Question about Rancilio Coffee Makers & Espresso Machines
Rancillo espresso machine classe 8 - Rancilio Coffee Makers & Espresso Machines
2 Suggested Answers
  • 3828 Answers
SOURCE: My rancillo classe 8 is leaking it leaks more when it is in use than when it is not in use any ideas what could be wrong with it
its a commercial coffee brewer
has hose connections heater chamber pump
seals and jets
needs a service
Posted on Mar 11, 2017
seals and jets
needs a service
Mar 11, 2017 | Coffee Makers & Espresso Machines
What are the Rancillio classe 8 all settings numbers?
This would depend entirely upon what drinks you are making. Most users set the quantities based on the double espresso drink; as an example 14g of powder tamped to produce a 75ml double shot in 22seconds. Other drinks can then be set from there.
Dec 07, 2014 | Coffee Makers & Espresso Machines
My rancilio classe 8 has the water run out to fast first it happened on one side now its on both sides. We run it manually. Do you have any suggestions
Adjust the grind of the coffee you are using finer, I don't know what type of grinder you are using but I will assume it is a commercial one. Adjust it about 2 numbers towards fine that will be a good start.
Jun 28, 2011 | Rancilio Classe 8 Fully Automatic 5 Liter...
Our rancillo silvia does not heat up water or make steam. the power light shows on.
Sounds like the heating element is fried, you will need to find a local person who understands basic electrical troubleshooting with a meter. Take the top off and have somebody meter voltage across the heating element electrodes if there is voltage ther,e but the machine is cold, your heating element positively absolutely has gone bye bye. We can repair this
WWW.DOLCEVITAESPRESSO.COM
Mar 04, 2011 | Rancilio Silvia Espresso Machine
Espresso works but steamer isn't working
Is the water from the espresso hot? If yes, then check the nozzles at the end of the steam wands. If no then make sure the middle switch is turned on. If the middle switch is turned on, then the hi-limit reset tripped and needs to be reset, remove top panel and find red reset switch and push in.
Feb 17, 2011 | Rancilio Classe 8 Fully Automatic 5 Liter...
I have a brand new Rancilio Classe 8 and it appears that the pump is not working. The machine was previously on another espresso cart, but was never used. However, the boiler was already filled. Note: it...
The pump may have some scale making the impeller stick. First remove it and attempt to turn the impeller shaft with a pliers. You may be able to unstick it. If not, you will need to use an aggressive descaler that you should completely soak the pump in. 50% muriatic pool acid is what I use. If after this, the impeller shaft will not budge with a pliers, your pump is no good and this is a very common problem in machines that sit. You will have more scale problems from that machine sitting, so get ready.
Feb 16, 2011 | Rancilio Classe 8 Fully Automatic 5 Liter...
Hello , please help me. we have Rancilio Classe 10 Espresso Machine , this is stop working, "machine is not ready" also error 2 lower pressure, i don't know, why?
Turn machine off and then back on. That should reset machine. It went off because it did not reach the correct temp in time so the CPU turned the machine off.
Jan 04, 2011 | Rancilio Classe 10 Espresso Machine
I need a manual for the Francis Francis X1 Trio' espresso maker
I have pdfs of the user manuals for X1 & X2 machines, email me me if any use to you
Jan 03, 2009 | Coffee Makers & Espresso Machines
Home expresso cappucciono machine
Look, if you want to use an espresso machine in a sem- commercial way, I would strongly suggest you look for a second- hand 1- group commercial machine.
These machines have a copper or stainless steel boiler, and run under pressure all the time. They have a motor- driven pump and indirectly heat the coffee water. Steam is always available for milk frothing, and they do a superior job of this. You also have a source of plain boiled water for other purposes (tea, Bonox or whatever). They are very hardy.
You shouldn't need to pay too much.
Mar 10, 2008 | Saeco Magic De Luxe Espresso Machine
Coffee Makers & Espresso Machines Logo
20 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
vilhj
Level 1 Expert
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
