Question about Mossberg 835 Ulti-Mag Mossy Oak Breakup Turkey Gun 12 ga. 3-1/2"
How to remove firing pin spring from mossberg 835 shotgun
How do you remove the firing pin spring from the bolt
    Habit-Forming:
  • 143 Answers
Small pin at the back of the bolt. Top edge. Tap it out. As with all pins, just drift it out to the point that you can grab it with smooth pliers and twist it out. Do NOT drive a punch any further into that hole than you need to. Punches widen as they go and you'll deform the hole. Pins are cheap to replace, bolts aren't.
Posted on Aug 18, 2016
2 Suggested Answers
agent91
  • 2100 Answers
SOURCE: I have a mossberg mod 352 KB with a broken firing
Go to gunparts.com online, they have schematics for every gun ever made and parts to boot. They sell to the public, certain items of course. Check them out.
Posted on May 30, 2010
WHERE CAN I FIND THE BREECH BOLT WITH FIRING PIN AND SPRING? FOR A 22 MARLIN 25MN
Contact a local gunsmith for this. This site doesn't sell parts or have anyway to find them.
Feb 16, 2017 | The Optics
Mossberg 500 A old style firing pin; can I replace it with the new factory pin without changing bolts
It'll work but you'll need the spring, too. The old style pin was pushed back out of battery by the locking lug as you pumped the gun. It won't push the new style so you could theoretically have a stuck firing pin fire a shell out of battery. Be safe, just use the firing pin for your bolt....or buy a new bolt off of Ebay. The entire bolt is a direct switch out.
Jul 30, 2016 | Mossberg Optics
WHERE IS THE PIN LOCK LOCATED SO I CAN REMOVE THE ONE BOLT ON THE FIRE WALL TO REMOVE CLUTCH MASTER CYLINDER?
There are two bolts holding the master cylinder to the fire wall remove the two bolts, remove the metal tubes , remove the pin holding the pedal to the master cylinder piston rod , then remove master cylinder.
Dec 12, 2015 | Cars & Trucks
Remmington 700 new total of 12 shots action works and sounds perfect but missfires leaves no mark on the primer
tear down the action clean the parts look for damage on each easpecially the spring and firing pin, and also the ejector to make sure a round is properly seated against the face of the bolt, do the rounds eject properly?, you may need to order a new firing pin and or spring from the manufacturer, Remmington online, some manufacturers will send you free parts such as smith and wesson who desnt even charge shiping
Jan 04, 2015 | Optics
Diagram of a model 70 bolt- how to take the bolt apart to change firing pin
Compress the spring. Remove the C Clip. Remove the spring. Remove the firing pin & cocking piece from the shroud. Drive out the retaining pin in the cocking piece. Unscrew the pin. Reinstall in reverse order.
Oct 26, 2012 | Winchester Optics
Firing pin not working
Take the bolt out of the rifle and take the firing pin out of the bolt. Thoroughly clean the firing pin and surrounding spring with a harsh solvent (Gunblast works well--be sure to lubricate the spring and pin after cleaning).
Nov 28, 2010 | Mossberg Optics
Mossberg 800 bolt disassembly instructions
TO DISASSEMBLE BOLT - Depress Safety
Cap' Lock Plunger #8 and turn Safety Cap
# 1 counterclockwise. Striker Spring #9
and Firing Pin Assembly #10 can then be
removed.
TO REASSEMBLE BOLT - Replace firing pin
assembly and striker spring. Insert safety
cap and turn clockwise making sure that it is screwed forward as far as it will go. Then unscrew
until the hole for the safety cap lock plunger is in line
with the cam slot in the bolt. Drop lock spring and
plunger into hole and face cut out portion toward bolt.
Depress plunger and screw cap clockwise until the
plunger is engaged in the recess in the rear of the bolt.
Oct 26, 2010 | Mossberg Sport & Outdoor - Others
I'm trying to remove the coil spring on a 1981 AMC concord. Is the retaining bolts on the lower spring spindle permanate or do they come out? I collapsed the coil but can't slide the lower spring seat out...
This is for the lower control arm:
NOTE The inner end of the lower control arm is attached to a removable crossmember. The outer end is attached to the steering knuckle pin and ball joint assembly.
  1. Jack up the car and support it on axle stands under the subframes.
  2. Remove the brake drum or caliper and rotor from the spindle.
  3. Disconnect the steering arm from the knuckle pin.
  4. Remove the lower ball joint stud cotter pin and nut.
  5. Separate the ball joint from the knuckle pin using a ball joint removal tool.
  6. Disconnect the sway bar from the control arm.
  7. Unbolt the strut rod.
  8. Remove the inner pivot bolt and the control arm. To install:
  9. Reverse the removal procedure; do not tighten inner pivot bolt until car weight is on wheels. Tighten ball joint retaining nut to 40 ft. lbs. through 1976, 75 ft. lbs. thereafter, strut rod bolts to 75 ft. lbs., sway bar bolts to 8 ft. lbs., steering arm bolts to 65 ft. lbs. through 1979, 55 ft. lbs. thereafter, and control arm inner pivot bolt to 95 ft. lbs. through 1976, 110 ft. lbs. thereafter.
This is for the coil spring.....see if maybe you missed a step in here:
  1. Remove the shock absorber.
  2. Install a spring compressor through the upper spring seat opening and bolt it to the lower spring seat using the lower shock absorber mounting holes.
  3. Remove the lower spring seat pivot retaining nuts, then tighten the compressor tool to compress the spring about 1" (25.4mm).
  4. Jack up the front of the car and support it on axle stands at the subframe (allowing the control arms to hang free).
  5. Remove the front wheel and pull the lower spring seat out away from the car, then slowly release the spring tension and remove the coil spring and lower spring seat. To install:
  6. Place the spring compressor through the coil spring and tape the rubber spring cushion to the small diameter end of the spring (upper).
  7. Place the lower spring seat against the spring with the end of the coil against the formed shoulder in the seat. The shoulder and coil end face inwards, toward the engine, when the spring is installed.
  8. Place the spring up against the upper seat, then align the lower spring seat pivot so that the retaining studs will enter the holes in the upper control arm.
  9. Compress the coil spring and install the spring.
  10. Then install the wheel and tire and lower the car to the floor (to place weight on suspension).
  11. Install and tighten lower spring seat spindle retaining nuts and tighten them to 35 ft. lbs.
  12. Remove the spring compressor and install the shock absorber.
Nov 03, 2009 | 1983 AMC American Motors Concord
SKS bolt jams with gun empty
If you have Cosmo any where it wont work . Clean it from inside the firing pin channel and trigger group , mine would also slam fire and bump fire till I got it all cleaned out
Oct 11, 2009 | SKS Rifle High-profile See-thru Scope...
How do u remove the rear overload spring on a silverado 1500
go and get some new center pins for the rear leaf springs 4wd stores always have them for around $10, take a jack and jack ther rear of the truck up remove the u bolts on one side of the axle, unsrew the center pin or cut it of, remove the overload spring replace the center pin with new ones reinstall the u bolts and move to the other side
Oct 02, 2009 | 1999 Chevrolet Silverado 1500
Mossberg 835 Ulti-Mag Mossy Oak Breakup Turkey Gun 12 ga. 3-1/2" Logo
225 people viewed this question
Top Mossberg Optics Experts
obsteiner
Ted Maxwell
ray gallant
Are you a Mossberg Optic Expert? Answer questions, earn points and help others
