Question about Saws
Change blades on Lobo jt2206
How to change blades on Lobo JT 2206 Jointer
4 Suggested Answers
efs_perpends
  • 1996 Answers
SOURCE: can not find replacement blades for delta jointer
I can't get a hit on that number, the model must be other. But it shouldn't be too hard.
Try to find a reliable sharpening service in your area; someone who does saw blades and knives for the cabinet shops will have a source for tool steel and carbide and can make you a set of knives for your jointer. Just get tool steel. While it won't hold it's edge quite as long as carbide knives, it will take a sharper edge to begin with, and should last just fine if you don't run sand through it.
If you have the original knives, hang onto them as they most likely can be resharpened to like new condition, and steel today ain't necessarily what it used to be.
The critical factor is the height. It's usually between 5/8" and 3/4" tall. You want them to be able to rest all the way down on the adjustable pistons without sticking up more than 10-15 thousands above the cutterhead. That will give you the most resharpenings from a set. You might want to invest in a magnaset to help with setting the knives in place.
Here's a link to the sharpening service I use: http://maps.google.com/maps?rls=com.microsoft:en-us&oe=UTF-8&um=1&ie=UTF-8&q=Precision+sharpening+%2B+Albuquerque,+NM&fb=1&split=1&gl=us&view=text&latlng=15322695688682105671
Finally, I would almost bet some contemporary delta replacement knives would work. If you find a place that will return your funds if they don't, you might be able to order them online. These guys will carry them if you can't find someone nearer you: http://woodworker.com
If I've answered your question or solved a problem, please take a moment to rate this posting...thanks!
Posted on Mar 28, 2009
SOURCE: blade guard for Atlas 6'' jointer
I can send you pics of the one I made from plywood for this same jointer. If you're looking for an original I can't help you there.
Posted on Sep 26, 2010
schwaa44
  • 252 Answers
SOURCE: Changing blades on a dd39c jointer
dajomail52 at this link, claims to have the manual on this link.
Reliant Jointer Model DD39C
Posted on Dec 07, 2016
Dec 07, 2016 | Masonry Tools
2206 error code - Konica Minolta Konica BizHub Pro 1200
Drum Motor check drum area. Cleaning blade, bad motor worse case the board
Sep 06, 2016 | Konica Minolta Office Equipment & Supplies
Delta jointer, where do i find the wrench to loosen the nuts for the blade
go to Dewaltservicenet.com and with your model number you can download a schematic for this tool and also order the parts online. I tried finding them but there are too many jointers listed in the Delta category.
Apr 16, 2011 | Delta Jointer Blades 6 Inch Fits , Jet...
Eg2175need manual for craftsman 6inch jointer model number 113 20 680
Go to partsdirect.com and type in your model number. From there, you can order whatever you need for your jointer.
Feb 06, 2011 | Delta Jointer Blades 6 Inch Fits , Jet...
I need to find blades to fit a delta 6" X5 jointer, model 37-866x
go to Dewaltservicenet.com and under the service locator on the right hand side type in your information. The blade set number that I came up with is 37-658 and they show that as qty 3 in one package.
Mar 19, 2010 | Delta Jointer Blades 6 Inch Fits , Jet...
Blade guard for Atlas 6'' jointer
Mar 09, 2010 | Masonry Tools
Need to find out haw to adjust cutter head and blades.
I called Jet and they e-mailed me a pdf file with the older manual. There is a toll free number on their website.
Jan 26, 2009 | Delta Jointer Blades 6 Inch Fits , Jet...
Technical
a jointer includes infeed and outfeed tables. A set of rotating blades is positioned between these two blades. A fence is set on one side of the jointer to serve as a guide. The infeed table and outfeed table are adjusted so that they are parallel, but the infeed table is slightly lower thereby exposing a small amount of the cutting blades. The woodworker then presses the lumber against the infeed table and pushes it onto the outfeed table; the rapidly spinning blades remove a small amount of material. If the wood is particularly warped, several passes on the jointer may be required.
Aug 27, 2008 | Delta 37-108 Push Blocks for Jointers
Saws Logo
43 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
