Question about Vehicle Parts & Accessories
I have a popping sound in my back end not sure if universal joint or wheel bearing 2003 grand marquis
    New Friend:
  • 10 Answers
I'd like to try and help with this. Does the sound happen when the car is simply bounced up and down? Does it only happen when it's put in a gear? Does it happen only when driving on a rough road? Can you get a little more detailed as to when it occurs and were on the car? Noises are hard to find but not impossible. Try having someone drive around while you pin-point the sound's location.
Posted on May 10, 2014
I have a 2003 Grand Marquis with a steering problem, When you turn hard to the right the steering seems to float on them shortly after straightening out makes a hard turn right without turning the ste
Immediately take the vehicle out of service until you can repair it! You may have a dangerously worn or cracked tie rod end or ball joint. Jack up the front end, put blocks or jack stands under the frame (but not the moveable parts of the suspension), and manually try to move the suspension parts. If you detect slop at the moveable connections, that's part of the problem. As part of this, rock the wheels back and forth to check for bad ball joints or control arm bushings.
Another possibility is a bad seal or check valve in the power steering actuator.
Feb 10, 2015 | 2003 Mercury Grand Marquis
Is it a bearing or the cv-joint that makes a loud humming sound in the front end when driving at any speed?
ITS PROBABLY TOUR WHEEL BEARING . IF YOUR GOING DOWN THE ROAD AND THE LONGER YOU DRIVE THE LOUDER IT GETS. OR IF YOU TAKE YOUR WHEEL AND GO BACK AND FORTH A LITTLE WHILE MOVING AND THE NOISE COMES AND GOES ITS PROBABLY A BEARING . A CV JOINT WILL POP WHEN TURNING HARD AND ACCELERATING . THIS BEARING PRESSES IN WITH THE HUB ITS A PRETTY DIFFICULT JOB IF YOUR NOT A TECHNICIAN WELL GOOD LUCK
Jan 31, 2011 | 2003 Kia Spectra
Parts and picture to rebuild a 1997 mercure grand marquis front end. ball joint,tie rod ends ect.
I have the book for the 98 and it says to check the corect wheel bearing adjustment first. or you can do what I did and take it to sears and have then do a free check to tell you what you need.
Jul 13, 2010 | 1997 Mercury Grand Marquis
I have a95 jeep grand cherokee with all time 4 wheel drive when i make sharp turns i get a popping sound in front end
have the universal joint's checked on the drive shaft's ans the cv joint's on the axel's also check the transfer case oil
Jun 04, 2010 | 1995 Jeep Grand Cherokee
The car is wobbling in the front end, could it be the ball joints or the wheel bearings? 1992 Mercury Grand Marquis.
hi it could be both but its also worth checking wheel balance also engine mounting rubbers hope this helps please rate this answer
Nov 20, 2009 | 1992 Mercury Grand Marquis
When I turn there is a grating sound, both left and right turns--doesn't happen at low low speeds or on very easy turns. 2003 honda civic
It sounds like the CV joints need some attention. These are covered with rubber boots and if the boots crack they let in water and/or dirt which cause the joints to make a popping or grinding sound. Turn the wheels left or right and look under the car towards the inside of the wheels. The boots are right next to the back of the wheels. Look for cracks in the rubber. If you can, push on the boots and check for small cracks. If they are cracked, have them looked at immediately. The longer they go like that the more damage will be caused. Thanks for using fixya.
Nov 19, 2009 | 2003 Honda Civic
The bolts that hold the drive shaft in the car fell out
here's the illustration with parts and numbers you need. take to dealer parts counter. If the bolts cam out, are you sure the u-joints did not get damaged?
#12 is the bolts
Item Part Number Description 1 — Needle Rollers (Part of 4635) 2 — Grease Seal (Part of 4635) 3 — Bearing Cup (Part of 4635) 4 — Thrust Washer (Part of 4635) 5 — Spider (Part of 4635) 6 4635 Universal Joint 7 4841 Driveshaft Slip Yoke 8 — Snap Ring (8 Req'd) (Part of 4635) 9 4602 Driveshaft 10 4782 Driveshaft Centering Socket Yoke 11 4851 Rear Axle Universal Joint Flange 12 N800574-S100 Bolt (4 Req'd) 13 4635 Universal Joint 14 — End Yoke (Part of 4635) A — Tighten to 93-130 Nm (71-95 Lb-Ft)
Mar 03, 2009 | 1986 Mercury Grand Marquis
Have a chirping sound front left ,wheel went drivin
had a break job lately? it might be the squeakers on break pads telling you its time for breaks. or if its 4 wheel drive could be a CV joint on front axel going bad, or wheel bearing going bad too.
Feb 03, 2009 | 1993 Jeep Grand Cherokee
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
