Question about Samsung CLP 300 Laser Printer
PINK LINES AT THE BOTTOM OF MY WORK
Thera are pink lines, streaks at the bottom of the page, also the black ink is fading. All new toners.
  • sfedrick66 Jun 23, 2009
    Thanks, i really appreciate this, but how do i clean the printer heads?
  • 93 Answers
Try cleaning the heads.
Posted on Jun 22, 2009
When we attempt to print it leaves black streak marks. At first it printed all black and when we went to setup under maintainence we chose alignment and clean cartridges. This worked however we still see...
If an inkjet printer gives white streaks where it should be black, it means the ink is very low, or there is dirt under the nozzles preventing it from printing properly, or, in the case of non original cartridges, ink might be leaking which prevents the bubbles of ink to squirt onto the page.
If the streaks are black where it should be white, is sounds like some dust or fluff below the cartridge leaves ink smears on the page.
Aug 23, 2011 | Lexmark X4650 InkJet Printer
I bought some cheap toner and noticed almost immediately streaking and missing lines. I replaced it with HP toner but now black won't print at all.
If your printouts are streaked or faded, missing black or other colors, have blurred or fuzzy text, or ink streaks or smears, or show other problems, please refer to the link below for troubleshooting steps for print quality issues.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01957673&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=2512009
Apr 03, 2011 | HP Officejet Pro L7680 All-In-One Printer
Our copies are streaky like the drum is not clean.... help! There is black streaks on the top of all of our copies on our canon imagerunner 3300.
A) Black Streaks, Shadows, And Ghosting
Adjust the printer's lightness/darkness setting to 2-3 different variables and see if problem disappears. Look at the fusing assembly - is the roller torn or does it have any black buildup? Use caution!!! It gets HOT!
Try another toner also.
Feb 17, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Quality starts out good, and then fades quickly
You probably running out of black ink. Try replacing with new black ink cartridge.
Try to run a test print.
Jul 18, 2009 | Office Equipment & Supplies
Faded-out streak
check your ink levels. if its the ink that came with the printer it is probable running out of ink. they do not give a full cartridge with printers, only about 3rd full. also try cleaning the heads. and try changing your printer settings/prefrences to less ink, more drytime see if that helps.
Apr 26, 2009 | HP LaserJet 1018 Printer
Faint printout
So we all understand; there is no ink your printer. In an inkjet printer, liquid pigment is sprayed from print heads directly on the paper where it dries and makes an image. Your printer has toner, which is a pigmented powder. I'm sure you found this when you cleaned the waste toner container.
The simple:
A laser printer draws an image on a rotating drum which then rolls into a tub of toner. Anywhere the laser hit, toner sticks, where it didn't hit, it doesn't stick. The drum rolls over a piece of paper (transfer belt with 1-pass color) and the toner rubs off onto the paper - it's still powder. The paper then goes through an oven (developing drum or fuser) which melts the toner onto the paper. BaM! Out comes your document.
A consistent line going from top to bottom of every page printed means one of the following:
1) A band of evil is thinly encircling the imaging drum causing it to pick up toner where it has not been hit by the laser. Check the imaging drum for lines that match the ones on your paper. Replace if necessary.
2) The transfer belt has a line of evil on it. Look at the belt in the right light in order to see scratches and such. Replace as necessary.
3) If your streak is an anti-streak, which is the LACK of toner. You need a new imaging drum. It's damaged. Unless it's a smudge, then its the fuser.
You can clean things inside very carefully with a cloth, but I always use compressed air. The CLP-300 is very compact and cheap and is not really made to be repaired. Replace the parts, or throw it away.
I understand that at this time July 18, 2008, you can purchase this unit for as low as $99 US after mail-in rebate. Check your local or online (newegg) retailer.
Questions? Ask. Good Luck.
Jul 08, 2008 | Samsung CLP 300 Laser Printer
Magicolor 2400W print fades on right side of page
Have you tried cleaning the leans at the bottom of the printer? Open the cover, pull out the drum. Under it is a long, narrow piece of glass. If it gets dusty or toner accumulates on it, it will cause streaks in the printing. If this is dirty, take a clean, soft cloth and very gently wipe it off.
May 12, 2008 | Konica Minolta magicolor 2400 Laser...
Consistent, faded and streaking vertical lines across entire page, from top to bottom.
Toner issue getting to drum - use gen toner cart.
or Drum blade stuffed (lines are down page fro top to bottom- replace drum assy
Drum has been exposed to light faint or blank across copies repeated 4 times down page - replace drum assy
or upper fuser roller stuffed, down page, smudgy print -  replace fuser
LSU(laser) or boards rarely cause issues
Oct 25, 2007 | Samsung ML 2010 Laser Printer
Black streaks on printout page
It sounds like excess toner has built up in or around the imaging drum. I would *carefully* remove the toner and drum (can be messy) and use some canned air to clean the inside out. If you are still getting these streaks, it might be time to get a new drum (DR 400) as you are supposed to replace the drum every 6 to 8 times you change the toner cartridge.
Aug 22, 2007 | Brother HL 1440 Laser Printer
Samsung CLP 300 Laser Printer Logo
226 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
