Question about Home
Rear caliper and parts diagram 92 eldorado - Home
I need full diagram of cooling system 4.9l
Chris, Check the attached links,instruction, diagrams and guides for your caddies cooling system. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
1992 Cadillac Eldorado 4 9l cooling system diagram Google Search
Parts com Genuine Factory OEM 1992 Cadillac Eldorado Touring V8 4 9 Liter...
1992 Cadillac Eldorado Parts GM Parts Online GM Parts Direct
Likely Coolant Leak Locations General Cadillac Forums
Apr 08, 2016 | 1992 Cadillac Eldorado
Brake bleeding squence for 92 cad eld
RIGHT REAR, LEFT REAR, RIGHT FRONT, LEFT FRONT
Jan 22, 2013 | 1993 Cadillac Eldorado
My 1984 Cadillac has had new brake pads and new master cylinder and new rear calipers. Now the brake pedal rises up and my left rear caliper is locking the wheel up after 3- 7 miles
I would take it up with the guy who put the caliper in. if that was you i would get it up in the air and see what you did to cause this. take a close look at the parking brake mechanism and cable, used to see frozen cables cause this on drum brakes
Dec 27, 2010 | 1984 Cadillac Eldorado
HOW TO CHANGE REAR BRAKES ON FLHTC 92
Remove any saddlebags or anything that hampers your access to the rear brake caliper. Remove the two bolts that hold the caliper onto the brake caliper bracket and lift the caliper off the bracket.
The pads and all anti-rattle parts should stay on the caliper bracket. Pay particular attention to the way these parts are installed in the bracket. Replace all the old parts with new parts paying attention to how the new parts are put in the bracket. Make sure the rear pad is installed with the fiber side to the rotor, not the metal side. Don't laugh, I've seen it done more times that I care to remember.
Now, you have to get the piston compressed back into the caliper. I used either a large C-clamp or a large pair of slip joint pliers. Protect your paint and finish on your caliper by using rags or a couple pieces of wood or something. Once the piston is fully compressed into the caliper, carefully replace it back on the bracket being careful not to disturb the pads or parts. Install the two bolts and torque them to 25 foot pounds.
Now, slowly press the rear brake pedal repeatedly until you get a full firm pedal. Check the level of the brake fluid in your master cylinder. Add only the proper type of fluid called for on the top of the master cylinder cap. DO NOT MIX THE TYPE OF BRAKE FLUIDS. Check the brakes before riding the bike. Failure to insure proper brake operation prior to riding the bike can cause lose of control of the machine resulting in serious injury or death. Make sure you do this job correctly.
Good Luck
sTeve
Oct 17, 2010 | Harley Davidson FLHTC - FLHTCI Electra...
Replace the rear brake pad on 92 ford ranger 3.0 v6,but only the rear left working,but right side is not,can you help me please or show me the diagram pictures!
If they are disks it will be a sticky caliper piston. (You can buy 'repair' kits online)
If it's running on drums, it'll probably be the cylinder.
One, or the other.
But also make sure that there aren't any obstructions, on the handbrake cable.
Good luck with that ;)
Don't forget to rate, thanks;)
Aug 01, 2009 | Ford Ranger Cars & Trucks
Left rear blinker and break light stopped working 84 eldorado
See if you can locate a wiring diagram for your vehicle. I have a 92 Seville and the wiring for the brakes and blinkers runs through the turn signal switch. The switch generally goes bad just from everyday use. They lose connection and you get intermittent problems (much like yours). Consult a wiring diagram, if they do run through the switch then I would recommend replacing that. Start there. Cheers.
Mar 12, 2009 | 1984 Cadillac Eldorado
I NEED A DIAGRAM OF 92 LUMINA SEDAN FRONT BREAK ASSEMBLY
That is the brake caliper bolt. It secures the brake caliper to the caliper bracket.
Please remeber to rate this fix.
Feb 14, 2009 | 1992 Chevrolet Lumina
Cant get caliper to calapse
Open Bleeder screw. If talking about rear caliper, piston must be turned clockwise, with brake "Cube" to retract.
Aug 08, 2008 | 1996 Cadillac Eldorado
Home Logo
67 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
