Question about Samsung 700DXn LCD TV
Why does my samsung 700dxn no standby light
My TV was fine, now it has no power to it whatsoever, no standby light either. It was moved from one location to another recently but it was moved very carefully. The TV is not new, its a 2009 model. I read in quite a few places that TV's of this age are relatively easy to fix because it tends to just be the capacitors that need replacing etc. Is that accurate? If it is not capacitors, what could be the culprit?
SOURCE: Samsung LCD TV doesn't power on, just blinks 5 times
After about 5 years the Samsung LCD televisions backlight fails which prevents the TV from coming on and the powerlight just flickers the backlight can be changed but it is often alot easier and cheaper to buy a new Television
Posted on Sep 23, 2009
roety
  • 585 Answers
SOURCE: My Samsung TV power indicator light cycles on and off.
Hi my name is Eric,
I hope I can help you with your issue ,
Your power supply is the problem, a repairman will charge between $250-$450
depending on if they repair or replace the power supply
Seems you know about this already, they are either 1000uf at 16volts radial caps or 2200uf
open the set and look for bulging caps
here is where you buy new ones
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Posted on Sep 26, 2009
  • 927 Answers
SOURCE: Samsung model LNT5271f excessive relay cycling before full power
Howdy,
Yes, it is very easy to repair. Solder iron wattage should be at least 300 w.
The PSB is the center Board (towards left) after you remove the back off the TV. Remove the shield that covers the Boards and remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Good Luck, big IRISH.
Posted on Dec 28, 2009
Testimonial: "Great fix"
  • 927 Answers
SOURCE: Which Replacement Power Board for LNT4665F Samsung LCD TV?
Howdy,
It would be a lot cheaper if you just replace the two caps that have gone bad. Just get a cheap solder pencil from the store and about an inch of solder and you are in business.
The Power Supply Board is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Thaks for using FIXYA, BIG IRISH.
Posted on Jan 02, 2010
SOURCE: Samsung TV clicking and won't come on
Did you find out if that would solve the problem? I was really excited to learn that all I needed to do was change out the capacitors but after installing 4 it continued to click. I to removed the cover to the and found the relay where the noise is coming from
Posted on Jan 29, 2010
Samsung tv will not come on power light is on but will not show picture standby light flashes nothing else happens did this after moving from room to room
Capacitors are blown on the power board. if you keep unpluggging and trying sometimes it will come on other times not, but these capacitors will need replacing
Feb 11, 2015 | Samsung Televison & Video
HOW DO I FIX MY SAMSUNG FLAT LCD SCREEN ?? IT WONT TURN ON AND THER IS A LIL RED LIGHT FLASHING IN THE FRONT OF IT
How old is the set The older models suffered from problems with the electrolytic capacitors in the power supply . No point in trying another power outlet or cable if the standby light has been flashing red . Power is obviously getting to the set if the standby is lit .
Has the set been a little slow staring from cold lately
Jan 03, 2015 | Samsung Televison & Video
Screen is blank!!!!!!
How many times Standby LED blinks? Its 3 CRT rear projection TV.
Aug 01, 2008 | Sony KP-57WS520 57" Rear Projection...
No picture or sound
take you tv to tech you have damaged your microchip and component in the power supply
Dec 20, 2006 | Samsung TXN3245FP 32" TV
Samsung 700DXn LCD TV Logo
Jerry Greenberg
Jerry Greenberg
