Speaker noise in dodge truck
Fan causes speaker noise in drivers door dodge truck ,with radio turned off or on
insanegtp
  • 112 Answers
SOURCE: i have a jensen uv8
Your remote wire is wrong behind radio swap the blue and blue/white stripe wire going into cars blue wire... you'll be allset...
Posted on Jan 26, 2009
LVT7857
  • 116 Answers
SOURCE: uv8 some seakers dont work in dvd/cd mode
You have the wrong wire hooked up to turn on your amplifire. You used the blue wire but need to use the Blue/White wire!! That is an amp turn on wire Thje blue one is for a power antenna and goes dead when you put in a disc. The tweeters play because they are hooked direct to your Jensen. You'll be jamming in no time.
Larry T
Winona Lae
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html IN
Posted on Jan 28, 2009
samtoler
  • 666 Answers
SOURCE: Radio intereference (whistling sound)in auto
buy a noise suppressor, you can get it at any audio store
Posted on Jun 09, 2010
  • 28 Answers
SOURCE: radio harness diagram for 95 chevy tahoe....rear
check wiring on passengers side near the rear hatch speaker, the rear door speakers are run through them also. i had the same problem and it was a unplugged connector at that location
Posted on Dec 12, 2010
emissionwiz
  • 76846 Answers
SOURCE: i need a factory speaker and radio wiring diagram for a 2009 dodge 2500 quad cab truck
This is what my books show.
2009 Dodge Ram 2500 Car Radio Install Instructions
Car Radio Battery Constant 12v+ Wire: Gray/Red
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
Car Radio Ground Wire: Black/Dark Green
Car Radio Illumination Wire: Orange/Dark Blue
Car Stereo Amp Trigger Wire: Dark Green/Red
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Posted on Jun 12, 2012
Signal working no noise 07 pontic G5
Probably the driver door speaker is going out (yes the "click" noise is "played" through the speaker). Seems common on these cars and was my problem. Turn all your music to that one speaker using the radio controls and see if it plays music. All the chimes and blinker noises come out of that speaker.
Oct 21, 2016 | Cars & Trucks
INfinity speakers make loud bumping and static noise when radio fuse is plugged in
It sounds like the radio is defective. I can think of no other issue that would cause the speaker noise you discribe
May 26, 2016 | 2002 Dodge Stratus
My radio and cd want put no sound out fuses are ok and my speaker is makind nose even when the car is turn off
'03 G35 Radio Problem. Speaker Noise Even When RadioTurned Off ...
g35driver.com/.../437164-03-g35-radio-problem-speaker-noise-even-w...
Feb 1, 2014 - Turned entire car off/on several times, no change. ... Still had the static/crackling type noise from driver rear speaker at all times - even with ...
Oct 01, 2015 | 2007 Kia Amanti Sedan
97 DODGE 1500 CHASIS WIREING DIAGRAM
probably a bad ground connection on the speaker. remove door penal and speeker and inspect.
Mar 24, 2013 | Cars & Trucks
The speakers on the left side of my 2003 dodge intrepid quit working
take the door panel off, disconnet the speeker harness connector using an anolog multimeter the one with the needle setting on A/C low voltage cause sound is transmitted thru A/C current putting the Pos. & neg. probes on the harness side turn on the radio and watch the needle move if it does'nt the radio went to hell or if it does then change out you speaker.
Sep 12, 2010 | Dodge Intrepid Cars & Trucks
2008 Cobalt - Front speakers not working and no audible turn signal. Both stopped working at the same time.
In my 2008 Cobalt, the front speaker in the driver door went inoperative - no turn signal noise, no warning chimes for door open with key in, seatbelt chime, low fuel chime, and of course, no music. All of those sounds come through the speaker. I switched the driver door speaker and the passenger door speaker, and now I have all of those noises back.
If you have manual roll down windows, you'll have to buy a special tool to remove a little clip that's behind the roller handle. This tool was included in a kit for about $7 that I bought at Harbor Frieght, but you might be able to find the kit at other auto parts stores. Google "removing window crank" and you should be able to locate a video that shows how to get it off.
Anyway, I switched the speakers and now we just don't have music coming out of the passenger door speaker, but at least we have all of the warning chimes and turn signal clicking noise again.
The dealer wanted almost $200 for a new speaker and to replace it (labor). Rediculous.
Jul 20, 2010 | 2008 Chevrolet Cobalt
Jun 09, 2010 | 2005 Chevrolet Tahoe
Dodge 2007 charger the passenger speaker in the front is not work
when mine stopped working,the right speaker, i removed the door panels then swapped the speakers. and still the right speaker didnt work. so i got a radio from a junkyard and installed it. and now all speakers work fine.
Feb 28, 2009 | 2007 Dodge Charger SRT8 Sedan
Radio Problems
Check your wiring harness from the radio to the speakers, as well as the wiring to the speakers themselves. If the insulation is gone, sometimes that open wire will cause that noise. Or, the plug off the back of the radio to the speakers could be loose.
Oct 17, 2008 | 2004 Dodge Ram 1500
15 people viewed this question
jasbo
jasbo
