Question about 3M ESPE Rotomix Masonry Tools
Who do I contact to repair a defective motor or bearing? We have had our Rotomix for a very long time.
Why does it pop the reset button?
The button is a current overload protection for the motor. There is a variety of causes. Defective motor windings, carbonized burnt pressure switch contacts, loose connection (e.g. cord to plug, switch terminals, motor terminals), wrong voltage supply to the motor, worn motor bearings, drive belt too tight, or defective driven machine.
I would run the motor with no load, remove the belt or coupling to the compressor pump, and read the amperes and compare to the motor nameplate rating, let it idle a few minutes and listen for bearing noise. By reading motor amperes or current while the compressor is still connected to the motor, it can be determined if the reset button/overload protector is weak. Check every electrical connection for discoloration or overheating and repair if any are found. Check the contacts of the pressure switch. If nothing wrong is found and the motor is just overdrawing current or amperes, then it is time to replace the motor, probably due to a weak or defective motor internal winding.
May 27, 2015 | Air Tools & Compressors
WHY DISHWASHER MAKES A WHINNING NOISE
If the dishwasher is making a loud whining noise, the drain pump or motor bearings are defective, the drain impeller or wash impeller might have worn out. All these components are part of the pump and motor assembly. It may be possible to replace one of the impellers, but the motor bearings cannot be repaired. In that case the pump and motor assembly will need to be replaced.
Jul 14, 2014 | LG LDF6810ST Stainless Steel Built-in...
Ricoh sc452
That error code is related to Paper transfer belt contact motor error
The paper transfer belt contact motor drives beyond the specified time during home position detection or contact operation.Broken harness or defective connectors. Disconnected connector of paper transfer belt contact sensor or motor. Defective paper transfer belt contact motor. Paper transfer belt unit not installed try to change the motor
Oct 24, 2013 | Office Equipment & Supplies
Wtw5640xwi
see this causes and fix it. God bless you
Tub Bearing If the washer is making a loud noise the tub bearing might be worn out, this is a common problem. The bearing can be replaced.
Clutch If the washer is making a loud noise in the spin cycle, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may become loud during spin or just after the spin cycle finishes. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Drive Belt If the washer is making a loud noise the drive belt might be defective. Over time the drive belt will dry out and start cracking, eventually a piece of the belt can break off resulting in a loud noise whenever the motor is running.
Transmission If the washer is making a loud noise the transmission might be worn out or defective. There are many other more likely causes for noise from a washer. If the noise turns out to be caused by the transmission it may have to be replaced.
Drive Motor If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
Water Inlet Valve If the washer is noisy or loud, particularly when the washer is filling, the water inlet valve is at fault. Replace it.
Tub Seal and Bearing Kit If the washer is making a loud noise the tub seal and bearing kit may need to be replaced. This is a common problem and the parts are relatively easy to replace.
Rear Drum with Bearing If the washer is making a loud noise the rear drum with bearing might need to be replace. On this washer the bearing is not sold separately, the entire rear drum will have to be replaced. This is a very involved repair and will require disassembling most of the washer. However, the problem is going to get worse very quickly and so either the drum and bearing will need to be replaced or the washing machine.
Bearing If the washer is making a loud noise the bearing might be worn out. As bearings wear out from friction they gradually get worse and worse until they fail. In the meantime they get louder. If the noise primarily happens during the spin cycle the bearing is likely the problem.
Drive Pulley If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
Pulley If the washer is making a loud noise the pump may be worn out, or something might be caught in it. Remove the pump and inspect it for debris. If it is clear and the blades spin freely the problem might be somewhere else.
U-Joint Kit If the washer is making a loud noise the U-Joint may have failed. This is the primary drive mechanism for the agitation motion in this washer. Although this is not a very difficult repair for a DIY'er with some experience, the part is expensive and so it may be worth considering a new washer.
Motor Coupling If the washer is making a loud noise the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission
Oct 16, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
The bar is not turning and there is no suction
1) test the belt for broken or worn, replace
2) test for pulley worn or defective replace
3) test the motor for worn brushes, lubrication, bearing repair
4) test for bar worn or defective repair or replace
5) hose is clogged, repair bag/tank full, need emptied.
God bless you
Jul 14, 2012 | Vacuums
Not draining
see this possibles causes:
Drain line/air gap
see for clogged pipes, and repair see the diagram
Pump
test for defective pump
Drain valve and/or solenoid
try to lube the solenoid
Belt
see for worn belt
Motor
test for input voltage, bearing, burn
Timer
see for defective time, clean with special spray contact, tight wires, see for burn wires, and break wires.
5_9_2012_11_40_30_am.gif5_9_2012_11_40_49_am.gif5_9_2012_11_41_09_am.gif5_9_2012_11_41_30_am.gif
May 08, 2012 | Dishwashers
Power comes on but will not start wash cycle justs sit there and humms
Try the steps below:
- try running it without any load to see if it still hums.
- if it does, see anything underneath the pulsating disk if there's anything stuck. (like a coin or a pin)
- if it doesn't, You can also try removing the belt between the motor and the pulsator to isolate if it's a defect in the motor or the pulsator.
After that, If the motor is defective, then you'd have to replace that or repair it if you know how to. If the pulsator is defective, check again if there's something stuck in the bushings. If you've used the washing machine for quite a long time, you may need to replace the bushings and bearings of the pulsator. You can also buy an assembly unit for the pulsator if there's one available in your area.
Hope this helps.
Jan 27, 2011 | Washing Machines
I have replaced two DX300 washpump motors in 6 months and both times the front bearing has seized due to water contamination.This is due to the mechanical seal leaking past and entering the bearing.Is this...
not at all you have a defective seal on the washer. I would contact the maker of the unit and see if they have a recall on this particular model for the reson stated above
Hope this helped
Dave
Feb 03, 2010 | Dishwashers
Reddy 110000 btu fan motor needs front bearing , shaft id fine i took motor apart by grinding weld off of end bell. i am a motor repair expert, retired do not have accses to a lathe or i coud make a...
You may want to contact Master Parts, they may not have the bearings. However, they may have that motor at a reasonable price. You can contact them at 800-446-1446 or online at www.masterparts.net. I hope this helps you.
Mar 06, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Spinning
bearing is bad.its located on the motor.it is rusted and got totally dried up.the oil on the bearing is completely got over so its not moving frequently.so first put some oil on the motor bearing and wait for some time and check out.if still the same noise the bearings got worn out.so motor needs replacement.only spare bearing are very rare to get. --------------- If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Jan 09, 2009 | Indesit W 123 Front Load Washer
Masonry Tools Logo
94 people viewed this question
Top 3M ESPE Rotomix Masonry Tools Experts
Tom Chichester
Are you a 3M ESPE Rotomix Masonry Tool Expert? Answer questions, earn points and help others
