Question about Canon MultiPASS MP730 All-In-One InkJet Printer
Weong cartridge error on my LCD screen--I cleaned
"wrong cartridge" error on my LCD screen--I cleaned the heads and put in new cartridges-- error msg. remains--?
This msg. appeared during printing in the "copy" mode.
    President:
  • 2,306 Answers
Wrong cartridge error is a problem with the printhead, needs to be replaced. Qy6-0064-000, aprox. $40.00
Posted on Jun 22, 2009
Just replaced the black ink PGBK on my Cannon MP810 printer and kept getting error msg "wrong printer head". Took printer head to World Cartridge and they cleaned but still get the same msg....
Dont go to Cartridge World :(. This problem is sometimes caused when a cartridge has been re-filled and re-set too many times, The chip corrupts and causes some very weird messages. Simply try a New Set of Cartridges (Not reconditioned or Refilled). GnL Products in NSW have new compatible cartridges for about $10 each. gnlproducts@live.com.au
Apr 04, 2011 | Canon PIXMA MP810 All-In-One InkJet...
Installed Office Depot ink cartridges, BCI 6 C and Y in my MP780. Worked ok at first, but then started getting "wrong cartridge" msg, Per canon rep, turned off mach, disconnected power, took out...
This is an example of why 2nd class refills are junk. I would try to gently clean the printer out. While a lot of people disagree with this advice, a mixture of 90% alcohol in a tiny pipit works well. Then use some lint free q-tips. Most cartridges have electronic chips on them that report the status of the cartridge. Refilled ink cartridges may have bad or defect chips.
Jan 04, 2011 | Canon PIXMA MP780 All-In-One InkJet...
Re cannon mp730 all in one -I keep getting ?wrong cartridge? error msg. when I followed the solutions that had been posted a month or two ago, removing the cartridge holder, etc. I found that the ink was...
Your print head may be damaged. You might consider replacing it.
Canon suggests pulling the ink wells and also pulling the print head and then reinstalling the whole assembly. They consider this a reset. It is also suggested to replace the printhead which the ink cartridges are housed in. I have done this to remedy bad printing and am considering this $50 purchase as I am dealing with "wrong cartridge" message also. Some have said replacing the printhead remedied this code problem. BUT, i did read one person who said this did NOT work. Right now I am debating whether I should put $50 dollars more into this machine....although this printer has been excellent and many agree.
Comments: Apr 17, 2010 - As a follow up I did fix my "Wrong Cartridge" message by replacing the printhead, I worked and worked at cleaning the old one but finally gave in and anted up the $50. This fixed it! Long live DIYers!
Apr 09, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
Canon F50 error Wrong Cartidge , now Put in Cartridge
if you ever get this figured out, let me know, my mp730 says the same thing, i had the head cleaned after i got a wrong cartridge error and now i have a put in cartridge error
Jan 26, 2010 | Cannon MULTIPASS C530 Printer
Canon mpc190s imageclass printer error wrong cartridge
Try to remove all ink cartridges, then remove the print head, clean the contacts on carriage with piece of cotton and little alcohol then put all back again.If this not help replace the print head.It's part number is QY6-0037-000.
Oct 05, 2009 | Canon SmartBase MPC400 All-In-One InkJet...
Canon MP F50 "wrong cartridge" error
remove all cartridges leaving printhead intact.
close cover, turn off
turn on, let power up, error message should be gone.
open cover, reinstall cartridges
if you cleaned your print head like I did you'll probly
eventually end up getting a new one anyway, due to the color variations
but I can at least print text.
Apr 08, 2009 | Canon MultiPASS F50 All-In-One InkJet...
Wrong cartridge
I have the multipass mp700 and have just experienced the same message ..... wrong cartridge. After reading the manual, from the disc, it means that there's something wrong with the print head, most likely needs cleaning, but it won't clean because the printer is sending a malfunction message. I will be trying to clean the head and if that doesn't fix it then I'll buy a new print head. Good luck with the problem.
Aug 15, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Left Cartidge incorrect
Hi, remvoe the black ink cartridge , dip the cartridge in luke warm water for 30 secs , clean the cartridge and unplug the power adapter from the printer , wait for a minute and then reconnect it back , put back the cartridge and then look for the error msg , if it stil displays the same error then its an issue with the cartridge and needs to be replaced..
Do lemme know if it helps..
Thanks
Jul 08, 2008 | Dell 922 All-In-One InkJet Printer
Dell photo 924 ink cartridge problems
Hi ,
if you are getting the msg color cartridge missing , maku sure that it is compatible with your printer , on the cartridges you will get the part no M4646/J5566 , look for those part no's and if it is giving the error msg on the LCD display of the printer , try using the old cartridge ...try the following steps
1) put the old cartridge in and then unplug the power adapter (Black box ) from the printer.
2) wait for 30 seconds and put back the power adapter and turn on the printer, and look for the msg on the printer display. if it gives the same error msg with the old as well as the new color cartridge then its an issue with the printer , and if it does not gives the error msg with the older one then its an issue with the cartridge and if you have purchase the cartridge from dell online/phone then call them back give the order no of the cartridge that u have purchased and they will replace it.
good luck..
Jan 09, 2008 | Dell 924 All-in-One InkJet Printer
Canon MultiPass F20 - "Wrong Cartridge error msg" - not new but hardly used
Take both cartridges out and then you will see a grey lever in the front of the assembly that holds the two cartridges in it.
If you lift that lever up it will allow you to remove the print head assembly.
Soak that in some hot water, use a straw to help blow out any remaining ink residue in the holes that the ink flows throw and once it is dry again put it back in and see if the error goes away.
I'm just running a head cleaning, nozzle cleaning etc. now but I appear to be back in business.
Mar 27, 2007 | Canon MultiPASS F20 All-In-One InkJet...
Canon MultiPASS MP730 All-In-One InkJet Printer Logo
184 people viewed this question
old marine
old marine
