Question about Ryobi Cultivator
What size is the fuel line on an earthquake mini cultivator
4 Suggested Answers
wadembly
  • 513 Answers
SOURCE: fuel lines on my cultivator corroded. I do not
ok you have two fuel lines coming in from tank the one that has the fuel filter atached inside should go to the top & the other is just the return line try that & let me know if it helps wade at wadembly@aol.com
Posted on Jun 06, 2009
  • 112 Answers
SOURCE: how to hook up fuel lines &were
top one usually goes to primer bulb and bottom to carb if its like the one I got.
Posted on Jul 24, 2009
  • 316 Answers
SOURCE: fuel line diagram for sears mini cultivator
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, ``
Posted on Feb 21, 2012
Why is the belt wearing out so quick, i have used my brand new earthquake rear tine tiller less than ten hours and have gone thru three belts.
-The pulley, idler are not line up and may be too sharp edges. or may be some other part is touching the belt when is running.
Good luck
mai
Jun 08, 2014 | Ardisam Inc Earthquake Mini Cultivator
Tines
Either clutch is bad or teeth are striped in bottom gear box. remove tines run engine and see if you can feel movment in lower gear box, if yes the gears are gone. If no remove engine to expose clutch.
May 20, 2013 | Ardisam Inc Earthquake Mini Cultivator
Belt size 727a
5/8" or .625 by 39" Honda PN 22431-727-013
Mar 11, 2013 | Ardisam Inc Earthquake Mini Cultivator
Have been on the computer all morning many diff sites getting a nervous breakdown want tine geat & shaft part for earthquake mini tiller all sites are impossible to use help help help
Select the model on this website and then the part. The link below is for MC43E Mini Cultivator http://www.getearthquake.com/foundations/store/partsblowup.asp?product=MC43E
Jul 19, 2010 | Ardisam Inc Earthquake Mini Cultivator
Earthquake Viper 43C engines revs up and then quits
CHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RUN LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING ,FUEL FILTER AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 25, 2010 | Ardisam Inc Earthquake Mini Cultivator
Rewind on earthquake mini cultivator won't rewind
Call 1-866-598-2128 for parts, they are in Appleton, Wisconsin.
Jun 28, 2009 | Ardisam Inc Earthquake Mini Cultivator
Ryobi Cultivator Logo
102 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
