Question about Hampton Bay 24002 Ceiling Fan
How do i remove glass golbe on model #48-bb so i can change a light bulb?
2 Suggested Answers
alex_salve
  • 78 Answers
SOURCE: How do i remove the light to change a light bulb?
turn thr glass clockwise to open.
Posted on May 25, 2009
How do I change the bulb inside the cooker of the B5741 cooker
Oven Lighting
Warning: There is a danger of electric shock! Prior to changing
the oven light bulb:
  • Switch off the oven!
  • Disconnect from the electricity supply.
Place a cloth on the oven floor to protect the oven light and glass cover.
Replacing the oven light bulb/cleaning the glass cover
  1. Remove the glass cover by turning it anticlockwise and then clean it.
  2. If necessary:
Replace bulb with a 40 watt, 230 V, 300 °C heat-resistant
oven light bulb.
3. Refit the glass cover.
Dado
Apr 15, 2015 | AEG Ovens
HOW TO REPLACE THE LIGHT BULB IN MY OVEN
Oven Lighting
Warning: Risk of electric shock! Prior to changing the oven light bulb:
- Switch off the oven!
- Disconnect from the electricity supply.
Changing the oven light bulb/cleaning the glass cover
1.Remove the glass cover by turning it anti-clockwise and then clean it.
2.If necessary: replace with 25 watt, 230 V, 300 °C heat-resistant oven lighting.
3.Refit the glass cover.
24472822-skr3uzd4ii43xzwyhmpsswym-3-0.jpg Dado
May 21, 2014 | Electrolux EOB5665G Ultrafan Electric...
Change indicator bulb in Volvo V70 wing mirror
Easy peasy. Adjust mirror fully one direction or the other, right or left. Grab mirror glass through the gap created, pull hard to remove mirror glass. Light bulb assembly will be exposed for simple swap. Use a #194 bulb of your choice (there are many choices at your favorite local auto parts dealer). SELECT YOUR CAR
Good luck, should take five minutes or less.
Mar 19, 2014 | Volvo V70 Cars & Trucks
I need to change the interior light bulb in my Frigidaire over the counter microwave. The model # is FMV156DCA.
Good Morning Evelyn, thank you for allowing me to assist you!
Here are some simple troubleshooting tips to help replace the light bulb on your Frigidaire microwave, FMV156DCA.
    ·First, disconnect power to your microwave. This can be done by either unplugging it or at the circuit breaker panel.
    ·To release cover, remove the screw on the light cover (light cover may become very hot, do not touch glass when light is on).
    ·Remove old light bulb and replace only with equivalent watt bulb available from parts distributor or the manufacturer directly. Bulbs are also available at most hardware stores or lighting centers. Bulbs larger than 30 watts are NOT recommended.
    ·Close light cover and secure with screw removed in step 2.
    I hope this information proves to be helpful. If you have further questions, please do not hesitate to reconnect.
Nov 25, 2013 | Frigidaire FMV156DC Microwave Oven
Portable Cabinet Light, Model DCMS-10. How do you change out the halogen bulb?
most fixed halogen bulb units are either held in place with a spring around the glass or a pop tab ring around the glass, these should be carefully pried away leaving the glass to fall out, once the glass is out then bulb replacement can be achieved, remember not to touch the halogen bulb replacement with your bare fingers, use a tissue or similar as the natural oils on our skin can cause a bulb to fail prematurely refitting is a reversal of removal
Sep 21, 2012 | Cars & Trucks
How do you remove the light bulb cover in a fivestar 48
You remove your incandescent light bulb and insert your automotive LED light bulb.The LED lights cover the landscape area for people to be able to see.
home light bulbs
May 28, 2012 | Five Star FiveStar 48'' Range Hood -...
Burned out light on bertazzoni hood
Here is how I fix this problem in case someon is still looking for an answer: 1. Turn power to hood off at electric panel 2. Remove light diffusers - these are the round glasses under hood covering the light bulbs. Turn the light diffuser counter clock wise to remove 3. Remove the burned out light bulbs 4. Install the new light bulbs
Jan 05, 2012 | Bertazzoni K48HERX 48" Kitchen Hood
How to change the light
There are three different models... two wall models (the WL24 and the WL36) and an island model (the IS24). The instructions for changing the lights on all three models are the same.
Light bulb:
  • Make sure your hood is disconnected from the main power supply.
  • You may see a screw at the edge of the light cover. Unscrew it and remove the light cover.
  • Replace the light bulb with the same model as the original. There may be a decal near the bulb that indicates its rating. Don't exceed 25 watts! It's best to bring the old bulb to your store to have it replaced exactly.
Spotlight:
  • If you don't see a screw, then - using a screwdriver - lever the support ring, then grasp it & pull it straight down and off. This ring supports the glass cover - remove it as well (don't drop it!).
  • Replace the lamp with the same type (12V, 20W, G4 fitting).
  • Replace the glass cover and the support ring - it should snap back in.
Fluorescent light:
  • This needs to be changed by a qualified installer. Don't attempt it yourself.
Mar 02, 2011 | Futuro Altair Kitchen Hood
How do I change the light bulb in the oven
You can replace the light bulb(s) in your range/oven, though you may need to remove a glass covering or dome to reach it. Most interior oven lights use a universal 40 watt appliance bulb.
Apr 24, 2009 | Philips Ovens
Hampton Bay 24002 Ceiling Fan Logo
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
