Question about Sharp AR-M205 Copier
Sharp AR-405 showing error H3-01... how do I reset this error?
  • 41 Answers
Press the following in sequence
program / interrupt /clear /interrupt
press 14 and enter
restart and away you go.
let me know if it works
Posted on Jun 24, 2009
The printer Ar-5516 is showing H4 error
this error means:
heat roller abnormally low temperature.
for check:
1- check the heater lamp
2- check the thermistor
for reset:
clear key --> interrupt key --> "0" key --> interrupt key --> 14 --> start key
Jul 04, 2012 | Sharp AR-5316 Advanced Digital Imager...
My Sharp Copier Model AR-M160 showing f2 error even I replace the new tonner.
Below are the F2 errors and causes for Sharp AR-M160
"F2-31" Image density sensor fault
"F2-32" Drum mark sensor fault
"F2-33" Grid voltage correction problem
"F2-35" Grid voltage correction problem
"F2-37" Drum mark sensor fault
Cause : CRUM chip defect OR Improper developing unit
Check and remedy : As you have already replaced the tonner, we can suggest Replace the CRUM chip,Replace the developing unit
Regards,
Shrey
Jun 01, 2011 | Sharp AR-M160 Laser Printer
Error H3-00
Hello sir; This error code require a reset procedure ;
press "#", "*", "clear", "*",these four keys by order, then enter 14 press start. then turn power off and back on.
Aug 26, 2009 | Sharp AR-168D Copier
Sharp Ar-405 H4 error, when reset it goes right back to H$. What Part do I need to replace?
THE ERROR IS IN THE FUSING SECTION SO i WOULD LOOK THERE IF YOU HAVE RESET THE CODE EITHER THE LAMPS OR THE THERMISTORS ARE DEFUNCT SO THAT WOULD BE MY ADVISE TO START IF YOU TEAKE THE FUSER OUT GET AN ELECTRICAL TESTER AND CHECK THE LAMPS FOR A CONTINUITY BETWEEN THE CONNECTIONS IF THE THERMISTOR NEED CHECKING YOU CAN DO THIS ON RESISTANCE BY TURNING YOU TESTER TO THE OHMS SETTING AND CONNECT ACROSS TWO ENDS THEN PUT FINGER ON RESISTOR AND CHECK THE READING ALTERS . IF IT DOES THEY SHOULD BE FINE YOU CAN CHECK THE THERMO FUSE TOO.. GOOD LUCK a
Jun 30, 2009 | Sharp AR-M205 Copier
AR-405 copy machine has a L-6 10 error message. How do I reset copier?
It can not be reset, the problem is in your polygon motor at the laser unit, you should replace it
Jun 05, 2009 | Sharp AR-M205 Copier
Sharp AR 5316 E photocopier error clearing
Try reset by pressing [#] [interupt] [C] [interupt] [1] [6] [start]
May 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp ar 405 u2-11 error
Content Counter check sum error (EEPROM)
Detail Checksum error in counter data area
Cause EEPROM defective
Control circuit hung up due to noise
Defective EEPROM access circuit on
PCU PWB
Check Check EEPROM for proper set-up
and To prevent the erasure of counter data
remedy and adjustment values, write down the
counter data and adjustment values by
simulation. (If there is a printer option,
execute SIM23-1 and note counter
data/adjustment values.)
Clear U2 trouble with SIM16.
Replace PCU PWB.
May 22, 2009 | Sharp AR-405 Printer
U2 fault on Sharp AR-206
Error code U2 in Sharp copier AR 206 shows error or failure of toner crimp you can try to solve by replacing toner crimp
Or by reseting the error code by fallowing procedure
press c intrrupt 0 ( zero ) intrrupt contoneously after pressing all the light on control will go off then press 16 then press start switch
your prob will 100% solve.
if any more prob pl inform
May 20, 2009 | Sharp Office Equipment & Supplies
Error code 4H on sharp ar 5316
WHEN THE SHARP AR-5316 PHOTOCOPIER IS SWITCHED ON THE ERROR CODE 4H APPEARSAND THE MACHINE CANNOT BE OPERATED. IHAVE TRIED THE SOLUTION SUGGESTED JUNE THIS YEAR BUT IT DID NOT WORK. WHAT CAN I DO TO GET THE MACHINE TO WORK? IT IS VERY URGENT.
Feb 18, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp ar-163 model Error code F1
You can hold down the start key when the F1 is displayed it will show a sub code. The service manual for that model shows only one F1 code which is an F1-06. That is a shifter motor trouble. That is the section after the exit that offsets the copies.
You can reset the code with the instructions below. If the error recurrs then chech the exit section shidter for proper movement. You may require an on site technician to remedy this issue.
To reset the error code:
Hit <clear> <interrupt> <0> <interrupt>
14 <start>
Jan 05, 2008 | Sharp AR 163 Copier
Sharp AR-M205 Copier Logo
805 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
