Question about Vizio 70 Razor LED 1080p 120Hz Smart TV - VUDU Enabled Products
Green rotating circle on screen of vizio tv
Green rotating circle in bottom right side of screen
  • 142 Answers
SOURCE: Vizio L37 37" LCD screen screen is cracked.
I agree your screen is cracked. It's smooth to the touch because you're not actually touching the LCD section of the screen, just the protective coating. The advantage of owning an LCD TV over plasma... you can replace the screen either by going to the manufacturer or some place like e-bay. It's not a difficult thing to do if you take your time and pay attention to the details.
Good Luck
Posted on Apr 09, 2008
aminic
  • 61 Answers
SOURCE: Vizio P2 42 in. HDTV-Ready Plasma
Search Google "Screen Burn-In."
Mainly Plasma screens are affected by it.
Posted on Sep 20, 2008
  • 1779 Answers
SOURCE: VIZIO P42 plasma, half screen ok, other half showing blank
First you have to check if voltage and data are ok at the Y sustain board and the Y driver boards are not running hot. Even if you know how to replace these panels you must have a scope to adjust the v-set up and v- down. Not just a simple PNP. Trouble shooting a plasma is not a short time process to do it correctly. Please let a service center look at it for you.
Posted on Feb 18, 2009
tvtek
  • 1284 Answers
SOURCE: I have a Vizio SV420XVT. There is a green line
A single line out means a bad LCD panel..The cost for parts will exceed the cost of replacing the TV...
Posted on Jul 23, 2009
stonephoenix
  • 563 Answers
SOURCE: I have a 42
G'Day!
Unfortunately, what you're describing is a repair issue. You won't be able to address the problem with troubleshooting. There is a part inside the TV that needs to be replaced. If you're under warranty, this will cost you nothing. If you're not under warranty the cost will likely be a minimum of $200 parts and labor. However, be warned that the cost could be considerably higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Posted on Aug 03, 2009
My Vizio developed a black circle in the bottom corner. Eventually, the black circle disappeared. Now when I turn it on these horizontal lines develop on the bottom of the screen. Any ideas?
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Sep 08, 2016 | Vizio Televison & Video
How do I keep my iPhone 5 and my iPad 6 from switching from portrait screen up and down to landscape screen side to side ?...thanks in advance
Well first the obvious answer...don't hold the device in landscape mode :)
But that's no good. You should be able to hold the device how you want and have the screen rotation how you want as well. Holding an iPad in portrait mode while laying in bed on your side for example, right?
A single finger swipe from the bottom of the display just across the bezel into the display area will bring up the lock screen rotation toggle. It's at the top of the control center, the far right circle.
But what happens if the screen rubber bands?
What is rubber banding? See the video example.
Sep 27, 2015 | Apple iPhone Cell Phones
While installing a new vizio m550nv model the screen permantly from on "Vizio Internet Apps." We tried unplugging for 5 minutes, every button on the remote, including holding down. All Vizio tech support...
Try using the control on the right side near the bottom on back of set. Pushing this nob should get you to any menu that you want. rotating will change volumn when in the audio selection and etc.
Sep 19, 2010 | Televison & Video
I have a Vizio SV420XVT. There is a green line from top to bottom on the right side of screen. Help me fix this, just went out of warranty
Jul 23, 2009 | Vizio SV420XV 42 in. LCD TV
I think the inside panel is cracked
Yes lcd screen is cracked. No way to repair, other than changing screen. Cheaper to buy new tv.
Jul 20, 2009 | Vizio L32 32 in. LCD HDTV
My vizio 37" plasma tv has a green line running down the right side of the screen
Vizio does not make 37" plasma TV. for the green line problem, does it happen on all inputs or just when you what TV (cable or satellite)? That line should only be present on some channels due to signal processing compatibility. To get rid of it, you can use the horizontal size adjustment and expand the picture side way.
Jul 03, 2009 | Vizio L37 Television
VIZIO P42hd PS42a plasma Picture has two vertical lines (one red/orange, one blue) going down the right-hand side of the screen. Lines are clearly visible
The panel is almost certainly bad. The only fix for this is to replace the whole panel which would cost more than the whole TV.
Mar 30, 2009 | Televison & Video
Sep 20, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
One green vertical line in HDTV Vizio 42
Try changing the H/V position in the TV Set Up menu. You can adjust the horizontal and vertical position of the screen and move it enough that the green line disappears from the screen.
May 18, 2008 | Televison & Video
Vizio 70 Razor LED 1080p 120Hz Smart TV - VUDU Enabled Products Logo
20 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
