Question about Canon BJC 4300 N InkJet Printer
ECP-500 decimal code for cash drawer kickout
Does anyone know what is the decimal code for the cash drawer kickout for the ECP-500 A9 thermal printer?
How to program bottle deposit on xe-a507
PartsandTheirFunctions Printer cover Operator display Keyboard Drawer Check slot Drawer lock SD card slot (Refer to the "SD CARD Mode" section.) Printer The printer is a thermal printer, and therefore it does not require any type of ink ribbon or cartridge. The average life of the printer is approximately 6 million lines. When removing the printer cover, lift up its rear. When installing the printer cover, hook it on the pawls on the cabinet and shut it. CAUTION:Thepapercutterismountedontheprintercover.Becarefulnottocutyourself. Keyboard ? Keyboardlayout ? Functionkeylist { Receipt paper feed key PLU/sub-department/UPC key } Journal paper feed key Department code entry key Function menu key Department shift key a Auto key CLK# Clerk code entry key w Tax1 shift key Department 1-40 key 0 Percent 1 key FI Cursor (up/down arrow) key - Discount key m Mode key t Void key Escape/Cancel key H Help key X Charge 1 key f Refund key R Receipt print key @ Multiplication key Y Charge 2 key P Decimal point key u PLU/UPC inquiry key l Clear key x Check key 0 9 : Numeric key ; Non-add code/Time display/Subtotal key A Cash/Amount tender/No sale key Displays ? Operatordisplay •Screenexample1(REGmode) Salesinformationarea: When a transaction information occupies more than 2 lines, you can scroll to the direction by using the F I keys. Sales information you have just entered such as items and prices will appear between 1st line and 2nd line. Total is always appear at 3rd line. NumericEntryArea: Statusarea: Mode name Status information Clerk code Receipt ON/OFF status indicator (R) : Appears when the receipt ON-OFF function signs OFF. Sentinel mark (X) : Appears when the cash in drawer exceeds a programmed sentinel amount. The sentinel check is performed for the total cash in drawer.
Sep 28, 2016 | Sharp ELECTRONICS CORP. Xe a203 cash...
Sharp XEA22S cash register....will it work without paper....we don't have any thermal paper and the cash drawer will not operate
No it will not. If you have bond (non thermal paper) it will work with that but you will not see any printing on the receipt. If you are still stuck, cut a piece of A4 paper to the width of the printer. Insert it in the printer and press CLEAR (CL). Once the machine accepts it, turn the receipt off and you can operate it without printing. Remember, you can't print end of day reports though. ------------------------------------------------------------------------
If anyone needs more information, the Sharp XE-A22s manual is here: http://the-checkout-tech.com/manuals/cashregisters/Sharp_XE-A22S_instruction_programming_manual.html
Aug 20, 2011 | Casio Parts Cash Register PC Desktop
Hi, How can I use two cash drawers with one Star TSP143 ECO futurePRNT receipt printer. Star support say it can be done 'unofficially'. Therefore they will not say how it can be done! I use the...
Hi Gordon
There are 2 cash drawer circuits in available to be fired using the printer. You may need to purchase an adaptor to use this function or wire the cashdrawes yourself. Please contact support@star-emea.com for further help.
Star Technical Support.
Aug 09, 2011 | Star Micronics TSP100 Thermal Printer
Cash drawe won't open
If the cash drawer doesn't open, what does that have to do with the thermal printer?
Jul 23, 2010 | Epson TM-T88III Thermal Printer
Casio TE-2400 sales transactions
Try this: Turn key to program mode 0 CASH SUBTOTAL 3 SUBTOTAL 0 CASH SUBTOTAL
This should remove the preset amount from the CASH button. Now it should work normally when finishing the sale.
Now turn back to REG mode when entering the price, DO NOT use a decimal, so type 2000 for 20 dollars. Now press a PLU (item) button. SUBTOTAL Type the amount received (NO DECIMAL, so 5000 for 50 dollars) Press CASH Change should be displayed, and drawer open
If anyone needs a manual for a Casio TE-2400 cash register, go here:
http://the-checkout-tech.com/manuals/cashregisters/Casio4.php
Jul 10, 2010 | Casio Parts Cash Register PC Desktop
Printing blank receipt every time cash drawer opens
I would try a complete reinstall to make sure the presets of the machine are correct.
May 27, 2010 | Epson POS TMT88IV Thermal Receipt Printer
I can't get my cash drawer to work is there a secret. I have enabled the cash drawer in digital dining but it won't open
You must be sure the voltage to the cash drawer and the printer are correct. A 24 volt RJ12 printre connection to the solenoid of a 12 volt cash drawer will cause damage. If the drawer was working and stopped, it is possible the solenoid may be the problem.
May 21, 2010 | Epson TM-T88III Thermal Printer
MI THERMAL PRINTER DOESNT OPEN THE CASH DRAWER I CHECKED THE BOXES FOR THIS OPTION I CLICKED APPLY AND ACCEPT AND IT REMOVES THE CHECK MARK FROM THE BOX WHAT DO I NEED TO DO?
I think this printer has a cash drawer open version and a standard non-cash drawer version. Make sure you have the right model of the unit. If the setting on the driver is not "holding" it is likely a user access setting issue (UAC). make sure you have admin privileges. Depending on what type of windows you have it'll be different.
Apr 20, 2010 | Samsung BIXOLON® STP-103 Printer
Cash drawer
Greetings,
From the computer (application to be exact), you send a signal to the printer to kick the drawer open but is there a confirmation signal from the printer going back to the computer that it successfully opened the drawer (not just successfully carried-out the command) ?
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
May 06, 2008 | Epson TM-T88III Thermal Printer
Need a code to fire open the till draw
Hi
The drawer kick sequence we use is
27,112,0,25,250
Mar 31, 2008 | Epson TM-T88III Thermal Printer
Canon BJC 4300 N InkJet Printer Logo
330 people viewed this question
old marine
old marine
