Question about CDN Thermometers Digital Thermometer
Why does HH.H appear on my thermometer ?
Ocasionaly LL.L also appears with no other reading,why am I not getting a temperature reading ?
Keep gettinG LO thermometer when taking my son's temp. but quite Ok with others
The actual temperature may be below the calibrated range of the thermometer.
Sep 22, 2016 | Braun Irt 4520 Thermoscan Ear Thermometer
I have an Acurite 822-RX thermometer that shows HH as the outdoor temp, even after replacing the batteries in both the base and remote units. How can it be fixed or reset?
HH means it is showing the high temperature you (most likely accidentally) set with the MAX MIN / + button, which is easy to do when setting the clock. Just press that button again until the reading appears.
Jan 15, 2011 | Acu-Rite Acurite Wireless Weather...
What causes the temp reading of LL.L?
The SkyScan temperatures only register a certain range, typically -4F to 158F. If it is below this range, it will read LL.L and above it will read HH.H. However, I have been having trouble with mine reading the correct temp, so I often get very whacky numbers, and LL.L is becoming more frequent. Hope that helps!
Dec 30, 2010 | SkyScan 86742 Digital Atomic Wall Clock
I have lost my manual for Nexxtech thermometer model6312030. I can't get it to read the outside temperature after I changed the batteries. How do I reset to make it read. Or better yet, how can I get a...
You must reset the outside unit every time you change a battery. To rest insert a paperclip into the small whole marked "reset". Temperatures should now appear on the inside or remote unit.
St. Bruno, Quebec
Nov 10, 2010 | Vacuums
Oven temperature only gets to within 20-25 degrees of temp. set
next to last page in your manual
Adjusting Oven Temperature
Oven temperature has been factory calibrated and tested. If
oven consistently over or under cooks food, adjust thermostat.
Oven temperature can be increased or decreased 35°F. To
avoid over adjusting oven, move temperature 5°F each time.
1. Push BAKE pad.
2. Press + pad until an oven temperature greater than 500°F
shows in display.
3. Immediately push and hold, approximately 5 seconds,
BAKE button until “00” appears.
4. Press + or - arrow pad to adjust oven temperature.
• To increase oven temperature (for a hotter oven), Press
pad until a positive number appears in display.
• To decrease oven temperature (for a cooler oven),
Press pad until a negative number appears in display.
5. Press OVEN CANCEL pad to save adjustment.
• Setting is saved if power fails or is disconnected.
heres a link to the entire manual if needed
http://shop.amana.com/assets/pdfs/literature/32103601.PDF
Nov 27, 2008 | Amana AOCS3040SS Electric Single Oven
Preheating
hummmm this sounds similar to what is happening to me. I am praying someone will have a solution, I don't want to have to explain to my daughter who is going to be 4 tomorrow, why I can't bake her cake.
May 12, 2008 | Ovens
Preheating
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Jan 13, 2008 | GE Profile J2S968 Dual Fuel (Electric and...
CDN Thermometers Digital Thermometer Logo
91 people viewed this question
Top CDN Home Experts
john h
Tom Chichester
Are you a CDN Home Expert? Answer questions, earn points and help others
