Question about Kenmore 25512/ 25513 Progressive Canister Vacuum
Kenmore floor mode not working but carpet mode is
2 Suggested Answers
  • 1214 Answers
SOURCE: Kenmore Vacuum 116.36623501 does not stay on bare floor setting
It sounds like there is something wrong with the latching assembly. GO to the Sears Parts website and enter your Model number. Look at the parts assembly for the Nozzle, and the problem will be in one of items 12 through 17.
Posted on Jan 15, 2009
Why does my eureka air speed vacuum not work when in floor mode?
There is an adjustment for carpet and for hard surfaces. Have switched it from carpet to a hard surface. When on carpet it sets up higher on a hard surface it should set lower. If it is to low it work properly either.
Oct 16, 2016 | Eureka Vacuums
How do I use kenmore evo carpet cleaner?
lost instruction on how to use kenmore evo carpet cleaner
Jun 14, 2010 | Kenmore EVO All Surface Floor Cleaner...
My brush bar won't turn - works in bare floor mode, but carpet brush won't turn when it should...
replace the belt the belt sounds like its worn or stretched the belts turn at high rpms and get very hot and soon just ware out they work fine on floors but when it comes to carpet they slow down, i hope this works out thanks
Nov 30, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
The vacuum works on carpet mode but not floor and only when the wand is attached to the floor brush otherwise it does not work at all
Please define "works" on carpet mode" do you mean when you say it does not work at all, that it does not run, or does not have suction.
This sounds like the symptom of a clogged hose with blockage like this another vac needs to be used to draw things back out of the hose the way they went in.. Remove the hose and try dropping a penny through it . If there is an obstruction the penny will stop at that point and rattle inside the hose.
With a blockage at the hose, your power head will still lift lint and light soft dust, it will appear to have suction because the brush will sweep but the dirt will not go all the way through the hose.
Please post back to clarify if this is a vac that does not run or simpley has no suction
Nov 04, 2009 | Kenmore 25614 / 25615 Progressive Bagged...
Dec 27, 2008 | Kenmore 25512/ 25513 Progressive Canister...
On/Off switch.
because floor means for lanolium it may have a sensor that detects carpet or linolium
Feb 11, 2008 | Kenmore 35821 Vacuum
My vacuum kenmore canister smells
My guess would be a slightly loose belt - tight enough to spin the roller on a hard floor, but loose enough to slip (then get hot and stink) when the roller is having to work against the pile of a carpet. Worth buying and fitting a new belt without pausing to investigate further, simply because they're so cheap and you'll have to replace it sooner or later anyway. A.
May 16, 2007 | Kenmore 23612 Progressive PowerMate Bagged...
Kenmore 25512/ 25513 Progressive Canister Vacuum Logo
52 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
