Question about Haier HDC10LBS Stainless Steel 10-Cup Coffee Maker
Replacement decanter for W14A7123 signature classics
What is a decanter?
A decanter is a vessel that is used to allow the decantation of any liquid that has sediment-most often it will hold wine. When you pour the wine into the decanter, the sediment is left in the first vessel. As well, a decanter allows the wine to aerate before you drink it.
Apr 10, 2013 | Home
Why do people decant wines?
Decanters are most often used to get rid of sediment from a wine bottle. If you slowly pour the wine on an angle from the bottle to the decanter you can use the light behind the neck of the bottle to see when the sediment approaches the neck.
A second reason to decant wine would be to help aerate the wine, releasing several aromas and flavors. It is best to do this with full bodied highly tannic red wines
Feb 03, 2013 | Wine & Spirits
SAYS COFFE READY PUSH LARGE CUP AND A COUPLE OF DROPS COME OUT THAN SAYS FILL AND PUSH STEAM HAVE DONE AND REDONE SEVERAL TIMES STILL NOT GETTING A CUP OF COFFEE TOOK TANK OUT AND CHECKED FOR FLOTATION IT...
Hello.
1 Perform the initial setup on the coffee maker. Make sure the coffee maker is not plugged in. Slide the empty funnel into the funnel guides, fill the decanter with cold water, open the lid and pour water from the decanter into the brewer, put the decanter back on the base, then close the lid and wait three minutes for the internal tank to partially fill. Open the lid, fill the decanter with cold water again, and once more pour the water directly into the brewer. Put the decanter back on the base and wait for water to flow out of the funnel and into the decanter. Once it has stopped flowing, pour out any water that is in the decanted and plug in the coffee maker. Press the on switch to turn the coffee maker on and heat up the water in the tank.
2 Ensure the lid is completely closed. If the lid is open, the Bunn coffee maker will not brew coffee.
3 Check the see how much water is in the water tank. The Bunn coffee maker will not begin brewing coffee if less than 20 ounces (4 cups) of water is present in the water reservoir tank.
4 Delime the coffee maker. Unplug the coffee brewer and allow it to cool down. Remove the sprayhead by turning it by hand and set it aside. Insert the flexible deliming tool into the sprayhead tube until all but two inches are showing. You may need to twist and force the tool to go in. Slide the tool in and out several times to loosen lime buildup.
Check the sprayhead for lime buildup. If there are flakes of minerals, they can be removed with a toothpick. Scrub the sprayhead with soap and water. Rinse the sprayhead with water and replace it in the coffee maker. Pour water into the water tank and turn the coffee maker on, allowing water to run through without making any coffee. This will flush any lime fragments through the system. Empty the decanter
Thanks.
Sep 18, 2011 | Jura Capresso Impressa S90 Espresso...
How do you clean coffee maker?
Start a cycle and run 4 ounces of white vinegar and 16 ounces of water through the coffee maker.
May 29, 2011 | Bunn NHB Coffee Maker
How do you clean the Bunn 10 cup classic comercial coffee maker it is a BX-B model?
To clean your brewer, with the machine still turned on, pour in 1 qt of white vinegar and let it sit in your brewer for 2 hours. At the end of 2 hours, you will flush it out with 8-10 decanters of water.
Dec 26, 2010 | Bunn 10 Cup Home Coffee Brewer
Mr. Coffee coffee maker replacement decanter NOT available ISD 17
I am in your boat! I have been searching for ISD17 for my dust collector, for 3 months now. I have called Mr Coffee, they told me the item would be available August (end of) and nothing. If I hear anything of find I will for sure come back and post! Although it doesn't solve your problem, I just thought you would like to know you are NOT alone.
Jul 20, 2010 | Coffee Makers & Espresso Machines
Can a replacement decanter be obtained??? for a bt10b
Yes- any reputable Bunn dealer or repair depot should have a replacement decanter for this unit. For a list of repair depots in your area, go to www.bunn.com,
Oct 29, 2009 | Bunn BT10B Coffee Maker
Haier HDC10LBS Stainless Steel 10-Cup Coffee Maker Logo
Top Haier Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Haier Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
