Question about Champion 2.4 HP Gasoline Generator
I nead a rocker arm - Champion 2.4 HP Gasoline Generator
Rocker arm pivot torque for olds cutlass 1987 307
Oldsmobile Torque Specs - GbodyOlds.com
www.gbodyolds.com/forum/showthread.php?754-Oldsmobile-Torque...
Feb 7, 2013 - 2 posts - ‎2 authors Oldsmobile Small-Block Engines Cylinder Head Bolts (1/2in. bolt) 130 ft. lbs. Cylinder Head ... Rocker Arm Pivot Bolt 25 ft. lbs. Rod Bearing ...
Rocker Arms - AutoZone
www.autozone.com/...Cutlass...1987.../Rocker-Arms/_/P-0900...
AutoZoneGM Cutlass RWD 1970-1987 Repair Guide ... To remove the rocker arms from the shaft, the nylon arm retainers must be removed. ... 7: Engine valve system, 260, 307, 350, 403 Oldsmobile built engines ... Unfasten the two bolts that attach the rocker arm pivot to the cylinder head. ... Torque the retaining bolts to 25 ft. lbs.
Dec 01, 2015 | 1987 Oldsmobile Cutlass Salon
Rocker arm specs
ROCKER ARM SUPPORT PLATE
Installing the rocker arms and rotating the engine with the valve
train loaded can result in bent push rods, damaged bushings
or a warped support plate.
To install the rocker arm support plate, both lifters of the
cylinder being serviced must be on the base circle (or
lowest position) of the cam.
Place the rocker arm support plate assembly into the rocker housing. Loosely install the four
rocker arm support plate bolts with flat washers.
Tighten the rocker arm support plate bolts in a cross pattern and alternately tighten
each of the four rocker arm support plate bolts just 1/4 turn. THEN continue turning the bolts in these increments until snug. THEN following the same sequence, tighten the bolts to 18-
22 ft-lbs (24.4-29.8 Nm).
THEN install and alternately tighten the two bolts to secure breather assembly to 90-120 in-lbs (10.2-13.6 Nm).
May 12, 2014 | 2008 Harley Davidson FXD Dyna Super Glide
Installed new oil pump and now have broken rocker arms
THe rocker arms are broken because there was not enough downward movement in the valves to allow the cam to complete its turn. IT happens when the valve spring retainer either hits the top of the valve guide or the valve springs are fully compressed forming a solid block . If you have hydraulic valve adjusters I would be suspicious of a lack of movement (seized) in the ones that broke the rocker arms
Feb 20, 2013 | Ford F-150 Cars & Trucks
I have a loud tapping in my front rocker box on my 2000 harley 1200 sportster custom i have pulled top and middle covers but the valve springs look fine and pushrods seem fine an thoughts?
I could be the bushings in the rocker arms and the rocker arm shafts. Bring the piston to top dead center on the cylinder that has the noise. Both valves should be closed. Allow about five minutes for the tappets to bleed down on that cylinder. When you can spin both of the pushrods with your fingers, remove the 5/16 inch bolts on the right hand side (pushrod side) of the head. This should allow you to push the rocker arm shaft out and remove the rocker arm. You may have to gently tap the rocker arm shafts out but it should not be difficult to get them out. Do not mix the rocker arms and their shafts up. Keep them together. Check the bushings in the rocker arms and the rocker arm shafts for wear. The bushings can be replaced and use new rocker arm shafts if this turns out out to be the problem. Check the face of the rocker arm where it pushes down on the valve stem for wear as well.
http://www.bikebandit.com/2002-harley-davidson-sportster-1200-custom-xl1200c/o/m18657#sch625617
Good Luck
Steve
Sep 06, 2011 | 2000 Harley Davidson XL 1200 C Sportster...
P 2647"A" Rocker Arm Actuator
Your going to need a air pressure regulator or better yet if the ECM found fault price it and replace it
  1. Start the engine, and let it run for 5 minutes, then turn the ignition switch to LOCK (0).
  2. Remove the cylinder head cover.
  3. Set the No. 1 piston at top dead center (TDC).
  4. Move the intake secondary rocker arm A for the No. 1 cylinder. The secondary rocker arm A should move independently of the secondary rocker arm B.
    1. If the intake secondary rocker arm A moves freely, go to step 5.
    2. If the intake secondary rocker arm A does not move, remove the secondary rocker arms as an assembly, then check that the pistons in the secondary rocker arms move smoothly. If any rocker arm needs replacing, replace the secondary rocker arms as an assembly, then retest.
    3. Repeat step 4 on the remaining intake secondary rocker arms with each piston at TDC. When all the secondary rocker arms pass the test, go to step 6.
