Question about Indesit W 123 Front Load Washer
Indesit washer hi have you got a wiring diagram for a indesit wil 123 model for connecting the heater and motor thanx
If you mean the wires that go to the back of the drum from left to right= green circle=brown wire pushon tellow/green(earth) square =2 lite blues yellow circle=dark blue if this isnt what you needed please respecify and ill do my best to answer ,ian if you add to this post it will inform me for a faster reply
Posted on Nov 19, 2008
F-08 code
Indesit 'f08' decodes as ' heater relay stuck' and the advice is 'check PS (power supply)connections for the heater, wiring and module'. Unfortunately this means an engineer call-out ;-0(
Good luck,
John C
Mar 25, 2011 | Indesit W 123 Front Load Washer
Error code f-08 on indesit wixe127 washer
Error code F08 means that the heaterrrelay cannot be activated.
Check the connections to the Pressure switch, the Module,and the Heater element.
If you can, test the element of the heater to make sure it is o/k.
Hope this helps.
Dec 02, 2009 | Indesit W 123 Front Load Washer
Bearings getting noisy
no need to remove the drum
u just unscrew the screws and spyder wil come and u can change the baring
Mar 07, 2009 | Indesit W 123 Front Load Washer
Indesit wil 143 washing machine
It is automatic half load you dont need to do anything.
Oct 04, 2008 | Indesit W 123 Front Load Washer
Indesit wil 103 heater element
no need to take drum out. heater is held by one 10mm nut in the middle of the heater. when tightened, this nut compresses the rubber seal and holds heater in place. loosen the nut. the heater will probably be too tight to remove by hand so carefully use a screwdriver to lever it out
Jun 26, 2008 | Indesit W 123 Front Load Washer
Indesit washeing machine
Karen, that was nice.........
May 31, 2008 | Indesit W 123 Front Load Washer
Indesit wil 113
this is a cold fill only machine as nearly all machines today are designed that way to save energy , as you only heat the water that you need
Mar 28, 2008 | Indesit W 123 Front Load Washer
Model 1100 WIL 113
sounds like you may have some moisture getting into the electronic panel but because it only happens rarely best not to try to fix. This is normally quite expensive as they need to replace electronic panel and seals around panel, so I would live with it.
Dec 13, 2017 | Indesit W 123 Front Load Washer
Indesit W 123 Service Manual
Click on your model number (below FIXYA) on this website, & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
And dont forget to rate me on this great site!
Jan 24, 2008 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
276 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
