Question about Kenmore Washing Machines
My kenmore 90 series washer model has a slow or no spin
The model # is 110.24932201, s/n CR0932202 and it aggitates fine and seems to go through the cycles. Clothes are wet @ the end of the spin cycle. I will not spin with a small amount of clothes when empty it will spin and slowly work up to a good speed but I can place my hand on the side of the drum and stop it. I replaced the coupler about 8-10 months ago and since it aggitates and I cannot stop it by hand I think the coupler is good, the motor is good and I think the timer is good. I checked for obstructions in the pump and drain lines but did not see anything. Any adice would be much appreciated. I have provided my email below. Thanks,
Scott, scott.swaim@gmail.com
  • 97 Answers
Hello Friend, Your solution is very simple. You need to replace the clutch assymbly. It's easy to replace the clutch assymbly on your machine. First, pop the cover off the top of your agitator and remove the bolt that holds it in place. Gently pull the agitator up and out of the machine. Now, remove the two screws that hold control panel in place and tilt back exposing the two metal clips that hold the cabinet in place. You will see some wires plugged into the cabinet, just unplug them. There are two clips, one on each side. Just pop these clips off and lift cabinet slightly from back and tilt forward. At this point you will be able to completely remove the cabinet. Once you have cabinet removed just set it aside. Now, just lay the washer on it's back. At this point you will see the water pump, motor, and transmission. Remove the pump by snapping off the two spring clips. The pump will slide right off the motor shaft. Now, remove the two screws that hold the two spring clips attached to motor. Unplug all the wires etc. and then snap the metal clips off motor. Lift motor straight up, it should slide right off. Now you will see three bolts holding the transmission in place, just remove these three bolts. Now, gently pull the transmission out of the washer and sit it in an upright possition. At this point you will see the clutch assymbly on the top of the transmission with the agitator shaft going through it. There is a spring clip holding the clutch in place be sure to wear eye protection. Just pop this spring out and remove the entire clutch and replace with new clutch assymbly. Re-assymble the washer and the problem you are encountering should be solved. Happy to help, Tim.
Posted on Jun 26, 2009
Kenmore 90 Series Washer
CHANGE THE LID SWITCH
Apr 18, 2009 | Washing Machines
Kenmore 90 series noise after spin
You need to replace the drive block and basket drive. You can download a tutorial to get you started at www.shop.washermd.com. The gearcase replacement tutorial will put you in the right direction. Dave
Mar 01, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Spin Cycle Works Some
you have a broken coupler...this is a plastic and rubber part that connects the motor to the transmission.  A $20 part
Jan 24, 2009 | Kenmore 15864/15862 Top Load Washer
Aggitator won't work and won't spin/ drains ok
Coupling is bad.
There is a coupling between the motor and the transmission. When this part breaks then it will pump the water out but won't spin or aggitate.
Jan 18, 2009 | Kenmore 15944 Top Load Washer
You have a broken lid switch. Its # ll in the diagram. Part # is 3949238. Let me know if you need info on how to replace it, Dave www.washermd.com
Dec 17, 2008 | Kenmore 23822 Top Load Washer
Kenmore 90 series slow spin
You need a repairperson. It is probably a belt or a switch problem.
Jul 29, 2008 | Kenmore 22422 Top Load Washer
Kenmore electronic 90 series washer
easy easy you need agitator dogs thats right the official name of the part is agitator dogs! 5 dollar part can chat you through the fix
Mar 25, 2008 | Kenmore 22422 Top Load Washer
Kenmore 90 Series Washer has slow spin cycle
Washing machine won't spin, seems locked up, when i turn the spin cycle on you can hear the machine trying to spin but it won't budge....... any suggestions???
Dec 19, 2007 | Washing Machines
Yes the brakes are grabbing too hard....I will sometimes lubricate them....Or replace the basket drive assy. You do know how to take the cabinet off i take it??
Oct 02, 2007 | Washing Machines
Washing Machines Logo
83 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
