Question about Craftsman 20 hp 42 in. Deck Yard Tractor
944.609890 blade part number
Have a Murray rider model # 465306X8b need to replace blades. What blade manufacturers make a replacement blade and what would be their part numbers ? Thanks , Bruce
The part number for the blades is: 056631E701MA
I referenced it here. Unfortunately, this online vendor lists the blades as unavailable. You will just have to get all the dimensions on them and compare shop. Here is the deck parts:
http://www.partstree.com/parts/?lc=murray&mn=465306x8B+-+Lawn+Tractor+%282005%29&dn=11192
Manufacturers like Stens and Oregon and others make blades. It would help if I knew what size they were. Compare YOUR blades to the ones listed here.
http://www.agrisupply.com/murray/c/6000108/c2c/sc/
Jul 12, 2011 | Murray 46 Primary Lawn Mower Blade Belt...
I bought a homelite curb runner and need to replace the blade. The problem is I cannot find the blades anywhere. Any ideas?
I found that your electric edger blade is rounded on the ends. I did not find a part number for it. I also found a site that has about 30 or more Homelite edger blades listed, but again, with half of them without pictures, I can't give you the edger blade part number. But, if you have removed the blade and can measure all the dimensions of the blade, then you can match it up with one from this site.They have more blades than other sites I checked. It should not be too hard as each blade listed has the critical dimensions listed with it. I wish you good luck.
http://www.mowtownusa.com/42.html?m5:search[keyword]=Edger%20Blade;search[keywordSearchType]=and;search[matchWholeWords]=1;search[keywordFields]=string0:text2:text0:code;search[active]=yes;search[fuzzy_sku]=1
Jun 19, 2011 | Garden
How do I remove the blade of my SR4
This is from the Toro owners manual for SR4 euper recycler model 20058 serial number 250003464
The steps and picture are on page 18 of the manual 3352-864[1].pdf
You can enter those numbers on this page for a manual:
https://lookup3.toro.com/request/request.cfm
1. Disconnect the spark plug wire from the spark
plug. Refer to Preparing for Maintenance
2. Tip the mower onto its side with the air filter up.
3. Remove the
2 blade nuts (A)
and the
stiffener (B).
4. Remove the
blade (C).
5. Install the blade and the stiffener that you
removed in steps 3 and 4.
6. Install the blade bolts and torque them to 15 to
27 ft-lb (20 to 37 N?m).
The replacement blade part number is:
108-3762-03 (google / net search)
Thanks for choosing FixYa,
Kelly
May 20, 2011 | Toro Power Lawn Mower
Blade number for Ariens Zero Turn Model 1840. Need
Depending on which version of the 1840 you have and when it was built it could be several blades...
Please get your model and serial number and then enter them into the following site's search engine. You should then be able to identify the parts you need.
http://partsradar.arinet.com/scripts/EmpartISAPI.dll?MF&app=ariens&lang=EN&TF=Empartweb&loginID=ariensc&loginpwd=consumer
John
Jan 18, 2011 | Ariens Zoom 42 In 165 HP Briggs Stratton...
Planer no. kw715 spare blades black and decker please supply
The replacement blades for a Black and Decker KW715 portable planer are Black and Decker part number X24192. It looks like there are a number available on Ebay.co.uk at the moment.
There are also third party replacements for these blades. Trend PB/29 blades should work as well.
If this answer was useful, please vote for it. Thanks!
Jun 14, 2010 | Black & Decker Tools & Hardware - Others
Ninja blade game serial number
If you mean the Ninja Blade game that is a product of IGN you will have to buy the game to get a serial number.
Apr 25, 2010 | Dell Latitude D600 Notebook
How to see if a used snow plow blade will fit my craftsman tractr
Underneath the hood of your tractor is a silver sticker with the sears item number for the correct snowblade. If its a craftsman snowblade it should have a meteal label on it with its model number the 5 numbers after the period need to be the same with what was under your hood to make it the correct blade
Nov 12, 2009 | Craftsman 16" High Garden Tractor Snow and...
I wish to know if I can purchase new blades for my hedge trimmer model number 900.799740 . Can I replace blade with 22 inch or longer size? Can original blade be sharpened? What new model is compatable?
Go to www.partsdirect.com, this is sears website for parts. You should be able to find the part number for a new blade.
If the blade has bolts and nuts holding the blade together it can be sharpened. If it is riveted together, it can be but it is more work than what it is worth.
Sep 25, 2009 | Craftsman Garden
Gardenline mower
What sort of blades does this gardenline mower product number 8846 take? Is it 4 blades and how many?
Sep 25, 2009 | Garden
Craftsman 20 hp 42 in. Deck Yard Tractor Logo
76 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
