Question about Gardena Silent hand reel mower ()
How do i flip the pawl on a gardena reel push mower?
2 Suggested Answers
SOURCE: I have a gardena 12v
Hi! I had the same problem and had it repaired (guarantee-repair). They had to exchange the driving belt in the maschine and now it works great again.
Posted on Jun 12, 2011
Replacing the pinion gears in each wheel. Which way do the ratchet pawls go?
the pawls are positioned so that when the wheels rotate in a forward direction they lock up the pinion and drive the cutter blades ,
they release when the mower is pulled backwards
as for grease , if it had none then none is what is used
If it had grease then a water resistant bearing grease would be prefered
May 28, 2016 | Scotts 20" Classic Reel Mower
Why one wheel turns and other won't
Sounds like a seized bearing. Shoot oil into it or remove wheel and you can tell that way. I would oil the shaft and wheel well before taking apart.
Sep 20, 2014 | Great States 18-Inch Deluxe Reel Mower
How to open up a okuma komodo reel
to open the reel and access the worm gear cog ( the gear that actually drives the level wind ) you will need to remove the handle, the star drag assembly, the side plate screws etc. Before you do all of that look directly at the front of the reel beneath the level wind face plate is the worm gear pawl ( the tooth that actually rides in the level wind gear itself ) there is a cap with a flat head screw driver slot in it, remove the cap ( if you can access it with the face plate on other wise youll have to go thru the steps previously mentioned) and carefully tap the reel until the pawl itself falls out there will also be a very small washer that goes inside the cap. Inspect the pawl for defects like chips on the points that ride in the gear. also inspect the worm gear it self, debris that gets lodged in the gear from regular use can chip the ends off of the pawl which will cause the pawl to stick to one side or in extreme cases stop working all together. It is possible that the worm gear cog ( located in side the reel ) is damaged but almost every reel with this issue that I have repaired (100's of them) is caused by a damaged pawl or worm gear it self Dark Side Reelz
Aug 17, 2014 | Okuma Komodo Low Profile Baitcast Reel
Guide does not move on GTO220 is pawl worn?
It should have a gear under the side cover that goes from the crank to line drum to the pawl. You should take the side cover off open face reel Periodicly to lube the gears. It may be so a locking pin in the interior gear.
Jul 31, 2011 | Penn Gt Levelwind Series Reels
Does not flip arm to lock to reel in line
Normally when you **** the bail, the reel allows you to discharge the line with a flip of the wrist. Then when you touch the crank and execute half a turn it releases the bail to lock the line and allow you to reel in. If this action is not happening, then the release pawl is stuck and holding the bail in place. You must disassemble the reel, clean the parts and re-assemble with proper lubrication. Checking the parts for wear replace all worn parts.
Jun 22, 2011 | Shakespeare Agility Spinning Reel 6825
How to strip down a pflueger supreme reel. i need to know how to undo the handle from my pflueger supreme reel so i can get the side cover off. i need to change the pawl, and the pawl axle
On the new Pflueger Supreme ( which I own one of) tighten the drag down ( just snug it down) PUSH IN ON THE DRAG STAR, TURN HANDLE; COUNTER CLOCK WISE! Handle will back off...you must keep the drag star compressed until you reach a point it will no longer engage.....DO NOT LOSE THE SPRING behind the drag star. Good Luck.
Jan 08, 2010 | Shakespeare Sport & Outdoor - Others
Scotts reel mower gear problem
I found some replacements at http://www.reelin.com. The parts number for the pinion gear is 30737-2, 30737-3 (left and right) for the Scotts Classic.
You can find the owner's manual, with part numbers, here:
http://www.reelmowersetc.com/2000-20.pdf
Jun 09, 2009 | Great States 20" Scotts Classic Push Reel...
A part on my Scotts 16 '' Elite push mower broke
The number Jakeyjones gave is the customer service number. Call it and describe your problem.
As for the gear, I had the same issue. I called customer service and was told that there was a supplier material issue that caused some gears made last year to break more easily than they are supposed to. They are sending me 2 new pinion gears completely free of charge. These are the black plastic gears that engage against the orange wheels to make the blades spin. Make sure you don't lose the pawls (metal rectangular pins that go through the shaft to engage the pinion gears).
1-800-618-7474
I called at noon eastern time today. The woman I spoke with was very helpful and knew exactly what parts to give me.
Mar 24, 2009 | Great States Corp. 16 In. Scotts Elite...
Gardena Silent hand reel mower () Logo
27 people viewed this question
Top GARDENA Garden Experts
Dennis Key
Dennis Key
john h
Are you a GARDENA Garden Expert? Answer questions, earn points and help others
