Question about Kodak EasyShare M853 Digital Camera
Pinkish screen with horizonal lines running through it.
Just happened to screen one day and trying to figure out if it's a setting issue or if the camera needs to be repaired/replaced. Any advice would be great!
  • oats3000 Jun 22, 2009
    I figured it was time for a new camera. Thanks
That happened to me once. It's the inner lens, I think. Unfortunately there's no other way to fix it than to get it replaced.
Posted on Jun 22, 2009
My Mitsubishi Projection TV Model WD-62525 screen has pinkish lines running through the screen. The lamp has been replaced. What could it be?
not the lamp. Its a known issue with the power supply. Bad capacitors usually. this requires a servicer to repair it.
Sep 17, 2015 | Mitsubishi WD Televison & Video
What causes a black screen to have a pinkish tinge with visible lines on a cathode ray sony kd34xbr960n? And what might it cost to repair?
The video output section circuits has the fault. Might be a a video output transistor short. Type {Electro-help} in your search box and enter this site. It has all details.
Jun 08, 2012 | Sony FD Trinitron KD-34XBR960 34" TV
MY LAPTOP WONT GO ON AND THE BATTERY HAS A PINKISH LIGHT
The battery has a pinkish light or the laptop screen has a pinkish light? When the screen has a red or pinkish tint to it, and is black still, it is the LCD inverter that is the problem. The computer and the LCD screen work fine but you need to change the inverter. It happens very often and you can find inverters for your specific laptop online and certainly on eBay.
Apr 02, 2010 | Computers & Internet
Horizonal lines
Unfortunately you can't.
This is what happens when you blow pixels on your monitor.
If it is still in warranty this will be covered.
If you are outside of your warranty then you will need a new monitor
Sep 26, 2009 | Acer AL1916W 19" LCD Monitor
My older Toshiba TV is showing horizonal lines on upper screen.
maybe dust in the back of set try giving it a hoover out but unplug first
Mar 19, 2009 | Toshiba Televison & Video
Horizontal lines across TV screen Panasonic CT-31SF13U
The problem sounds like a vertical deflection issue form what you describe.
On average they are usually in the simple repair categories. On average they would run in the $50 range if you take it to a reputable repair shop.
There are several possibilities
Bad capacitor (s)
Bad vertical IC
resistor in the power supply to the vertical circuit changing value
Jan 24, 2009 | Zenith B25A10Z 25" TV
Screen has red lines
try to reset default setting on monitor
Jan 09, 2008 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Horizonal problem
Practice visual acuity technique! Examine chassis,solder any/all bad connects,re-assemble,try again.If that does not do it,you might have a small break in pcb==gently flex board,try to isolate area.Above all else,do no harm!!
Sep 26, 2007 | Hitachi C3390FSP 33" TV
Philips 28PW6515-05 flat screen TV
You have a bad connection on the CRT board thats mounted on the end of the picture tube it sounds like, or the socket on that board that plugs into the TV set is intermittant or has a bad solder connection on it. Good Luck
Mar 27, 2007 | Philips 28PW6506 28" TV
Kodak EasyShare M853 Digital Camera Logo
139 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
