Question about Haier DE65EK 65 Pints eco-Friendly Portable Dehumidifier w/ Adjustable Humidistat, Built-in Wheels, LED Display, Auto shut-off & Auto Restart, Comes with Continuous Drain option, Energy Star rated, Covers up to 3,700 sq ft
How do I install the drain hose to my haier dehumidifier? DE65EK
4 Suggested Answers
  • 30 Answers
SOURCE: haier 30 pint dehumidifier continuous drain problem.
Many just attach the hose at the reservoir; from your description, Haier apparently has a separate location. Check that the point that the hose attaches has an opening (many don't, they expect you to drill it). It should then drain through gravity. Check to make sure that no part of the drain hose is higher than the bottom of the reservoir, otherwise it can't drain. It won't siphon because each time the the tank empties, the suction is broken and the siphoning can't continue.
Posted on Aug 31, 2008
SOURCE: I have a model HD-306 Haier dehumidifier which is
please make sure the unit is leveled.also make sure the hole in the drain pan not clogged.also the size of the hose must be fit the hole not smaller
Posted on Sep 13, 2009
  • 2468 Answers
SOURCE: Haier HDN655E - water does not drain out of hose
check the hose connection,when new these units have a knock-out plug where the hose goes so if your only going to use the bucket and not the hose it wont run out the hose connection
Posted on Aug 01, 2010
Dehumidifier runs continuously and displays higher than normal humidity levels.
Probably some glitch with the sensors. I recommend taking it to a service center.
Dec 06, 2013 | Haier DE65EK 65 Pints eco-Friendly...
What does E1 mean on the display of my dehumidifier
follow this steps and fix it. God bless you
E1 error code : Deshumidifier
indicates generally an issue with rh sensor on the back of the control. However, at this time we would like to gather further information relating to the application if possible.
Oct 29, 2013 | Haier DE65EK 65 Pints eco-Friendly...
Why doesn't water drain into the hose?
My dehumidifier was dumping condensate onto the floor instead of through the hose to the floor drain. The solution turned out to be making sure the unit was level. No worries since then.
Feb 05, 2013 | Haier 65-Pint Energy Star Dehumidifier...
I am showing a HI on my current humidity/set humidity display what does it mean
The HI indicates that the current humidity is 90%+ in the room/unit. You should check if the filter is clogged. I've seen this message in dryer locations when the dehumidifier coils ice up. Check the coils (behind the filter) for any build up.
If this is a brand new dehumidifier, leave it on for an hour to see if it auto-defrosts. (A similar wait is needed if the room is cooler that 60 degrees F.)
If the unit continues to freeze up and the room is over 60 degrees, you may have a refrigerant leak in the dehumidifier. If it is still under warranty (5 years on the cooling system), contact Haier. The warranty service number is 1-877-337-3639.
The manual for the DE65EK is available here: www.haieramerica.com/downloads/dl/file/id/26/de65ek_manual.pdf . You will need Adobe Reader or a similar program to access the manual.
I hope this helps.
Dec 24, 2012 | Haier DE65EK High-Efficiency ENERGY STAR...
Model DE65EK. Why won't it drain into hose?
Your dehumidifier must be level for proper draining.
Jun 29, 2012 | Haier Dehumidifiers
Aug 01, 2010 | Haier HDN655E Dehumidifier
I have a model HD-306 Haier dehumidifier which is hooked up with a hose to a drain. It has been working fine until several days ago. Water now is coming from the bottom of the unit onto the floor. I...
Sep 04, 2009 | Haier 45-Pint Dehumidifier
Continuous drainage
Take out the drain pan and look in left hand top of the compartment and you will see a drain hole for the pan.Plug the drain hole with a small rubber plug, I used an electrical wire nut wrapped with tape and it worked fine.replace the pan and the water will run out the back. A 3/4" garden hose should work for the drain hole.
Jul 27, 2009 | Haier HDN655E Dehumidifier
Haier 30 pint dehumidifier continuous drain problem.
Aug 24, 2008 | Haier Dehumidifiers
Haier DE65EK 65 Pints eco-Friendly Portable Dehumidifier w/ Adjustable Humidistat, Built-in Wheels, LED Display, Auto shut-off & Auto Restart, Comes with Continuous Drain option, Energy Star rated, Covers up to 3,700 sq ft Logo
53 people viewed this question
Top Haier Dehumidifiers Experts
Shawn DuRee
Michael Vincent Cruz
Shehu Pro
Shehu Pro
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
