Question about MedWeigh MS3300 High Capacity Medical Scale
MedWeigh scale Instruction manuel or how to change the units from oz to lbs
How to change kgs to lb
There's a small "unit" button on the bottom/back of the scale. Press this until it goes back to lbs. It should cycle between kg, stones, and lbs. If that doesn't seem to be working, press and hold for 4 seconds or more. The screen will flash "reset" and it will have gone back to default, factory settings.
Mar 23, 2014 | Ozeri Scale. Touch Digital Bath Scale in...
How do I set my Hanson Body fat Scale HFX835 to read in lbs?
Body Fat/Bone Density Scales and the like can be just about impossible to program without having the instruction manual. However, changing unit of measurement is usually very easy. Just look for a manual switch on the bottom of the unit, often found in the top left corner. You may need a pen or similar item to change the setting.
Apr 17, 2013 | Health & Beauty
I have the royal ex3 digital scale and when i turn it on it just shows - - - - how do i fix it ?
I am having the same problem with my Royal ex3....changed the battery, but when I turn it on, all I get is - - - -
Anyone know what this means or how to fix it??
Jun 30, 2011 | Royal 17014c 10 lb Digital Postal Scale
Change scale from kg to lbs
Ok i Just figured it out my self with no manual. When you put new batteries in your scales the unit will be shut off. Press and hold the select button for 5 seconds and then it will show LBS or KG and you will be able to change your weight at that time. Hope this helps.
Apr 23, 2011 | Health-O-Meter Health o Meter BFM681DQ-63...
I have glass top bathroom scales eks. reading err5 any ideas how to fix? javan
Hi take the batteries out then put them in again that should solve the problem
Jun 28, 2009 | MedWeigh Health & Beauty
Does not turn off automatically
Turn remote "off", press and hold "Kg - Lbs" button, turn unit "On". Display should show "0", then "320" or model number. Unit was programmed to disable auto off. Works great now.
Thanks
Jun 01, 2009 | Health-O-Meter Healthometer 320KL Digital...
How do I get the detailed instruction manuel for the Taylor Bodyf
This link allows you to trouble shoot and download manuas directly with/from the company... I hope this helps. http://www.taylorusa.com/advantage/root/contact.html
Dec 01, 2008 | Taylor 5593 Body Fat/Body Water Scale
Tanita 2204 Scale weight reading problems
Try the following steps:
1) press both the "set" and the triangle button
2) press the triangle button until you get the desired unit of measurement: a) Kilogram, b) stone lbs or c) lbs; and
3) press the "set" button.
Nov 16, 2008 | Tanita 2204 Body Fat Scale
MedWeigh MS3300 High Capacity Medical Scale Logo
Top MedWeigh Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a MedWeigh Health and Beauty Expert? Answer questions, earn points and help others