    4. Check that the air pressure on the shop air compressor gauge indicates over 400 kPa (4.0 kgf/cm2, 57 psi).
    5. Inspect the valve clearance.
    6. Install a 10 x 1.0 mm adapter to the inspection hole, then connect the air pressure regulator
  5. With the specified air pressure applied, move the intake secondary rocker arm A for the No. 1 cylinder. The secondary rocker arm A and secondary rocker arm B should move together. If the intake secondary rocker arm A does not move, remove the secondary rocker arms as an assembly, and check that the pistons in the secondary rocker arms move smoothly. If any rocker arm needs replacing, replace the secondary rocker arms as an assembly, then retest.
Aug 23, 2011 | Honda Accord Cars & Trucks
What are the torque specifications for a 3.5l v6 1995 ford tarus rocker arm
For each valve, rotate the crankshaft until the valve lifter rests on the heel (base circle) of the camshaft lobe. Position the rocker arm(s) over the push rods, then install the rocker arm seats. Tighten the rocker arm seat retaining bolts to 44 inch lbs. (5 Nm).
Final-tighten the rocker arm retaining bolt(s) to 19-25 ft. lbs. (25-35 Nm). For final tightening, the camshaft may be in any position.
Hope helps.
May 19, 2011 | 1995 Ford Taurus
I replaced the lifters in my 2000 galant 2.4 L and i need to know what to torque the rocker arm shafts to.
1.5 and 1.8 engines:
* Install the rocker arm and shaft assemblies. Tighten the rocker arm shaft retainer bolts to 23 ft. lbs. (32 Nm).
* Check valve adjustment and install the valve cover. Tighten the valve cover bolts to 16 inch lbs. (1.8 Nm) for the 1.5L engine or to 29 inch lbs. (3.3 Nm) for the 1.8L engine.
2.0 engine
* Lubricate the rocker shaft with clean engine oil and install the rockers and springs in their proper places.
* Install the rocker shaft assemblies on the engine. Tighten the bolts gradually and evenly to 21-25 ft. lbs. (29-35 Nm).
2.4 engine
Fig. Rocker arm shafts and components-2.4L engine
* Fit the rocker shaft springs from above and position them so that they are at right angles to the plug side. Install the rocker springs before installing the exhaust side rocker shaft and rocker arm assembly.
* Install the exhaust side rocker shaft assembly in the engine. Tighten the rocker shaft mounting bolts gradually and evenly to 23 ft. lbs. (32 Nm).
* Remove the lash adjuster retaining tools.
* Install the rocker cover and tighten the mounting bolts to 30 inch lbs. (3 Nm).
* Reinstall the spark plug wires to the spark plugs.
Hope helps.
Sep 06, 2010 | Mitsubishi Galant Cars & Trucks
Rocker arm come out on jeep chrysler 3.7 eng
A rocker arm is the arm that sits on top of the valve stem and connects to the push rods 'the push rods sit on the cam so when engine is running, the push rods go up and down in a timed sequence and with the rocker arms, open and close the inlet and exhaust valves. the rocker arm is located inside the valve(rocker)cover .If the rocker arm gets loose or comes out.
Check the nuts on the shaft which holds the rocker arms.either the shaft or nuts are got loose.They need to be tightened.Don't make it too tight or too loose.  Too tight,and they don't flutter right. Too loose,and they allow the rocker arms to wiggle out of whack. Other possibility can be  something is broken, bent, collapsed, or out of adjustment.
Thanks. you can rate this solution and show your appreciation.
May 20, 2010 | 2002 Jeep Liberty
Cam gears pulled out when changing gear box gasket trouble reinstalling due to tappets line cams up but front exhaust to tight to install
I'd be interested in knowing how the cam chest cover cam off changing a gear box gasket but.
In order to get the cams back in and to insure their proper timing, I'd put the rocker arms out. I'd pull them all out but you're free to do whatever you wish. Remove the top and middle rocker cover on the front clinder. Remove the large bolt that hold the lower plate and the rocker arm for the front cylinder in. Tap the rocker arm shaft out of the rocker arm and remove the rocker arm. You can then get your cam into position. Now, to get rocker shaft back in, rotate the engine until the front exhaust cam has the valve in it's closed position. Reinstall the rocker arm and shaft and torque the bolt to 25 foot pounds. Reassemble the upper and middle rocker box covers.
Apr 15, 2010 | 2005 Harley Davidson XL 1200 R Sporster...
Loud rattle noise in Camshaft
First, your engine has rocker arms, if you have a 4 cylinder you have 8 rocker arms, and if it is a 6 cylinder you have 12 rocker arms. Now if it is indeed a rocker arm making the noise, the cause is most likely a bad lifter or a worn cam shaft.
Apr 02, 2010 | 2001 Chevrolet Cavalier
Champion 2.4 HP Gasoline Generator Logo
14 people viewed this question
Top Champion Electrical Supplies Experts
ken skalski
Gene Haynes
Are you a Champion Electrical Supply Expert? Answer questions, earn points and help others
