Question about Kenmore Refrigerators
Kenmore Refrigerators model 106.9555782 ice maker adjustment
Which way do you turn the screw to make ice faster?
5 Suggested Answers
  • 72 Answers
SOURCE: whirlpool refrigerators model number ED22TEXHWOO does not feed ic
YOU COULD HAVE A BAD DOOR SWITCH OR AUGER MOTOR OR THER IS ALLSO THE SWITCH WHEN YOU PUT THE GLASS IN
Posted on Nov 06, 2009
Bat1956
  • 585 Answers
SOURCE: I just replaced the icemaker in my Kenmore
Congratulations, you have very good water pressure. I am not aware of any adjustment for the time the fill solenoid opens. The easiest thing I can suggest is to adjust the water flow with the supply valve. If you have the typical saddle valve, it has quite a taper to the piercing needle, and you could possibly use that to reduce the water flow, thus the volume of the fill. A little trial and error will be needed to find the right number of turns for the valve to be opened. I also recommend a water filter in the line to reduce contaminants, which makes the ice taste better. The filter should be replaced every 6-months or so depending on the amount of impurities.
Posted on Feb 13, 2010
  • 44 Answers
SOURCE: My Kenmore refrigerators (model #79177990) ice
Ice inlet tube may be frozen up inside of Fridge. Thaw it out with a hair blower. Shut of water supply and disconnect the water line that goes into the back. Use a flexable item at the connection to see if will go all the way through to the icemaker. I used a zip tie.
If you still don't have water going to the icemaker, you may need to replace the "Water Inlet Valve" at bottom back right of your Fridge. Easy to Do.
Posted on Jun 06, 2010
  • 1833 Answers
SOURCE: Can the ice maker in
There is a knob which sets freezer temperature. You have to turn this knob to extreme end marked "FREEZER MAX". Then you will be able to make ice cubes faster.
Posted on Sep 01, 2011
My Kenmore refrigerator's ice maker is dripping at the front of the ice maker. it drips slowly but makes a big chunk of ice right at the front of the bucket. What should I do?
This is pretty generic without a model # but holds true with alot of them..this type of icicle is usually caused by water overflowing the ice mold of the ice maker module. The reason for the overflow could be that the ice maker module is not level. Check to see if it is tilting. This could be caused by loose screws or a warping of the liner on the side wall of the freezer.
If the ice maker is level, then the next cause could be that the ice maker is overfilling. There is an adjustment screw on the right side of the front of the ice maker module. You may have to remove the cover from the front of the module to access this screw. Turn the screw counterclockwise to decrease the water fill. Turning this screw one turn may decrease the water fill level in the mold enough to prevent the leaking. If not, you may need to make a second adjustment.
Other problems that could cause this icicle could include:
Wicking of the water over the top of the ice maker mold caused by hard water deposits in the mold.
Leaking of the ice maker water solenoid valve.
Crack or leak in the ice maker module.
If the module is level and decreasing the water fill level does not solve your ice maker problem, then I recommend checking the ice mold for hard water deposits. If you find no deposits in the mold (or clean them and still have the same problem), then you will probably need a service technician to fix the ice maker. if you need more help, re-submit your question with additional details.
or reply in comments.
Jan 02, 2018 | Kenmore Refrigerators
The ice maker overflows the ice tray, so water runs down the side of my freezer.
if it has worked for 3 years then I would guess just a new tray
Feb 18, 2015 | Kenmore Refrigerators
I have a 10 year old, at least Kenmore ice maker overflowing into the ice chest. No obvious adjuster.
Can you locate the Kenmore Model Number? It will look like this=> 321.654987 What I think is the dual water control valve is leaking once it turns off. Here below is a ice a ice maker repair clip on You-Tube where he shows a slug of ice filling the ice maker fill tube. In most cases replacing the water control valve will stop the continued water flow to the ice maker once the ice maker fills. I will be here to answer any questions you have Thanks Sea Breeze
Apr 15, 2013 | Refrigerators
I have a Kenmore Elite side-by-sr ide refrigerator Model 106. The ice making system is putting too much water in the ice tray, making the cubes too big. These large cubes are clogging up the dispenser. ...
With out the full model number it is hard to say. Most 106 model referigators have a modular ice maker. If you take the cover off of the front of the ice maker and look on the right hand side of the motor module you will notice a small plastic adjustment screw. If you turn this screw you can adjust your water fill time to the ice maker.
Sep 01, 2011 | Kenmore Refrigerators
I have an amana side by side model # JXD2252L. The ice maker is adding too much water at the beginning of the cycle and is dripping water into th ice bucket. It freezes and casues the ice dispenser to...
Adjusting Ice Maker Fill
Use a flat-head screwdriver to remove the screws on the ice maker's front access panel, and then remove the panel.
  • Locate the adjustment screw, located about mid-point on the side of the ice maker. Do not turn the crew more than one full turn in either direction.
  • Turn the screw clockwise ½ turn to decrease the water fill level.
  • Turn the screw counterclockwise ½ turn to increase the water fill level.
  • Close the access panel and restore the screws. Turn the refrigerator back on.
  • bobicehouse_20.jpg Look at mid point for adjusting screw
    Jul 10, 2011 | Amana ACD2232HR Side by Side Refrigerator
    Ice maker not filling up with enough water
    Remove White plastic cover. On right front side you will see an adjustment screw with + and - .Turn only 1/4/turn at a time.
    Apr 30, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
    Ice maker quesiton
    There is a screw with a spring around it. This adjust the amount of water that goes in. There is a cycle thermostat but its not adjustable.
    Aug 10, 2009 | Whirlpool Refrigerators
    Ice maker is making hollow ice cubes, some only half frozen
    Most ice makers have an adjustment screw to control the cube size. Its usually hidden behind a plastic panel on the front of the ice maker. A quarter turn either way and some trial and error testing should get you pointed in the right direction to your ideal ice cube.
    Nov 05, 2008 | Kenmore 53642 / 53644 Side by Side...
    Ice maker # S10626636 water level adjustment
    IF THE ICE MAKER IS OVERFLOWING, THE ADJUSTMENT SCREW WON'T HELP. ON MODULAR ICE MAKERS, THE BIG
    WHITE GEAR ON THE FRONT BEHIND THE COVER HAS CIRCUIT TRACES ON ITS BACKSIDE THAT WILL ARC, BURNING THE PLASTIC GEAR, BRIDGING THE FILL CIRCUIT WITH ANOTHER TRACE, MORE THAN DOUBLING THE FILL TIME. THE MODULE NEEDS TO BE REPLACED. (GEAR IS NOT AVAILABLE BY ITSELF).THE MODULE IS THE SQUARE PLASTIC ASSEMBLY MOUNTED TO THE FRONT OF THE ICE MAKER WITH THREE SCREWS. INCLUDES THE MOTOR.
    Mar 27, 2008 | Kenmore 53552 / 53554 / 53559
    Refrigerators Logo
    Top Kenmore Refrigerators Experts
    Sal De
    Jim Goldsmith
    Jim Goldsmith
    oldblindman
    Level 1 Expert
    Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
