Question about GE Cre00-bk Create Jason Wu 12mp Digital Camera With 3x Optical Zoom - Black
My camera won't turn off
Everything else is functioning fine.
I push the button but it wont take a picture
Did you try it like it is said in the manual? press the button half till the camera is focused and then press the button completely down?
Don't expect the camera to shoot with the same speed as a camera with film did. Give it some time to focus and everything will be fine (I hope)
If not let me know.
Jan 02, 2014 | Sanyo vpc-s1415 - Vpc-s1415 14.0...
Camera powers on and everything seems to be in working order except it will not take a picture. could it be full?
That is one possibility. Try using a different memory card, or clear out the one you're using.
Dec 15, 2011 | Sony Alpha Dslr-a290 A390 Camera
We pulled our stacked washer out from the wall to service the cold water hose filter on the back of the unit. when we pushed it back into it's location the washer won't start, won't fill...
I know you don't want to hear this, but either you did something to the hose filter or you didn't get it plugged back in correctly.
If you banged the water inlet valve in moving it back, it might be damaged.
Suggest you unplug everything and start over.
Sep 04, 2011 | Frigidaire FEX831F Top Load Stacked Washer...
I have a Sony AX Digital 100 Camera. I used it yesterday and everything worked fine. Battery is fully charged. Tried to use it today and it won't start. I have taken the battery in and out and even...
Does there is something happened when you turn on the camera? If you can heard sound made by the len or the camera try to open but turn off in a second? If so, there is something wrong with the lens, and this how to fix camera lens error will be helpful. Else, if the camera are without any reaction you can check it the joint of the camera to battery is well.
May 20, 2011 | Cameras
Kodak v550 easyschare camera
As long as the pictures look fine it is something going on with the lcd display.
If it was taking pictures the same, it could be a special effect that is turned on or the CCD is bad. It sounds like the LCD display is bad. Some cameras can be repaired at a reasonable price with a new LCD display.
Have you replaced the batteries in the camera? That might take care of the problem.
Jun 15, 2008 | Kodak EasyShare V1003 Digital Camera
Camera won't retrack
August - this sounds like the same problem I had with my Finepix510. Turns out the new unopened package of batteries I put in weren't fresh enough and weren't working. When I got truly fresh batteries, everything started working just fine again.
Hope that turns out to be true for you.
Dec 28, 2007 | Fuji FinePix E510 Digital Camera
GE Cre00-bk Create Jason Wu 12mp Digital Camera With 3x Optical Zoom - Black Logo
12 people viewed this question
Top GE Video Cameras Experts
Ravi
Tony Parsons
Tony Parsons
Are you a GE Video Camera Expert? Answer questions, earn points and help others
