Question about Lindhaus Vacuums
Roller brush not turning
Does the vacuum have a belt that needs replacing or does this require a repairman?
Buffalo12980
  • 625 Answers
SOURCE: hoover windtunnel U6439900
please go to the hoover vac store using the following link. you will have your exploded diagram for the machine and any spare parts you might need. http://www.thehooverstore.com/U6425.html
Posted on Sep 15, 2007
reddevil6
  • 1673 Answers
SOURCE: Hoover Wind tunnel V2
Either the brush rolls are bad, ends are bad, or the gear housing/motor asm. is bad and will have to be replaced. ee84874.jpg
Posted on Jan 29, 2008
SOURCE: Bissell Lift Off Broken Belt and Brush Roller
I had the same problem. I found that the brush actually melted to the end cap (the one with the square/ovalish end). I was able to pull it off with some force and applied some WD-40, but that only worked for one more use. The brush has again melted to the end cap and it is too deformed to try and fix. I suppose I will have to search for a new brush, but this model obviously has some innate flaws.
Posted on Dec 06, 2008
SOURCE: How do you put a Hoover runabout belt on vacuum
I found this on another site and it worked for me. RonL
Looking at the brush, remove the two screws from the black plate holding the brush. There are two clips that holds this plate once you remove the screws. This should be easy to remove with a flat type screw driver. Now is the tricky part to remove the top cover of the vacuum so you can access the compartment to put the belt on. The whole top part of this vacuum comes off. If you look above the part where black plate was, there are two more clips on the top left and top right hand corner. These two hold one end of the top cover. It is not as simple as pushing the clip to one end to slide out. You have to find a gap between the edge of top cover and bottom structure(right next to each clip) and shove the flat screw driver in and push the top cover away from the bottom structure and push down the top cover. You will notice that there are invisible hinges between the two which locks in the top cover.
Do the same procedure for the bottom right and left edges(right next to each end of the brush) of the vacuum and separate the two(bottom structure and top cover) out using the flat type screw driver..
Posted on Feb 02, 2009
  • 75 Answers
SOURCE: roller brush of my dyson dc07 isn't turning...
it migh be the belt.check your belt or it is the brushroll is stuck.(from to much hair ect.)
Posted on Jun 30, 2009
How to fix vacuum roller bar?
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuum's belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Bissell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Apr 01, 2017 | Vacuums
Brush won't spin on hoover wind tunnel bag less upright when on carpet, belts are fine
The belts may look fine but may be stretched and worn. Replace them. Make sure brush spins free. Idler pulley should tighten belt tension when handle is released
Jul 25, 2014 | Hoover U6630-900 WindTunnel Bagless...
I got a cord wrapped around the roller brush and after removing it the roller brush won't turn.
should have smelt a rubber smell at the same time. The rubber belt probably melted in half. Just flip vacuum over so you can see the bottom. look for arrows pointing to clips or screws. Usually requires removing one panel and the brush. Buy new belt (look on vacuum for correct size or take make and model and name to the store). Just reinstall, replace brush and cover and screws and your all good.
Feb 15, 2011 | Electrolux 5740 Upright Vacuum
Lost manual on vacum need to replace belt
Remove the bottom cover of the sweeper head, then remove the brush roller along with the belt if still there. Clean the brush end-bearings--the roller ends and the interior of the bushings. Then oil the bearings lightly with 3-1 oil or similar. Place the new belt over the roller and the motor shaft adding any required belt twist (diagram on the casting), then seat the roller and bearings as a unit. Replace the cover and test the roller for running. Hope this helps!
Oct 08, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
Describe how to replace belt on hoover windtunnel bagless
If you turn the vacuum so the bottom is facing up you will see the base plate that covers the roller brush. There will be four screws (usually phillips head), remove the screws and the base plate will lift off. You now have access to the roller brush and belt. Lift the roller brush up and remove the old belt. Place one end of the new belt over the motor shaft and the other end over the roller brush and put the roller brush back in place. Now simply replace the base plate and you're done! This models requires Hoover belt # 38528033 (single) or Hoover belt #40201160 (2 pack). You can get this belt at www.vacbelts.com.
Here's the pages:
http://www.vacbelts.com/hoover-40201160-belt.htm
http://www.vacbelts.com/hoover-38528033-belt.htm
Oct 15, 2009 | Hoover U5750-900 WindTunnel Bagless...
Brushes won't spin
Remove the bottom plate and check the drive belt from the motor to the brush roller--if the belt is broken or damaged, replace it. You need to remove the brush roller from the frame to put the new belt on--make sure to make a half-turn twist of the new belt in the correct direction if required. Also, remove the end bearings from the roller and clean all the accumulated thread, hair, and other debris from the roller ends and bearings. Replace the bearings as they came off, because some are not symmetrical.
Aug 16, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Roller brush of my dyson dc07 isn't turning...
Jun 29, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
When I sart to run my bagless vacuum, it runs for a second and then shuts off. I replaced the belt and the filter. The repairman told me that on bagless vaccuums, the motor and bearings get clogged w
take the brush roller off and on the ends are the bearing caps.try to take those off and clean the bearings ,carpet strands and hair will cause that.after you do that make sure the roller turns freely if not then the bearings might be bad and if thats the case you might have to order a new brush rollersome bearing caps unscrew and others pull off
Apr 27, 2009 | Vacuums
Dyson DC07
Hi.
Depending on wether your machine has A clutch fitted will decide how easy this job will be.
The non clutched model is very simple turn the 3 plastic screws on sole plate to unlock position lift plate off remove belt from motor shaft & lift out brush roller.
Replace belt & roller fit sole plate & its done.
The clutched version will require the removing of the sole pate,
Then remove brush roller. & brush roller housing.
Then remove clutch cover,
Replace both belts & reassemble.
Its A lot to explain in great detail so try this site if your struggling.
http://dysonmanuals.llc.nu/
Jun 18, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
Vacuums Logo
52 people viewed this question
Top Lindhaus Vacuums Experts
vince
ray gallant
Are you a Lindhaus Vacuum Expert? Answer questions, earn points and help others
