Question about LG LSU360HV Ductless Outdoor Heat Pump 16.1 SEER 36,000 BTU 3 Ton
Comp wont run - LG LSU360HV Ductless Outdoor Heat Pump 16.1 SEER 36,000 BTU 3 Ton
Briggs 19E412, the engine surges from full open throtle to closed, runs best when choke is paritally closed but still surges
comp air wont do it.. soak in carb cleaner to make sure all orifices are clear.. use fishing line to clear them out THEN comp air
Sep 06, 2014 | Motorcycles
Can anyone help my laptop is saying my ipod has malfuctioned
You need more info. Do you have a mac or pc. Also what version of itunes are u running. Does the ipod still work? If it wont even turn on try the wall charger. This way you can take the comp out of the situation and know if its the ipod or comp with the problem.
Apr 01, 2013 | Audio Players & Recorders
I'm reinstalling Windows 7 on my ACER laptop. I need JUST the DRIVER. A wizard wont work since the comp isn't running yet. swingdav10@yahoo.com
If you install the Windows 7 disk it should install generic drivers, then run ALL the Windows Updates.
Mar 22, 2013 | Computers & Internet
My kitchenaid ksrg25fkss refigerator supera wont get cold
freon. dirty coils under refrig. fan motor by comp. not working. make sure first of all comp. is running if not make sure freezer fan is. if that the case you need a relay starter overload or a compressor.
Apr 01, 2012 | KitchenAid Refrigerators
Marine unit will run but not cool or make ice
if it doesnot get cold it wont make ice. u need to check to see if comp. is really running. might have a bad relay on comp. ok
Feb 11, 2011 | U-Line Refrigerator Ice Maker
Wont power up green light on back is on but
Most likely a failure in the internal power supply of the tower. Replacements are around $50 if not under warranty.
Oct 09, 2009 | HP Compaq Presario SR2150NX PC Desktop
It wont cool
if the compressor is running your ref. should be getting cold.their is a defrost timer but when it is in defrost the compressor shuts off.I think you do have a leak.
Mar 20, 2009 | Magic Chef (CSD2610KRW) Top Freezer...
My HP pavillion laptops keyboard is non responsive. The computer works, mouse works, but the keys wont respond. It seems to be locked on numslock the liht stays on but it doesnt respond to any keys. I dont...
i had the same prob with my sony vaio..but soon found the way out all by myself. first, run a thorough antivirus check and then reboot your comp. then reinstall your keyboard drivers. reboot your comp your comp again. your keyboard will be working. trust me..
Dec 13, 2008 | HP Internet Keyboard
Computer will not load anything
Turning you rmonitor on then your comp my monitor has a delay and if i dont turn it on before i turn my comp on or before i here the little beep noise my comp makes the monitor wont display anything.
Jul 14, 2008 | Systemax AOL Optimized PC (100607) PC...
LG LSU360HV Ductless Outdoor Heat Pump 16.1 SEER 36,000 BTU 3 Ton Logo
12 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
