Question about Microwave Ovens
Microwave daewoo koc 970t no display, spares availability in chennai... pl...
SOURCE: Daewoo KOC-985T - Help me find manual!
http://www.2instructions.com
Posted on Feb 05, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Daewoo KOC-1B0K no interior light and turntable not rotating
Looking at the service manual at our site, that would be a failure in the "motor relay" (relay 4) or one of the components that drive that relay, such as transistor Q8.
The part numbers for this relay are OJ-SS-124LM (generic) 5SC0101405 (Daeweoo).
Posted on Jan 29, 2009
SOURCE: Where can I get a users manual for a daewoo
manual required for a daewoo microwave cooker model no. koc-8h4t
Posted on Feb 28, 2009
SOURCE: Manual for Daewoo KOC-985T Microwave cooker
I have the manual with me.
Can u help me in return, who can do repair for this model KOC-985T; and where the spares are availble?
Contact me at prabirjose@hotmail.com
Posted on Mar 31, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: how do i change the bulb lamp on a Daewoo KOC-875TSL microwave
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
You'll need to remove the outer cover (wrapper) to get to the bulb.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
If you don't have your instructions, please reply back with your brand and model number.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Jun 08, 2009
Daewoo koc-985t bi - Not heating food equally. ie. middle of food cold. Sometimes food takes double the time to warm.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Jan 18, 2011 | Daewoo KOC-925T Microwave Oven
I have no internall light & manual is no help
If you remove the top cover of the microwave, about 10 screws, you will be able to locate the lamp/lamp socket. The lamp is available from your local appliance parts store for about 5 bucks. Unplug before opening.
Hope this helps.
Jan 20, 2010 | Daewoo KOC-925T Microwave Oven
Sparks coming from back of microwave
If you coffee container had any metallic logos or paint on it sparks will occur. Try to heat water in the glass container.
Dec 11, 2009 | Daewoo KOC-925T Microwave Oven
Micro wave works but do not heat up the contens model koc 970t
est the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.
Thediode and capacitors can br tested. The capacitor must bealloweddischarge before testing, or you risk to get electrocuted, evenifpower is off. Capacitors can get discharged by shorting theirtwocontacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
Mar 04, 2009 | Daewoo KOC-925T Microwave Oven
Manual for Daewoo KOC-985T Microwave cooker required please. HAVE BEEN GIVEN COOKER IN NEXT TO NEW CONDITION, BUT NO INSTRUCTION BOOK
Feb 28, 2009 | Daewoo KOC-925T Microwave Oven
Jan 08, 2008 | Microwave Ovens
Need a service centre
Can u suggest a service center for a daewoo microwave oven at bangalore. I wanted a glass turntable for my daewoo microwave oven. I wanted its telephone or contact number.My daewoo mocrowave oven MODEL NO.KOC-8H4T. Pls reply soon
Dec 09, 2007 | Microwave Ovens
Microwave Ovens Logo
16 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
