Question about Gilmour & Spray Doc& Poly Tank Sprayer Pump Assembly
I have a 4.5 gallon Gilmour Spray-Doc and the trigger has cracked. I can no longer control the spray coming out of the unit. I need to remove the base so I can replace the tubing and trigger assembly. What type of screw driver is required to remove the green base from the poly tank?
4 Suggested Answers
SOURCE: replace 0-ring
all I want to know is how I can get a replacement o-ring ASAP without paying to discuss my needphone number and person to call would be helpful.
Posted on Mar 24, 2009
Biggdex35
  • 333 Answers
SOURCE: Weee killer leaks from my Gilmour sprayer finger
Im pretty sure that is all it is. The pressure is by how many times you pump it up. Its just on or off. Sounds like It needs to be cleaned real good, and put soap in it befor you put it bak together. Also there is a screen if you hold the handle and turn the trigger part and unscrew it.
Posted on May 11, 2010
Testimonial: "Thanks for the reply Bigdex!"
AndrexT
  • 19584 Answers
SOURCE: I need a manual for my Gilmour model 2000P spray doc garden innovation 2 - 2 1/2 gallon
That is just a simple pump sprayer. Your manual is here
Gilmour Professional 2000P Manuals
Posted on Mar 17, 2017
Will not pressurize
Seals not sealing check cover rubber gasket and relief valve
Mar 05, 2014 | Gilmour W4 Spray Doc 4 Gallon Wheel Pump...
How to fill gilmour spray-doc
All sprayers have a cap that turns anti-clockwise. With all of these you push the handle down and turn firmly.
Lawn Garden Gilmour Garden Watering
Mar 29, 2013 | Gilmour & Spray Doc& Poly Tank Sprayer...
I have a gilmour xp30. The pump assembly will not pressurize/blow air out the exhaust port. (There seems to be a part rattling inside the cylinder). Can it be fixed?
there is an O-ring in the plunger tube that can slip of its channel seating if it becomes dried out. To put it back you need to disassemble the handle from unit. At base of handle is a lock that looks like a cross. It is difficult to turn because it has small protrusions at the ends that snap into holes in the collar. Once you turn them and the pop out the handle can be removed exposing the pump shaft. The O-ring is probably what you hear rattling and will be loose in bottom of tube. Just put it back into its grooved seat, slide plunger back into unit, rotate the x-lock till it snaps back into place and unit should work again. I have oiled o-ring but that did not last long and might get oil on plants. I now just spray some water down the top to lubricate the O-ring when it seems dry.
Aug 22, 2011 | Gilmour & Spray Doc& Poly Tank Sprayer...
Water leaks out of the bottom
If you see water leaking it might be that the plastic has a broken, try to seal it with super crazy glue.
Thanks
Jul 01, 2011 | Gilmour W4 Spray Doc 4 Gallon Wheel Pump...
It will not spray
Your pump cam follower may be broken, such that the pump is just not working. Good news, you don't need to buy any new parts. If you open it up and find that the cam follower plastic tabs are broken, Gilmour provides a second set of 2 cam followers on the other side of the cam follower assembly. Just remove some screws, reverse the assembly, and you are back in business. Since the higher the wheel speed the more stress there is on these tabs, I would not recommend moving the wheels any faster than what occurs with a slow walk.
See photos at:
http://s911.photobucket.com/albums/ac317/vonoretn/Gilmore%20Wheelpump%20sprayer/
Jun 04, 2011 | Gilmour W4 Spray Doc 4 Gallon Wheel Pump...
My gilmour wheelpump sprayer just quit spraying. It appears to not be building up pressure. I have cleaned out the valve and screen on the bottom, removed and rinsed out the hollow oval 'ball'...
Your pump cam follower may be broken, such that the pump is just not working. It happened on mine. You don't need to buy any parts. If you open it up and find that the cam follower plastic tabs are broken, Gilmore provides a second set of 2 cam followers on the other side of the cam follower assembly. Just remove some screws, reverse the assembly, and you are back in business.
See photos at:
May 11, 2011 | Gilmour W4 Spray Doc 4 Gallon Wheel Pump...
I have a 3-gallon gilmour sprayer--has worked well-only several month old-able to get good compression but can not get anyspray-even after taking apart and rinsing your help is appreciated thanks ...
This situation sounds like a plugged hose. Keep taking apart and you will find something plugging a small orifice, somewhere... Always flush with clean water after each use, many garden sprays crystalize over time......
Apr 24, 2011 | Gilmour & Spray Doc& Poly Tank Sprayer...
May 10, 2010 | Gilmour 1 Gallon Lawn & Garden Spray Tank...
Replace 0-ring
Mar 23, 2009 | Gilmour & Spray Doc& Poly Tank Sprayer...
Gilmour & Spray Doc& Poly Tank Sprayer Pump Assembly  Logo
48 people viewed this question
Top Gilmour Garden Experts
cackelberry
Level 1 Expert
Charles T Nevin
Charles T Nevin
Are you a Gilmour Garden Expert? Answer questions, earn points and help others
