Carrier model 38tda036 shows error code 6 - Heating & Cooling
2 Suggested Answers
SOURCE: ERROR CODE 5 FLASHES CARRIER SPLIT SYST. AIR COND. 42G250HP-1
5 flashing is ' compressor drive' and check the high pressure, condenser fan motor capacitor for proper running
Posted on May 21, 2010
Carrier Comfort Zone II Thermostat is blank and the 3 companion thermostats are all showing Error Code C1. What does that mean?
Hi Anonymous,
For all wall mounted and Artcool split system codes
Error code = C1 or CH1
Flashing Light = 1
Fault = Indoor temperature sensor open or closedcircuit.
Display = Indoor.
Indoor Operation = ON
Error code = C2 or CH2
Flashing Light = 2
Fault = Outdoor temperature sensor open orclosed circuit.
Display = Indoor Outdoor.
Feb 14, 2015 | Carrier Heating & Cooling
Hi dear can you please please help me my fone is locked asking me for lock code I put my old lock code it shows error . My IMI 356406020731484
i think ur phone is Nokia N-96 if correct pl reload ur firmware ur problem is solved or send my address or contact me
Jul 18, 2014 | Cell Phones
My Lexmark printer shows EC1 on it, what does that mean and what do I do ?
The EC1 error code means "Incorrect Printhead". Try to follow the steps below to identify and fix the issue:
1. Make sure the printer is on.
2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
3. Remove both cartridges from the carrier.
4. Close the printer cover.
5. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge.
Aug 31, 2011 | Lexmark X2600 InkJet Printer
I have a 15 ton carrier gas pack at work with inducer motor and spark igniter with hall senser ..showed error 6 flashes on igc board which the drawing said was inducer motor or hall senser...
The error code is always right. Sometimes misleading, but in 15+ yrs I've seen, always right. I'm not familiar with a Hall Sensor. If this is a remote sensor, as in a remote location that senses in the hall and not at the tstat then I know what you're calling a hall sensor. Make sure your IDM is working and closing the air proving switch. And that no other safeties are in that circuit. Check continuity to the remote sensor wiring and all connections? I've seen hot surface ignitors look fine and not work, but pulled a new off the truck and the new worked. All else fails, remote sensors are tough to get a good ohm value due to a temp difference affecting the ohms, replace it. I'm not sure why your "drawing" would relate the IDM to a remote sensor so I'd focus on the IDM and follow the voltage trail.
Apr 03, 2017 | Carrier Heating & Cooling
Does not ignite error code flashes 6 times
Look on the reverse side of the removable front panel of the Carrier. Each model will have a wiring diagram and a diagnostic chart to help you pin point the issue. Without knowing the model number the error code means something different for each model.
Nov 20, 2010 | Carrier Heating & Cooling
Model 30gx faults code
Hi, the indoor chiller unit blower section will have a sheet glued to a panel on the unit that will tell you where and what the code 302 means on the unit. Then you will be able to make the repairs you kneed.
Shastalaker7
PS the numbers above show that this is a 3 ton unit, 38CKC036. The error code more than likely will be 3 flashes from the board followed by 02 flashes. I may be wrong on that , so correct me if I am.
Mar 16, 2010 | Carrier 38CKC036 Air Conditioner
Mar 10, 2010 | Carrier Heating & Cooling
Carrier Thermidistat TSTATCCPRH01-B E6 error
Bring it back to a Totaline store and get a replacement. If you just bought it, it is in warranty.
Oct 17, 2009 | Kitchen Appliances - Others
Carrier Air Conditioning error code 5
Carrier A/C split Model # 38KCL112313GP has error code E1 What is that?
Aug 09, 2009 | Carrier Heating & Cooling
Lexmark X5495,Error 1203, Says Clear Carrier Jam
Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds, then reinsert the power supply and power the AIO on.
Did the error message return?
Yes: Continue to step 2.
No: Print a test page. If the test page prints, the error is resolved.
2 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit. 3 Remove both cartridges from the AIO. Close the top cover, reinsert the power supply, and power the All-In-One (AIO) on.
Yes: There is a hardware problem with the printer. Continue to Contacting Lexmark.
No: Continue to Step 4.
4 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit. 5 Insert the color cartridge. Close the top cover, reinsert the power supply, and power the AIO on.
Yes: Continue to Cleaning the Cartridge Contacts, then repeat steps 4 and 5. If you have already tried cleaning the contacts, continue to Defective Cartridge Test.
No: Continue to step 6.
6 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit. 7 Insert the black cartridge. Close the top cover, reinsert the power supply and power the AIO on.
Yes: Continue to Cleaning the Cartridge Contacts, then repeat steps 6 and 7. If you have already tried cleaning the contacts, skip to Defective Cartridge Test.
Apr 15, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
