Question about Philips Audio Players & Recorders
Philips pocket memo LFH 9730
Not charging
  • 207 Answers
Hello I don't recognize that model may be you try to say Philips Digital Pocket Memo LFH9370.
Your unit charges two ways via power supply direct on the portable or via docking station, make sure you have the proper rechargeable batteries you must have the LFH9154 if you don't have this batteries you can buy them on the next link http://www.tvps.com/Products/Philips-LFH9154-AAA-NiMH-Rechargeable-Batteries---New-9154__PH-LFH9154.aspx
Posted on May 08, 2014
  • 61 Answers
SOURCE: I have an old Philips Professional Pocket Memo 398
At the end of the recorded part of the tape, hold in the RECORD button and pull the 4-way slider down into
REWIND position. Hold both until tape is fully re-wound.
Posted on Apr 25, 2010
  • 61 Answers
SOURCE: LFH 720 - Does it record?
This machine is a playback-only model. You will need a hand-held recorder using Philips mini-cassettes.
  • 61 Answers
SOURCE: Philips Pocket Memo 398 dictation machine - spindles not turning
Most likely cause here is a broken drive belt. This machine is at least ten years old. The belts for the latest model (381) will fit, but it's a tricky job to fit.
Posted on May 17, 2010
  • 61 Answers
SOURCE: can't get a playback of dictation
Download it from www.dictation.philips.com.
adnanbhatti
  • 1188 Answers
SOURCE: Where is the on/off switch for teh Philips 9350
Move teh 4-position switch to the stop position and push back the movable center part of the cap.This locks the 4-position switch and the device switches off.
MANUAL
Posted on Sep 29, 2010
How do I restore a deleted recording?
It's a digital recorder, right? And I think the lost audios were initially stored in the memory card. In this case, you may need a data recovery program on your computer. Feel free to give this one a try if you're a Mac user. Recover Digital Photo Music and Video on Mac OS
Oct 30, 2014 | Philips LFH9600 Digital Pocket Memo with...
The philips LFH9600 dictations are going back to the beginning
There is a minus and plus button under the menu button. If she rests her thumb on the minus button it will skip backwards. This will also cause lost dictation because it will skip back without knowing about it and you can dictate over what is there.
Jul 10, 2013 | Philips LFH9600 Digital Pocket Memo with...
Philips device won't recognize when docked.
Remove cable from the docking station and plug it directly in to the LFH9600
dictaphone if the system communicated it is possible that the docking station is bad.
Jul 17, 2012 | Philips LFH9600 Digital Pocket Memo with...
Tengo una grabadora digital RR-US395 Voice Editing ver 1.0 pero el CD no me funciona con win 7. que puedo hacer
Hola que tal, desafortunadamente hasta donde yo sé Panasonic no ha actualizado Drivers para Windows 7 desafortunada mente así pasa a veces, en realidad té recomiendo que si vas a invertir en otro equipo consideres tus opciones ya que la verdad es mejor una grabadora de voz profesional y de una Marca líder en el ramo de las grabaciones como Olympus Philips o Dictaphone normalmente cada que sale un sistema operativo nuevo se actualizan muy pronto con el asunto de los drivers yo te recomiendo esta grabadora por su precio creo que vale la pena cada dólar http://www.tvps.com/Products/Philips-9380-Pocket-Memo-Digital-Recorder---New-LFH-9380__PH-LFH-9380.aspx
Apr 16, 2011 | Panasonic RR-US395 Digital Voice Recorder
Our 9500 series Philips digital pocket memo will not clear the old files when complete. As a result, we are unable to download new files. Any help would be appreciated. Thanks! Jill
Hello You need to Use Philips SpeechExec software for automatic
download, conversion and routing of files
recorded with a Pocket Memo dictation
recorder. How and which files are downloaded after a
recorder is connected can be configured in
the settings menu of SpeechExec or with the Configuration Wizard
Configure the download process
from the Pocket Memo
Pocket Memo is connected can be configured in
the settings menu or the Configuration Wizard.
1 Connect the Digital Pocket Memo to the PC
using the USB cable.
2 Click Settings > General Settings on the
menu bar, select DPM/DT Configuration >
DPM Settings from the list on the left side.
3 Click the Start... button. The DPM configuration
dialog is displayed in a new window.
4 Select Download in the left pane.
5 Select which files will be downloaded
(download file type):
• All files
• EOL (recordings marked as finished/endof-
letter)
• File selection (SpeechExec prompts the
selection of specific files to be downloaded)
• File with keyword 1 (specify a keyword)
6 The download settings also allow the user
to specify if files will be deleted on the
Pocket Memo after they are downloaded.
7 Click OK to save the settings and confirm
the transfer of the new settings to the
Pocket Memo.
Apr 05, 2011 | Philips Pocket Memo 9500 (256 MB 1 Hours)...
Oct 13, 2009 | Philips LFH-720
Mar 25, 2009 | Philips Audio Players & Recorders
143 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
