Question about HP DesignJet 9000 InkJet Printer
Spots in image?
I am getting spots in the image on paper? The same image prints fine on vinyl material?
What is error 5101
When the message "5100 / 5101 Printer error has occurred. Turn off power then back on again. If problem persists, see the manual." is displayed, the behavior of the print head holder is interrupted.
Do you see a jammed paper or foreign material?
Did you install the print head properly?
Please see the following for detail.
If the problem persists, contact the service center for repair. Cause 1. Is there a securing material for the holder inside the printer? Summary There may be a securing material for the holder inside the printer.
(This material must be removed before using the printer.)
Open the Top Cover, then remove the securing material for the holder. See Also Cause Summary [ With the securing material ]
[ Remove the securing material ]
Then, close the cover, and turn ON the printer again. See Also Cause 2. Is there a jammed paper or foreign material inside the printer? Summary Stop printing, then push the power button of the printer to turn OFF the printer.
Open the Top Cover of the printer; then,
  • If there is a jammed paper or foreign material inside the printer, remove them.
See Also Cause Summary [ The printer with the Top Cover opened ]
( Paper jam )
After checking the above items, push the power button to turn ON the printer again.
CAUTION
When removing the jammed paper or foreign material, take extra care so that you do not touch the inner parts. Or, it may cause another printing problem.
See Also Cause 3. Is the ink tank properly installed? Summary If the ink tank is not properly installed, it interferes with the operation of the print head.
See the following images to get an idea of proper print head position. See Also Cause Summary [ When the ink tanks are not properly installed ]
The ink tank is not set firmly.
The ink lamp is not turned ON. See Also Cause Summary [ When the ink tanks are properly installed ]
The ink lamps are turned ON.
CAUTION
Always remember "Do not touch the Print Head Holder while it is moving."
Wait until the Print Head Holder automatically stops.
Do not even attempt to stop/move the Print Head Holder by holding it.
Canon PIXMA MX922
Apr 10, 2017 | Canon Pixma MX922
Where can i get cheap vinyl banners with high quality material?
Hi Aaron, I think you should visit BestofSigns.com they provide high quality vinyl banners and signs at lowest price from across the web in USA.
Aug 07, 2014 | Canon Scrim Banner Vinyl Paper - 24 x 480...
Service manual hp 9800
I have an HP 9800 Deskjet that I print heavier self stick vinyl paper. The print comes out wavy. Lines aren't strait and images get blurred. Seems like the rollers might be worn causing it not to pull paper in right and centered.
Mar 25, 2014 | HP DeskJet 9800 InkJet Printer
Epson Photo 1390 leaving the paper grip at the end ...
Use a paper deroller, or strengthen the vinyl backing by adding some sticker on it's back side so it won't curl this much. Packing tape should do it.
Mar 13, 2014 | Office Equipment & Supplies
Can not find a jaguar xkr logo decal
Print an image of one and go to the local vinyl print shop and have them make a digital copy of one and create it using vinyl sticker. You can also have one printed and a vinyl print shop. Should cost maybe 20-30 bucks
Oct 02, 2013 | Decals, Emblems, & Detailing for Jaguar...
Ink spots on back of printed page from Canon i860. What to do?
Type in your search engine How to get rid of ink spots on back of printed page from Canon i860 printer.
It will take you to How to download a manual that will help you fix this issue. PDF.
Jun 18, 2017 | Canon i860 InkJet Photo Printer
Spots on paper
Look on the image drum (bottom of toner cartridge) are there spots on that?? if so clean carefully so as not to damage it or replace the cartridge. If this is not the case open the cartridge door during a print, but before the paper fully enters the fuser and check if the spots are already there, if not the fuser is causing the problems.
May 14, 2008 | Lexmark E321 Laser Printer
Paper has black marks only on the edge
There are several issues that will cause a problem like that.
1, As X box mentioned is a problem with the drum. That is part of what is called the print cartridge or imaging unit. There is most likely a shutter or opening in the cartridge which you can shine a flash light at and see if the defect is visible. If so you will have to replace that cartridge. I would suspect that is the most likely issue.
2. There may be something in the paper path. A small piece of paper riped off in it, something else, a piece of tape, label, etc may have made it into the machine, that will make contact with the paper and smear the image.
3. Lastly, your fuser roller may be bad causing the reprint.
How to determine where the issue is, shut the machine off while it is printing and jam the paper in the image area. See if the defect is on the paper before the fuser. Eliminates the fuser ....
Feb 19, 2008 | Lexmark C522n Laser Printer
Solid Blank Line
If it's blank, is this on what you send/recieve?
Also if you print something like a status sheet, is it missing on those too? If so, your print head needs replacing.
If its on copies/sents you need to clean the scanner head.
Feb 15, 2008 | Brother IntelliFAX 885MC Plain Paper...
Black smudge streaks on rightside of printed/copied material
Can only be two things the drum or the fuser. More than likely drum they last about 4 toners i think.
Learn the art of getting a page to stop halfway threw printing, you want to stop the page after the drum has put a image on the paper but before paper has gone threw the fuser (hotbit).
Once you have mastered the position correctly by stopping the printing by opening the door and removing drum/toner cartridge, to reveal the paper that is printed but can be rubbed off, we will know if marks are coming from the drum (you will see them) or from the fuser, if print is fine.
Dec 17, 2007 | Brother MFC 7420 All-In-One Laser Printer
HP DesignJet 9000 InkJet Printer Logo
11 people viewed this question
Seeker5211
Seeker5211
