Question about Car Audio & Video
CD disc will not load
When you try to load cd we get message disc won't load. We bought a new CD player and same error is coming up!
Eagleeyes
  • 199 Answers
SOURCE: cd player
Ok guys thius it how it works.
Blaupunkt supply a repair kit for this unit, this basically is a fix. but only works for 8 out of 10units.
its a pain to fit too.
you have to replace the 3 spindle guides and arms. the part number is : 8619001490 there a reall complicated thing to fit.
i am looking to get a install guide sorted. and will soon be selling the kits on my website
www.carradiospares.co.uk
Regards
Mark
Blue ICE
Posted on Feb 24, 2008
ginko
  • 19396 Answers
SOURCE: cd error message
Try to disconnect battery contacts and connect it back. Check also if there is an emergency opening device. In some model you have a pin hole underneath the cd tray. push a staple tip inside the hole, and this will release the cd.
If the tray still does not open, you may need to have a repairman opening your stereo at your local service point.
Regards
Posted on Apr 03, 2008
SOURCE: Can't eject cd magazine - E-99 error message
I put a small pin in the reset button a few times and that then got the catridge to eject.
Posted on Apr 15, 2009
  • 3 Answers
SOURCE: CD stuck in CD Player - 1998 Mazda Protege
It might be a Bose system. I usually remove stuck CD's by grasping the edge with a pair of tweezers and pulling slowly, there will be some resistance. Try to reset first by removing the fuse for about 30 seconds and after it powers up again (don't turn it on yet) push the eject button.
Posted on Apr 20, 2009
SOURCE: ford 6006e cd changer with e 3 error keeps happening
The only way to do it is to remove the radio using DIN radio removal tool - then you will have easy acces to remove cd's if you do not have this tools try to use coat hanger (do small catss on the ends)
(you can try to hold eject button and swich off - swich on button - probably it will not work but try few times
Good luck,
Kamil
Posted on Jun 24, 2009
Cd player error
so is this a stock RAD/cd?
stock JBL 6 disk player in dash>? or? what? name and model #
mp3 and wma format. but not DVD
or
JBL premium 4-disc in-dash CD changer
io the single disc player, 3 kinds sold. new.
and now comes the big question.
TELLS where you got the disk, or name it, or tell how it was made if home made. we dont know that.
is said CD a CDDA? or not. (always try CDDA first)
is CD a real music disc. from a real store, CDDA, is that.
or CDR, or DVDr, or CDRW, or other record-able media
is music MP3? files.
see, the old units dont play modern media.
try 2 real discs, not scratched.
do they play?
one other way, is to name the radio, brand, like JBL then get the
p/n off it. (hard) then look up the product data sheet on it,
bingo, what it can and can not do is there.
but this does it all, mostly
does what yours will not do.
http://www.flyaudio.net/product_id.asp?id=113
Jan 02, 2014 | 2007 Toyota Camry
I have a sherwood cdc-5090/c/r multiple cd player - it goes on error when using open/close, disc selector, disc skip. have tried troubleshing guide but doesn't seem to work.
The problem is in the CD loading bays, quite often the gears will ware over a period of time causing error messages because it is unable to complete the cycle. The second issue is the timing gears go out of sink because one of the CD'S gets jammed against the other causing it go out. The repairs are tricky because of the timing issue, however if gears are stripped the whole CD bay must be replaced.
Mar 10, 2012 | Audio Players & Recorders
Cd player won't spin disc
HelloCheck the sled motor. it is the motor that spins the disc inside, as soon as it has been loaded. Check the voltage comes to the leads of the motor first. If the voltage is there, and the motor does not spins, repalce the motor. It is a stepper motor, can be bought from most of the electronic spare part shops at your town. it is not a very colstly component. OK.
Dec 19, 2011 | Sony Audio Players & Recorders
I hav a clarion auto cd/stereo displaying err 6 please explain, thank you
Error 1.Battery inside CD Changer needs to be replaced.
Error 2.CD error message. Mechanism has as eject problem or takes a long time to select CD.
Error 3.CD error message. The pick-up is out of focus during play mode due to scratches on the disc or contamination.
Error 4.Connection problem. Reconnect the data cable.
Error 5.CD error message. Could not read correct data due to CD ROM.
Error 6.CD error message. Could not read data from disc because it is upside-down.
For error code 6:
Try an original purchased cd with no scratches and see if the cd player reads it. If yes then lens is dirty or tired so try using a cleaning cd(has little brushes on it). If it doesn't read with the original cd try using the cleaning cd and if no go then look at purchasing a new cd player!
Nov 01, 2010 | Car Audio & Video
Loads cds. I can hear the loading mechanism operating, I get the 'read' message, but 10 seconds later comes the error message
either the cd you are trying to use is in the wrong format for that cd player or something is wrong with the eye in the cd player
Jun 10, 2010 | Sony CDX-565MXRF 10-Disc CD Changer
CD Player won't read disc's. ERROR message
Well if the unit came with car over 10 years old, u can't clean it might have to just replace. buying a new one will cost as much as trying to fix that one.
Apr 10, 2009 | 2003 Dodge Grand Caravan AWD
I bought iTunes card, bought the songs i wanted, but it wont work
Your CD Drive may be just a CD/DVD reader Drive may not be able to burn onto CD/DVD,s my dads laptop cant, he gets same error when he trys, so he had to use a different cd/dvd burner on a desktop.
If you have a desktop or laptop and you are 100% sure it can burn to CD/DVD,s then i reccomend you get a program called "ULTRA ISO" it is shareware but allows burning up to 300mb per cd for free before it asks you to pay so as long as you keep cd files below a total of 300mb you,d never have to pay. if its actually ITUNES which is reporting the error then your CD/DVD drive may require its own software before itunes will reconise it as CD/DVD burner drive. windows media player can report this type of error also.
Feb 07, 2009 | Classic Electronics MP6410 MP3 Player
1997 Chevy Pick up Single disc player won't work
Have you tried different CDs?
If the cd is ok, the read head on the cd player is probably covered in grunge! Get thee to ye olde local audio / TV shop and purchase a CD head cleaning kit.
Usually these come with a cd with a brush attached to it and some cleaning fluid.
Follow the instructions on the packaging and give your music cd another try.
Hope this does the trick
M3ODQ
Feb 01, 2009 | Car Audio & Video
2002 lincoln alpine 6 disc focus error
Probably a Sony clone. Have a look at the Pioneer disc player schematics.
May 22, 2017 | Car Audio & Video
Car Audio & Video Logo
52 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
