eater, when you release the throttle the engine dies
If you still have your instruction book look for for the location of the idle adjustment screw. If you find that and adjusting does not help. try some Seafoam this is a carb cleaner. put a little in the tank with some fresh gas. start it and run this thru then readjust your idle.
Don't forget to ck the air filter and clean or replace it, replace it if you can't see day light thru it.
Jul 04, 2009 | Troy Garden
Wont run when you pick it up or give it gas
Make sure your fuel line, with filter has slack to move around in fuel tank.
May 22, 2009 | Troy Bilt Tb70ss Gas Trimmer
Garden Logo
77 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
