Question about OKI MICROLINE 520 Matrix Printer
Oki 420 alarm light utility prop on - OKI MICROLINE 520 Matrix Printer
4 Suggested Answers
  • 40 Answers
SOURCE: oki 520/521 logic boards
Check if the Pico fuse is blown ? next to the heat sink on the transisitor array with the number 2025.if the fuse is gone than the fuse plus the 2025 transistor must be replaced.
Dezzi
Posted on Dec 31, 2007
Soulvisitor
  • 1113 Answers
SOURCE: oki 520/521
Cover on these are often broken causing the two little switch's to not close on left and right of lid
Posted on Jan 20, 2008
SOURCE: Hello!OKI MICROLINE 5520 NLQ and
Hi, I have the same problem, my solution is: change the cooler in bottom of the printer.
Posted on Apr 28, 2011
Printer Throws Alarm, HSD, Prop error and Head Problems
Most likely, you need to lubricate the shaft the head moves on and clean the positioning tape (carefully, the marks on it can be dissolved).
Unplug the printer while it's moving the head, so you can manually move the head around. Use light oil, such as used in sewing machines.
Oct 17, 2014 | OKI MICROLINE 321 Turbo Matrix Printer
Printer prints one line, then alarm light comes on and stops printing.
Sir the printer is giving line because the cartiage or toner is not of good quality so it does not melt properly and produces line while the alarm comes and stop printing is due to the problem in charging cathode or gutter
Jun 03, 2013 | OKI MICROLINE 321 Turbo Matrix Printer
Machine stopped - alarm light flashing
just saw this yesterday. remove the top rear paper guide. on the left side between the tractor feed and the input slot for the paper, there is a sensor flag that pivots. check for paper scrap caught under the flag. it prevents the flag movement, causes a paper out alarm.
Jul 13, 2012 | OKI MicroLine 420 Matrix Printer
I have an Oki C3400 that wont print
Could very well be the sensor window. I suggest looking at the side of the drum on the right side and pushing a q tip into the opening. heres an older model thats sort of similar instructions. http://www.c3400.co.uk/index.asp?menumode=0&content=sensorerror
Also you can check the exact error code here. http://www.okic3400.co.uk/library/downloads/utilities/c3300c3400smv1115.exe
Dec 10, 2008 | OKI C3400n Laser Printer
Alarm light flashing
Is the front cover on the printer(ifs its not the alarm light will keep flashing as there is a sensor that will trigger the alarm if the cover is not on or not on properly.Hope this helps?
Dezzi
Jul 16, 2008 | OKI MICROLINE ML-395 Matrix Printer
Microline 420
When the alarm light is blinking what other lights are on. This is the fatal error code with the printer.
Remove the ribbon. if still not moving smoothly unit needs service. 3 year warranty on this unit brand new.
If you cannot move the carriage back and fourth accross,
there is a seriuois issue. unit requires service.
Jan 29, 2008 | OKI MICROLINE 520 Matrix Printer
Printer won't print labels
What driver are you using ? the default driver should be IBM Proprinter.
Hope this helps
Dezzi
Jan 24, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Oki 520/521 logic boards
Dezzi
Nov 22, 2007 | OKI MICROLINE 520 Matrix Printer
Oki 520/521
OKI MICROLINE 520 Matrix Printer Logo
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
