HP LASERJET 4250N PAPER JAM IN 20.13.00 TRAY 2 HOW TO FIX
5 Suggested Answers
NotAsUsual
  • 43 Answers
SOURCE: hp laserjet 4250n paper jam in 13.01.00
According to the manual: "A 13.01.00 error message indicates that the media did not arrive at the pre-feed sensor (PS102) within the specified time." That usually means that the rollers fail to pickup the paper from Tray 2. Usually, cleaning the paper feed roller in the 500 sheet tray should fix this. While blowing out dust, you may have coated this roller with paper dust. A quick way to double check this is to power cycle the printer & try to print from Tray 1, the MP feeder tray (unless Tray1 has rarely or never been used...it might be a little tempermental as well). Regardless, this error is very common & is usually fixed by cleaning. Depending on usage, this roller is considered a customer replacable item (Part # RM1-0037-000CN) with a life expectancy of more than 200,000 pages. There are 3 of that type roller in the printer, but the one in the tray is usually the 1st one to fail. Hope this helps!
Posted on Jun 02, 2008
DosHog
  • 168 Answers
SOURCE: 13.01.00 paper jam tray 2
The pickup rollers are worn out. Replace them and your problem will be gone. While you are sourcing them, use some alcohol. This may give them a little more life.
Posted on Jul 23, 2009
brett207
  • 231 Answers
SOURCE: Laser Jet 4250N
You should be able to clear this jam yourself
Open the top cover and remove the toner cartridge.
Look inside for jammed paper, and remove it.
Reinstall the toner cartridge and close the lid.
Try that....
Posted on Dec 08, 2009
  • 345 Answers
SOURCE: i have a hp laserjet 4250 printer it had a paper
There is still paper stuck in the printer. try lifting the printer off of tray 2 to inspect it or here it is straight from the service manual...
Jams in tray 2
Table 7-10 Causes of tray 2 jams
Cause Solution
The feed or separation rollers are dirty, worn, or damaged. Clean the rollers. If they are dirty after cleaning, or if they are
worn or damaged, replace the rollers.
The pickup roller is worn or damaged. Replace the pickup roller.
The tray 2 paper pickup assembly drive gears are damaged
or the assembly is defective.
Check the drive gears in the paper pickup drive assembly.
Replace the pickup drive assembly if the gears are
damaged. See Paper-pickup drive assembly.
The tray 2 pickup solenoid (SL101) is damaged. 1 Disconnect the connector for the tray pickup solenoid
from the dc controller PCA (location J92).
2 Measure the resistance between the cable connectors.
3 If the measured resistance is not approximately
160 ohms for the HP LaserJet 4200/4300, or 110 ohms
for the HP LaserJet 4250/4350, replace the tray 2
pickup solenoid.
The tray 2 lifter-drive assembly or the stack position
sensor (PS107) is defective.
Replace the lifter-drive assembly. See Tray 2 lifter-drive
assembly and/or Printer switches and sensors.
The dc controller PCA is defective. Replace the dc controller PCA. See Dc controller PCA.
Dirty, worn, or deformed pick-up roller, cassette separation
roller, and cassette feed roller.
Clean the rollers if they are dirty. Replace any worn or
deformed rollers. The cassette separation roller and the
cassette feed rollare are to be replaced together.
Damaged gears in the cassette pick-up drive unit. Move the gears in the cassette pick up drive unit. If the
gears are not rotating correctly, or are damaged or worn,
replace the cassette pick-up drive unit.
Posted on Dec 25, 2010
HP LaserJet 4250n Printerclearing paper path Questions
If this continually displays then either you have an actual paper jam in the printer that you have not found yet or a flag is broken/sensor has failed. Make sure you check the paper path that runs from the tray behind the MP tray assembly.There is a sensor in there that can be damaged.
Dec 02, 2015 | HP LJ 4250 Printer
Hp Color Laserjet 1600 says Jam in tray 2 bt there is not paper jams
Open the paper feed area and the printer, examine the paper feed path and make sure there isn't a page or piece of paper jammed in the path somewhere.
Aug 21, 2014 | HP Color LaserJet 1600
Our HP 4250N Laser Printer is leaving a black line approx 2 inches off left side of paper. Tried cleaning rollers and putting printer into clean mode. Nothing is working. Any advice? Thank you.
This is caused either by the fuser or the tonercartridge.
The most common cause is the tonercartridge.
You can test this by forcing a paperjam to stop the paper just after the toner but before the fuser.
To force a paper jam print you can print a page from the manual feed tray and as the last third of the page enters the printer opening the door causes it to halt.
If the black line is there before the toner is bonded to the paper by the fuser you should replace the tonercartridge..
Jan 04, 2011 | HP LaserJet 4250n Printer
LaserJet 2420 Printer: hp 2420n 13.20.00 jam inside rear door...
i have 2420 dn printer..printer reddy mode the power on...but not initlizing...13.20 paper jaming error coming but paper is not jam..hw to resolve
May 06, 2010 | HP LaserJet 2420 Printer
Laser Jet 4250N Is The jam code B.20.00 paper jam in tray 2..... a service call or can i try to fix it myself?
Try that....
Dec 01, 2009 | HP Office Equipment & Supplies
Paper jam
Try taking out the toner cartridge and seeing if you see any more bits of paper. Also open up the back panel and see if you see anything there.
Jun 12, 2009 | HP LaserJet 4250n Printer
I have a paper jam with my MP610 printer its the rear feed tray i got the paper out intact (1 piece) it still tells me there is a jam. Is there a sensor i may have tripped? I bought the printer 3 weeks ago
My hp laserjet 4250n was working perfect but when i give above 50 number of print it's start to use it it gives messege says paper jam in 13.01.00 help me how to fix this problem
Sep 15, 2008 | Canon Office Equipment & Supplies
Hp laserjet 4250n paper jam in 13.01.00
Jun 02, 2008 | Office Equipment & Supplies
HP 4250 DN
Change the tray one behavior from the front panels paper handling menu. from there you can tell tray 1 to print first if paper is present or default to tray 2.
factory settings are to print from tray 2.
are you keeping paper in both trays??
Mar 28, 2008 | HP LaserJet 4250n Printer
23 people viewed this question
jasbo
jasbo
