Question about Merits Health & Beauty
5 red led flashing on merit scooter model #s246
5 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: Require instruction book for DMA Merits
PRIDE pdf
Posted on Apr 19, 2010
  • 177 Answers
SOURCE: Scooter moves approx 10 feet then stops led flashe...
Hi. 8 flashes is a fault code for a motor fault. It will be either worn brushes in the motor or faulty connectors to the motor. This fault code means that there is no circuit through the motor. Probably time to overhaul the motor. Most mobility scooters have plugs and sockets that are really to small to carry the amount of current that they do. Because of this, they sometimes fail.Good luck. Neil.
Posted on May 28, 2010
  • 692 Answers
SOURCE: scooter battery shows full charge but scooter does
Plamont unfortunately that flash code usually means a controller error. The controller is the brains of your scooter. Take the seat off and remove the rear shroud that covers the batteries and motor/gearbox assembly. Check all the wiring connectors for damage or loose connections. After checking the connectors turn the scooter on and see if you still get 8 flashes.
Did Medicare purchase the scooter? If so they will pay for most of the repair costs. You can contact your provider that sold you the scooter or a repair service Repair Xpress@ 1-877-581-3733 or Roadrunner Mobility @ 1-800-467-2668 Hope this helps you
Posted on Sep 13, 2010
wcdoc1953
  • 280 Answers
SOURCE: I need a key for
Yes, the number on the seat post is a serial number for the scooter. Please call Merits in Florida at 1-800-963-7487 and ask them to send you a key. They may send you one for free or a nominal charge. If you need a key right away they will direct you to a local dealer who has one in stock. Hope this helps.
Posted on Dec 29, 2010
What is maximum wheel size that can be used on merits challenger scooter
Only the stock size.
Merits Challenger Three and Four Wheeled Scooters - Independent ...
ilcaustralia.org.au/products/5611
Nov 30, 2016 - A rear wheel drive scooter with rear suspension, suitable for outdoor use. It is available with three or four wheels. Closed loop handles allow ...
Merits Parts - All Mobility Brands - Mobility Scooter and Power Chair ...
www.monsterscooterparts.com/mobility/mobility-brands/mehepr Merits Atlantis (P710/P7101/P7102) Power Chair Parts. ... Monster Scooter Parts carries Merits parts for all models, including scooter and power chair replacement battery chargers and battery packs. ... As an authorized Merits parts dealer, Monster Scooter Parts can help you find just the ...
Merits Health Products - scooter, power wheelchair, manual ...
www.merits.com.tw/ Merits is the professional manufacturer of health products. We specialize in scooter, wheelchair, home care bed, accessibility, patient aids and other home ...
Merits Challenger 4 Wheeled Scooter - Assistive Technology Australia
https://at-aust.org/items/6176 Nov 9, 2016 - Merits Challenger 4 Wheeled Scooter - UNAVAIL (Deleted). Learn More. Approximate Price: $4350. No supplier. (0 suppliers). For information ...
[PDF]Merits Pioneer 3 and 4 Owner's Manual.pdf - Scootaround
https://www.scootaround.com/.../merits/Merits%20Pioneer%203%20and%204%20Ow... Congratulations on the purchase of your new Pioneer 3 or 4 power scooter. We at ... tiller assembly, battery charger, and owner's manual. Contact ... Wheel Size.
maximum wheel size that can be used on merits challenger scooter Google...
Apr 05, 2017 | Health & Beauty
Merits s548 Scooter, LED light flashes 9 times, meaning Other Internal Problem, will quit running at times.
hi, that error can be caused by a loose or bad connection to the controller or somewhere within the main loom, i suggest you disconnect one battery and refit all connectors on the main wiring loom plus those going to the controller...
Good luck,..
Regards
Rob
Sep 29, 2016 | Health & Beauty
I'm trying to find out the battery hookup for a Merits S549 Scooter; had to replace the batteries and want to make sure I hooked them up correctly
there should be two sets of cables, 1 set per battery, do not put one cable on one battery and one on another. Black is - and Red is +. the each cable plugs into its connector into the scooter system.
http://www.meritsusa.com/UploadFile/common/file/20160125/20160125064145_5387.pdf
Apr 22, 2016 | Electric Mobility Merits Electric...
Where is a wiring schematic for a Merits Pioneer 3 S 131 3 wheeled scooter?
You can call Tech support at Merits 800-963-7487. owners manual may have where the fuses would be. Lights could be burnt out. more likely the wires were disconnected.
Feb 10, 2016 | Electric Mobility Merits Pioneer 3 Hd ...
My charger flashes red/green and does not charge my scooter. Any suggestions?
hi the red led should not flash the green led should only come on when batteries r charged while charging the green led turns orange or yellow....can u borrow another charger just to check to c if its not the scooters charging circuit that is the problem..or the batteries ..good luck
Sep 19, 2015 | Health & Beauty
How do I know if my scooter is full charge
The charger will cut out when the batteries are fully charge. Look for the green led on the charger.
Oct 10, 2014 | Electric Mobility Merits Pioneer 3 Hd ...
Is there a reset button on a Merit Pioneer 10 scooter
You had better recheck your connections because the batteries are polarity reversed
Mar 20, 2017 | Cars & Trucks
I need a key for a Merits Electric Scooter. On the seat post I found Merits *1030837*. Is this the model or serial number. How can I find the correct info and how do I get a key. Thank you, Dianne
Dec 29, 2010 | NRS Merits S2351-ARMU Pioneer 1 Mini...
Health & Beauty Logo
Top Merits Health & Beauty Experts
D. E. Hev
Dennis Key
Dennis Key
Are you a Merits Health and Beauty Expert? Answer questions, earn points and help others
